Pages: 1 | 2 | 3 | (show all)
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: Unexpected viewing with the ES 24mm 68° new [Re: great_bear]
      #5941953 - 06/26/13 06:51 PM
"Seagulls" would be from coma which is from the primary mirror, not the eyepiece.
Coma produces comet-tailed aberrations, not seagulls.
Seagulls are astigmatism - very much an eyepiece issue.
Well, an actual seagull shape can be a combination of coma and astigmatism.
If the sky background is bright, rather than look like a comet, coma may look like a "V" with its point aimed at the center of the field. The "V" will be narrow, though, and not as wide as >
If that "V" is widened until it has a seagull shape, it is likely to be a combination of coma and astigmatism.
Scanning4Comets
Markus
Reged: 12/26/04
Loc: Ontario, Canada
Re: Unexpected viewing with the ES 24mm 68° new [Re: Starman1]
      #5942141 - 06/26/13 09:11 PM
ASTIGMATISM:
http://tinypic.com/view.php?pic=hvuqzr&s=5
COMA:
http://tinypic.com/view.php?pic=6tkyzm&s=5
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: Unexpected viewing with the ES 24mm 68° new [Re: Scanning4Comets]
      #5942186 - 06/26/13 09:38 PM
Thanks Markus. Sometimes a picture is worth a thousand words.
Edited by csrlice12 (06/26/13 09:40 PM)
      #5942195 - 06/26/13 09:45 PM
When you combine EYEPIECE astigmatism with coma, it does make "seagulls". TELESCOPE astigmatism produces images that are elongated in one axis that then flip to elongation of the other axis depending on focal position. Slightly inside of focus the astigmatic image will elongate on one axis and on the other side it will elongate on the other axis.
EYEPIECE astigmatism take takes a comet-shaped comatic image from the telescope and spreads out or fans the light of the "tail," forming seagulls and other similar distortions of the comet-like shape. Here are some examples:
EYEPIECE astigmatism:
http://www.telescope-optics.net/images/epa.PNG
TELESCOPE astigmatism:
http://www.telescope-optics.net/images/13d.PNG
TELESCOPE coma:
http://www.telescope-optics.net/images/11d.PNG
You can see how combining the first and third would produce fans or seagulls. Eyepiece astigmatism is common when a less well corrected eyepiece encounters a fast light cone. Most Dobs are fast scopes delivering a fast light cone. Fast dobs also show telescope coma from the steeply parabolized mirror. Telescope coma plus eyepiece astigmatism gives you little fans or seagulls off axis depending on the degree of each aberration and which one predominates. Haven't really checked to see how eyepiece astigmatism, telescope coma and telescope defocus manifest in off-axis SCT images. For me I think the defocus is so pronounced with wide field eyepieces that encourage me to care about off-axis image quality in my SCTs that I can't tell in what other ways the blobby defocused stars are also distorted.
- Jim
Sarkikos
Reged: 12/18/07
Loc: Scotophobe Maryland, USA
Re: Unexpected viewing with the ES 24mm 68° new [Re: jrbarnett]
      #5942280 - 06/26/13 10:55 PM
Very instructive pics and text, Jim and Markus!
Scanning4Comets
Markus
Reged: 12/26/04
Re: Unexpected viewing with the ES 24mm 68° new [Re: Sarkikos]
      #5942328 - 06/26/13 11:32 PM
Great additions and images there Jim
Reged: 06/16/04
      #5948270 - 06/30/13 03:48 PM
Regarding astigmatism:
Astigmatism means that an optic has two different focal lengths which are at 90 degrees to one another. In the absence of other aberrations, it means that when one orientation is focused, the other orientation will be out of focus, creating a line. "Best focus" is somewhere in the middle.
Anyway I spent the past 4 nights, out under dark skies and did some comparisons and evaluations with the Meade 24mm SWA. Basically it's a good eyepiece.
16 inch F/4.42: Without the Paracorr, coma was visible.. maybe some other stuff. With the Paracorr (F/5.07), I saw no field curvature, the edge correction was about as good as it gets in a fast Newtonian.
TV NP-101. As previously noted, I saw no obvious field curvature but there are some small off-axis aberrations, sufficient to be noticeable but small enough that I could not determine their nature. Near as I could tell it was probably astigmatism. With the NP-101, I expect the off-axis stars to be as sharp and clean as those in the center, this eyepiece, this eyepiece was very good but not that good. In comparison, the sometimes maligned 22mm Panoptic showed perfect tight stars across the field of view.
In another forum, another fellow and I went round and round about the 16mm Series 5000 Meade. He claimed it had coma, I thought it must be astigmatism. I finally purchased a 16mm SWA simply to resolve this question. It did seem like it had coma but that it went away when used with a Paracorr.
It does seem unlikely but I wonder if the reverse coma an coma correct adds could also affect the eyepiece.
Edited by Jon Isaacs (06/30/13 03:51 PM)
Starman1
Reged: 06/24/03
Loc: Los Angeles
Re: Unexpected viewing with the ES 24mm 68° new [Re: Jon Isaacs]
      #5948407 - 06/30/13 05:32 PM
John,
If the coma corrector corrects the coma from the objective, the image provided to the eyepiece will have no coma.
If you saw coma without a coma corrector and no coma with it, it isn't because the coma corrector canceled the coma in the eyepiece--it's because it canceled coma in the objective.
It's not totally impossible for an eyepiece to produce coma, but it is usually a characteristic of extremely simple lens designs, which the 16mm does not qualify for.
I've tested this eyepiece, and it has mild field curvature, a mild-to-moderate edge of field astigmatism, minimal lateral chromatic aberration, and mediocre suppression of off-axis or out-of-field scattered light, but decent suppression of peripheral light reflection off the top of the eyepiece. Its best performance wasn't in the NP101, but in my f/12.8 Maksutov. It was out-performed by a 16 Nagler, but at 3X the price.
If a coma corrector improved the images in this eyepiece and it was not coma you were talking about, it would likely to be the mild field flattening of the Paracorr at work. Or the mild f/ratio change affecting the induced astigmatism in the eyepiece from the light cone.
Reged: 06/16/04
      #5948860 - 06/30/13 11:11 PM
John,
Don:
That's how it seemed to me but consider this:
Imagine that you do have an eyepiece with coma. You also have a moderately fast Newtonian and a Paracorr. Now I believe that if the relationship between the Paracorr and the focal plane is not correct, then either too much negative coma is added or not enough negative coma is added. This would seem to depend on which side of the "proper relationship you are."
Now rather than adjusting the distance between the focal plane and the Paracorr so that it provides the appropriate amount of negative coma to correct only the mirror, you experimentally adjust the relationship between the Paracorr and the eyepiece so it minimizes the coma of the mirror + eyepiece.
Of course there are some assumptions about how the Paracorr works but it does seem at least plausible that the Paracorr could be adjusted to so that it adds more negative coma than is necessary to correct the mirror.
If that were the case, then correcting for coma in an eyepiece would seem to be possible.
Scanning4Comets
Markus
Reged: 12/26/04
Re: Unexpected viewing with the ES 24mm 68° [Re: Starman1]
      #5948869 - 06/30/13 11:16 PM
Dave:
What scope(s) are you seeing the field curvature with?
I own the 24mm Meade version of this eyepiece and I have used with a number of scopes, most quite fast. It's not a perfect performer in the NP-101 (101mm F/5.4 Petzval), there is some slight residual what I remember to be astigmatism, it's not a clean as the 31mm Nagler, but it is a very good performing eyepiece, there aren't many better.
I spent one evening comparing the 24 mm Meade SWA to my 20mm Type 2 Nagler in a 16 inch F/4.42 + Paracorr, it was close... it's a good eyepiece in a fast scope.
Jon,
I have owned the 28mm Meade SWA and also the 28mm ES 68. You'd think that both were similar performers. However, in my fast scope, the Meade 28mm SWA showed a lot less coma than the ES 68 which is quite similar. I found that weird.
There must be something quite different in the two brands, (ES 68 / Meade SWA Series).
Scanning4Comets
Markus
Reged: 12/26/04
      #6591190 - 06/19/14 04:59 PM
I've spent the past few weeks trying out all three AFOV offerings by ES in a 16" f/5 scope. Overall a pleasant experience, particularly with the 100° flavor.
The most unexpected finding was with the 24mm 68°, which seems to get mainly great reviews. While I'm usually tolerant of a bit of field curvature, I found this EP's FC to be very annoying.
I was constantly reaching for the focuser knob to alternate between sharp stars in the middle of the field and the periphery. It was impossible not to notice the extent of the field curvature.
The amount of adjustment required to alternate between on-axis and edge-of-field sharpness was surprising. Has anyone else experienced field curvature with this eyepiece?
Dave
After selling this very same eyepiece, I tried it again just last week...and the FC was extremely annoying! So, mine was not a bad sample either.
It IS there and it nearly drove me nuts, LOL!
I'm glad I was able to hand it back to the owner and not have to put it in my eyepiece case again!
I don't understand how someone can say they've "got rid of their 24mm Pan" in favor of this EP because as far as sharpness goes, the 24mm pan just kills it from center to edge. You can slice it, dice it, any way you like but there is no way that this eyepiece is anywhere near as good as the 24mm Pan in the sharpness dept in a fast reflector.
Dave Bush
Reged: 07/28/04
      #6591322 - 06/19/14 06:24 PM
I read this thread a while back when I was doing research on the ES eyepieces. I ended up getting one and so far, in my C8 at f/10 I see no more FC than any other eyepiece which tells me the FC is from the scope itself (to be expected).
With the f/6.3 RC, as with my other eyepices, the FC goes away (or at least to the point that I can't detect it anymore).
Perhaps there is variation with this one.
SteveG
Reged: 09/27/06
Loc: Seattle, WA
      #6592755 - 06/20/14 02:46 PM
Dave
I had and tested all (3); 24 Pan, 24 Meade SWA, 22 Pan. Yes the 24 Pan was the sharpest, and also had the shortest eye relief (no glasses or Dioptrx). I found the Meade to be much easier to use, with ample eye relief. I sold both Pan's.
Scanning4Comets
Markus
Reged: 12/26/04
Re: Unexpected viewing with the ES 24mm 68° new [Re: SteveG]
      #6592856 - 06/20/14 03:46 PM
Eyepiece performance is 100% scope dependent.
Starman1
Reged: 06/24/03
Loc: Los Angeles
      #6592875 - 06/20/14 03:54 PM
Well, that's an exaggeration. There are lots of eyepieces that perform quite well at f/6 and there are others that don't.
Let's just say that one of the factors influencing the performance of an eyepiece in the outer parts of the field is the f/ratio of the scope.
Given how different eyepieces appear in my f/12.8 Maksutov, and some f/15 refractors, though, I'm inclined to think that eyepiece design is also pretty important.
Eyepieces that are really poor performers at f/5 are usually less than perfect at f/8 too.
17 registered and 24 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, Scott in NC
