scott50
Reged: 08/18/08
Loc: New York
Source for plywood circles new
      #5948202 - 06/30/13 03:05 PM
I don't have access to a router and have cut many plywood rings and circles for Dobsonian scopes using a hand saber saw. For me, it was a pain. They never came out perfect and required a lot of sanding. Not a big deal for the cage rings but more critical for side bearings. I just found a GREAT, INEXPENSIVE source for plywood circles: http://www.readytocover.com/round-table-tops-wood-table-top-unfinished.html
For my 17.5" project I ordered a 30" table top for the side bearings, which they cut into two perfect semi-circles at no extra charge. I also bought a 25" table top for my ground board. I'm going to lighten the side bearings by cutting out some unnecessary wood, but I won't have to do anything to the edge. The company "Ready to Cover" was very helpful, shipping was free & speedy, the quality of the 3/4" plywood was first-rate, and their prices were very inexpensive. For a modest fee, I saved a lot of frustration. I'll post pics in the coming month as my scope gets fleshed out.
PaulEK
Reged: 05/25/08
Loc: Wisconsin
Re: Source for plywood circles new [Re: scott50]
      #5948513 - 06/30/13 07:07 PM
It's great that they have such a wide, full spread of sizes; 12-48 inches in one-inch increments. I do have access to a router, and I find these tempting!
Thanks for this; it's bookmarked for me!
cpr1
Reged: 03/24/12
Loc: Louisiana
Re: Source for plywood circles new [Re: PaulEK]
      #5948529 - 06/30/13 07:17 PM
That is a interesting site for plywood circles. Little high considering the price of a 5x5 sheet of finnish birch. But if you don't have the router and circle jig I can see that it would be a great option. What is the shipping like?
Are you planning a traditional truss with a full sized mirror box? If so are you going to use 3/4 or 1 inch bearings?
gaz-in
Reged: 12/17/07
Re: Source for plywood circles new [Re: cpr1]
      #5948760 - 06/30/13 09:53 PM
"What is the shipping like?"
Site says free shipping...
Thanks OP...I think the price is inexpensive also...plan to order for my next DOB project...Thanks again for posting....
Edited by gaz-in (06/30/13 09:56 PM)
cpr1
Reged: 03/24/12
Loc: Louisiana
Re: Source for plywood circles new [Re: gaz-in]
      #5948778 - 06/30/13 10:08 PM
oops, I did not see that I was just looking at the price. Cool.
HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
      #5949532 - 07/01/13 12:02 PM
A 1/4" trim router can be had for $30.
A carbide bit will cost $10-$20.
A scrap of plywood and ten minutes work will produce an adjustable circle cutting jig.
It's the old "Give a man a fish..." philosophy. <g>
dan k.
davidpitre
Reged: 05/10/05
Loc: Central Texas
Re: Source for plywood circles new [Re: HunterofPhotons]
      #5950131 - 07/01/13 06:26 PM
Anyone know of someone who will cut and ship routed Birch custom UTA circles?
gaz-in
Reged: 12/17/07
Re: Source for plywood circles new [Re: davidpitre]
      #5950276 - 07/01/13 08:02 PM
I believe Dennis from Dobstuff will...
Chuck Hards
Reged: 05/03/10
Loc: The Great Basin
      #5950867 - 07/02/13 07:56 AM
When I first read the title of this thread, I thought "you have to find a plywood tree of just the right diameter".
Sorry, I'm a patternmaker. Wise-cracking pertaining to the job runs deep.
careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
      #5950955 - 07/02/13 09:21 AM
dan k.
To be fair I would also add some other costs to that - a good book on router safety and usage to start with, ~$17 on Amazon. A trim router is not a 2 hp beast, but cutting large disks of 3/4" plywood is still a big cutting job, and the cheap trim router will have only one speed (high - 30,000 RPM) and no soft start. When working with an exposed cutter like this being grounded in all the proper handling and safety practices is essential.
And there will likely be incidental expenses - e.g. a box of special screws to attach said trim router base to plywood scrap (the screws with the router base are probably not long enough), so throw in a total of another $20 on top of the router and bit.
Then he needs a work table where the large volumes of sawdust emitted by said router will not cause a problem - some have that, some don't.
Then you can assume one of two pieces of wasted material while getting the skills together to do it successfully, and the time.
If you will only need a couple of disks and you know and can order the exact sizes, then ordering them is likely the wiser choice.
Get a router if your longer term plans are more ambitious.
derangedhermit
Reged: 10/07/09
Loc: USA
      #5951960 - 07/02/13 07:36 PM
The site does not say it is Baltic birch, just birch.
derangedhermit
Reged: 10/07/09
Loc: USA
Re: Source for plywood circles new [Re: derangedhermit]
      #5952129 - 07/02/13 09:31 PM
Astrogoods/1stbase offers custom CNC baltic birch work. I haven't done business with them. I kinda like the looks of the small dob base kits.
It might help if someone could figure out a set of "stock" dimensions for rings so it wouldn't be such a huge waste of plywood and someone could carry rings as stock parts.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
Re: Source for plywood circles [Re: Chuck Hards]
      #5952497 - 07/03/13 03:46 AM
davidpitre
Reged: 05/10/05
Loc: Central Texas
      #5954451 - 07/04/13 08:31 AM
I had a dob mount made by them. It was poor quality, a poor design, hardly sealed at all,and non functional until I put a lot of work in to it.
derangedhermit
Reged: 10/07/09
Loc: USA
      #5955749 - 07/05/13 09:27 AM
David, I'm sorry to hear that, but I guess it's good to know.
- Lee
scott50
Reged: 08/18/08
Loc: New York
      #5957732 - 07/06/13 03:21 PM
I received the circles in NY within 3 days. Great service
kfrederick
Reged: 02/01/08
      #5957744 - 07/06/13 03:34 PM
I can get aluminum rings water jet cut should not be much
kfrederick
Reged: 02/01/08
Re: Source for plywood circles new [Re: kfrederick]
      #5957749 - 07/06/13 03:37 PM
What size ?
calypsob
Reged: 04/20/13
      #5966606 - 07/11/13 11:57 PM
Yah know this is kind of crazy but I found out a few years ago that you can cut perfect circles on a table saw, big circles, at that. http://www.youtube.com/watch?v=23kkZZN1ACs
StarStuff1
Reged: 04/01/07
Re: Source for plywood circles new [Re: calypsob]
      #5966637 - 07/12/13 12:18 AM Attachment (12 downloads)
Been doin' that for years. Makes a lot of sawdust but works great. For some reason I prefer the table saw to a router for large discs of plywood.
Here is just one made 7 years ago to be a center tray/eyepiece holder for a tripod.
1 registered and 18 anonymous users are browsing this forum.
