Equipment Discussions >> Classic Telescopes
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
How can you tell if you have an early Astroscan
      #5951833 - 07/02/13 06:12 PM
I came across a Astroscan 2001, with a silver base, chrome focuser tube , and D rings on the strap , a sticker on the glass that states, "Edmund Scientific Company pat. pend." and a white oval sticker inside the focuser tower , with the number 2615 hand written in ink pen. Could this be one of the first 3000 made ?
Eric P
Reged: 04/04/05
Re: How can you tell if you have an early Astroscan new [Re: TOM KIEHL]
      #5951843 - 07/02/13 06:19 PM
Yes, that is the serial number. Welcome to the club!
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
Re: How can you tell if you have an early Astroscan new [Re: Eric P]
      #5951865 - 07/02/13 06:30 PM
Eric P, The chrome eyepiece focuser tube has a Aluminum ring with a brass thumb screw to hold the eyepiece in, and what appears to be a Barlow or some sort of corrector lens at the bottom of the chrome tube. My later Astroscan 2001 has none of this. Did the early ones come with a finder?
Eric P
Reged: 04/04/05
      #5952002 - 07/02/13 08:05 PM
hmmm ... That sounds like a modification by a previous owner. Can you post a pic? It would be interesting to see the mod.
The early ones did not.
Fred Janicke ('amicus sidera' on this forum) produced an excellent article on Edmund history including the Astroscan. Here is the link: http://www.classictelescopes.com/articles.html
Lew Chilton
Reged: 10/20/05
Loc: SoCal
      #5952408 - 07/03/13 01:39 AM
You can tell that it's an early one like mine - 1978 - because the primary mirror support has sagged causing a gross misalignment.
amicus sidera
Reged: 10/14/11
Loc: East of the Sun, West of the M...
Re: How can you tell if you have an early Astroscan new [Re: Lew Chilton]
      #5952658 - 07/03/13 08:11 AM
Thanks for the plug, Eric!
Tom, that sure is an early one, from 1976; is that base a shiny silver, or more a grey color? The earliest ones had grey bases before they went to tan. If yours is grey, and is original, that would mean that almost all of the Astroscan bases made in that first run of 3000 were that color, and that the changeover to tan occurred in early 1977. Any chane you could post a photo of the scope?
Lew, you probably are aware of this, but that miscollimation is almost certainly due to the deterioration of the foam pad that sits behind the primary and holds it in place against its retaining ring. My 1992-vintage Astroscan recently went out of collimation, and I used a piece of 1/2" charcoal-type camera case foam, cut to fit, to replace the old foam.This entailed the removal and replacement of the mirror; I'd done this before, but it's never a pleasant experience, and involves much frustration and accompanying colorful language The result, however, was a perfectly aligned mirror.
If one doesn't wish to go through all that, there's an easier fix for a sagging mirror: get hold of some of that camera case foam, and julienne-cut it into small strips, of a size that can fit through the screw hole on the bottom of the sphere... this should be done with the scope standing on end, so that the mirror is pulled by gravity into alignment against the ring that aligns and captivates it. This requires a bit of time and patience, but once enough of the little strips are up inside there, behind the mirror, they'll hold it in place. This won't be quite as stable as having a solid disc of foam inside, but it does work, and is nowhere near as nerve-fraying as the only other alternative.
It's also a good idea to add safety wires to the diagonal mirror and its support on these scopes; the glue used to hold them in place is getting pretty old. See this CN thread for information on using such safety wires; the pertinent section appears near the middle of the page.
Fred
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
Re: How can you tell if you have an early Astroscan new [Re: amicus sidera]
      #5952883 - 07/03/13 10:53 AM Attachment (18 downloads)
#1
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952887 - 07/03/13 10:54 AM Attachment (16 downloads)
#2
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952889 - 07/03/13 10:54 AM Attachment (17 downloads)
#3
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952890 - 07/03/13 10:55 AM Attachment (17 downloads)
#4
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952892 - 07/03/13 10:56 AM Attachment (16 downloads)
#5
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952894 - 07/03/13 10:58 AM Attachment (16 downloads)
#6
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952936 - 07/03/13 11:31 AM Attachment (11 downloads)
#7
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952939 - 07/03/13 11:32 AM Attachment (13 downloads)
#8
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952940 - 07/03/13 11:33 AM Attachment (15 downloads)
#9
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952941 - 07/03/13 11:34 AM Attachment (16 downloads)
#10
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952943 - 07/03/13 11:35 AM Attachment (17 downloads)
#11
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952945 - 07/03/13 11:36 AM Attachment (18 downloads)
#12
Eric P
Reged: 04/04/05
      #5952955 - 07/03/13 11:40 AM
Interesting! I have that lens component as well, but it arrived in the tube of a diagonal instead of the draw tube of the Astroscan. Possibly an early Edmund barlow? Looks like it would be difficult to remove from the tube once installed.
Dave M
Reged: 08/03/04
Loc: Ohio
      #5953242 - 07/03/13 02:26 PM
Tom, Nice pics
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
Re: How can you tell if you have an early Astroscan new [Re: Dave M]
      #5953265 - 07/03/13 02:36 PM
Tom, Nice pics
A Big Thank you , Oh most enlightened one.
Dave M
Reged: 08/03/04
Loc: Ohio
      #5953295 - 07/03/13 02:51 PM
Glad to be of Help!
amicus sidera
Reged: 10/14/11
      #5953348 - 07/03/13 03:27 PM Attachment (14 downloads)
Wonder if that base has been repainted; Eric, does that color match the grey base you have? It looks too silvery to me. Regardless, that definitely is a 1976-vintage Astroscan. Note that the accompanying book identifies it as "The Edmund Wide-Field Telescope", not Astroscan... it wouldn't receive that appellation until sometime in 1977.
I also have one of the old Edmund small-aperture Barlow lenses that was in your scope's eyepiece tube, Tom... as the photo below shows, it was in a cell that fit into an eyepiece tube. If used in a focuser tube, it would require one of the phenolic split rings shown to be placed around the cell. Due to the steep light cone that the Astroscan presents, this isn't the best Barlow lens to use with it; one with a clear aperture approaching 20mm or greater would perform better.
Fred
amicus sidera
Reged: 10/14/11
      #5953359 - 07/03/13 03:37 PM Attachment (18 downloads)
Here are two views of the foam pad that sits underneath the Astroscan's primary mirror; not too many folks have ever seen one, I'd wager! To its left in the first photo is the adhesive disc that attached it to the back of the mirror.
These pads are about 4" in diameter, just a little smaller around than the mirror itself, and 1/2" thick when new; the one shown has both compressed and deteriorated. The side view of the pad (propped up by a lime that was pressed into service ) shows approximately how much space is behind that mirror, in terms of both volume and shape.
Eric P
Reged: 04/04/05
      #5953500 - 07/03/13 05:15 PM
I would say so along with thorough sanding to remove the rough casting. It almost appears as if the cast contact spots were sanded down as well.
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5953552 - 07/03/13 05:47 PM
Eric , What is the production numbers on your astroscan?
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5953587 - 07/03/13 06:04 PM
The cast contact points are there, they are covered by larger red felt pads , your felt pads are smaller for some reason. I can't see any sanding marks and the paint is a thin even coat of silver with no overspray.
Eric P
Reged: 04/04/05
      #5953615 - 07/03/13 06:32 PM
I stand corrected then. Your base seems to have a smoother casting but it could just be the pic.
My Astroscan is #520
amicus sidera
Reged: 10/14/11
      #5953726 - 07/03/13 08:04 PM
So, the original grey on your base is a silvery-grey just like Tom's? I think I was too ambiguous with my questions...
Lew Chilton
Reged: 10/20/05
Loc: SoCal
      #5954224 - 07/04/13 01:51 AM
Thanks for the tip, Fred! I tried unsuccessully to remove the retaining ring holding the secondary support window, but I stopped when I thought I was going to bung it up. I'll try your 2nd method.
Thanks again,
Lew
amicus sidera
Reged: 10/14/11
      #5954692 - 07/04/13 12:34 PM
You're plenty welcome, Lew! That method has saved a few Astroscans from a trip back to the factory. Getting that front ring out is tricky, and if the foam-stuffing method works properly it's unnecessary, although it should be removed at some point to allow safety wires to be placed on that diagonal mirror and it's support.
Removing the ring that retains the primary mirror is pretty easy, it's the replacing that's very difficult. The easiest method I've used to get it back into place involved compressing the split ring and tying it across the widest part while compressed with unwaxed dental floss; then I'd drop it into place and verrrrrry carefully cut the floss with a knife - not the easiest thing to do one-handed, without being able to see what you're doing, and within an inch or so of a first-surface mirror! If I did it correctly, the ring (which, being steel, could easily sleek or scratch the mirror) would snap into place without incident and secure the mirror (all this has to be done wearing a clean white cotton glove on the working hand, otherwise the mirror will become very smudged)... Then, still one handed, push the mirror back into the foam to allow the retrieval of the floss ends from between the mirror and the now-captivated ring. Touch up any little smudges on the mirror, and done.
Not recommended for the manually impaired or faint of heart, unless one has a supply of spare mirrors...
Fred
amicus sidera
Reged: 10/14/11
      #5963118 - 07/09/13 10:29 PM
Just a note on that aluminum ring with the brass thumbscrew: that is a "focus locking collar"... this was part of a photography system sold early on by Edmund for the Astroscan, which included the generic Barlow lens (the RKE Barlow lens was used later), a T-mount with 1-1/4" adapter for a 35mm camera (one supplied their own T-ring for their specific brand of camera) and the focusing collar, the purpose of which was, once locked into position on the focusing tube, to keep the weight of the camera from pushing the tube into the telescope body while taking pictures, and thus inadvertantly changing the focus.
Fred
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5963143 - 07/09/13 10:40 PM
Well that answers that question ,,Mystery solved . thanks Fred........Tom
amicus sidera
Reged: 10/14/11
      #5963153 - 07/09/13 10:47 PM
My pleasure, Tom... and for the record, the early Astroscans didn't have a finder. Edmund started supplying them with the black sheet-metal peepsight finder sometime in the late 70's, to the best of my knowledge.
Fred
23 registered and 31 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
