cliff mygatt
Reged: 01/27/09
Loc: Kitsap County, WA
Counter weight bolt new
      #5944482 - 06/28/13 09:49 AM
My grab and go mount, an EQ-3, counter weight bolt plastic head is broken and it is hard to adjust. I went to the hardware store and bought an M6 thumb screw but it is threaded all the way down and will not work. Does anyone know where a replacement screw can be purchased, it has a few m6 threads and then is smooth all the way to the end. Thanks for the help!
zippeee
Reged: 12/27/10
Loc: Alberta, Canada
Re: Counter weight bolt new [Re: cliff mygatt]
      #5944555 - 06/28/13 10:38 AM
Would it work if you just ground the threads off?
Jim Romanski
Reged: 01/02/05
Loc: Guilford, Connecticut
      #5944596 - 06/28/13 11:06 AM
I had to make my own counter-weight bolt once. I went to the hardware store and bought threaded rod and a T-Handle. The T-Handle was a nut with the plastic T-Handle part around it. I measured and cut the threaded rod to the proper length then used blue locktite when I threaded it into the T-Handle to keep it from unthreading on me. On the other end I intended to put a dot of epoxy on the end to prevent marring of the counter-weight shaft but I haven't gotten around to that yet.
cliff mygatt
Reged: 01/27/09
Re: Counter weight bolt new [Re: Jim Romanski]
      #5944763 - 06/28/13 01:05 PM
I suspect grinding the threads off would work but it should not be that hard to find a replacement, then again, sometimes we run into these issues in our hobby. Thanks for input so far.
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5950997 - 07/02/13 09:46 AM
Grinding can be done pretty accurately by chucking the bolt in a drill and spinning it agains the grinder's wheel, but many CWs have a short bit of smooth rod that goes in before the screw. I use mild steel welding rod to replace them. Comes in various diameters, less likely to mar the rod than harder stuff and I don't do that much stick welding anymore.
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: Counter weight bolt new [Re: Geo.]
      #5951037 - 07/02/13 10:16 AM
If you are anywhere near Bremerton give Tacoma Screw Products a try. They might have what you need.
don clement
Vendor (Clement Focuser)
Reged: 02/02/11
Loc: Running Springs, California
Re: Counter weight bolt [Re: CharlesW]
      #5951257 - 07/02/13 12:16 PM
I turned a slug for a CW bolt from Turcite rod. http://www.boedeker.com/turcax_p.htm Didn't attach the slug to the bolt, just put it in the hole between the bolt and CW. Self-lubricating Turcite, unlike Nylon or Delrin, gives very smooth adjustment.
Don Clement
8 registered and 17 anonymous users are browsing this forum.
Moderator:  cbwerner, tecmage, rflinn68
