hungerford
Reged: 08/23/08
Cateye Autocollimator new
      #5912368 - 06/10/13 01:49 AM
I have invested in an autocollimator but unfortunately I am a little bit dim and I cannot understand and the various guide I found on the net don't help me.
Can anyone point me in the direction of a tutorial for beginners.
Thank you
Vince
Jason D
Reged: 10/21/06
Loc: California
Re: Cateye Autocollimator new [Re: hungerford]
      #5912374 - 06/10/13 01:53 AM
Did you get the Infinity XL or the XLK?
Did you attempt to follow Catseye provided steps? If yes, which steps sounded confusing to you?
Can you tell me how you are currently using it -- the steps your are following.
Jason
rlmxracer
Reged: 11/09/11
Loc: Motocross Mecca , CA
Re: Cateye Autocollimator new [Re: Jason D]
      #5912399 - 06/10/13 02:13 AM
Try this video http://youtu.be/Vj12cx3tnsM
I had to watch it a few times and then it all clicked. I have the 2 pupil XLK. I actually use the method they show at the end of the vidio in which I use the offset pupil and a 2" cheshire.
hungerford
Reged: 08/23/08
Re: Cateye Autocollimator new [Re: rlmxracer]
      #5913152 - 06/10/13 01:51 PM
Thank you for the info. I am at present using a friend XLK collimator as I was so impressed with the collimation of his scope. Unfortunately at present he has gone on holidays for a month so I can't pick his brain. My XLK is on order.
What is confusing to me is that I find it difficult to identified what the reflections are and end up trying to stack the wrong reflection.
I started using a Cheshire eyepiece to do a quick collimation.
I then use a Farpoint 2" laser to make the collimation better.
Then I use the autocollimator and I get thing wrong as stated earlier.
If I try to image after the auto collimation the star are elongated and show a lot of coma.
I am sure it is me not doing the right thing.
Vince
Edited by hungerford (06/10/13 02:03 PM)
Jason D
Reged: 10/21/06
Loc: California
      #5913563 - 06/10/13 04:48 PM
I still need more info.
What is the aperture size and focal length of your scope?
What kind of center spot you are using?
Can you take a photo from both XLK pupils and upload them into this thread?
Jason
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
      #5913722 - 06/10/13 06:21 PM
Try reading the part of this about the autocollimator to see if it makes sense. Note the illustrations:
http://www.cloudynights.com/item.php?item_id=2677
You can also drop me a message on CN if you have a specific question.
FirstSight
Duke of Deneb
Reged: 12/26/05
Loc: Raleigh, NC
Re: Cateye Autocollimator new [Re: Starman1]
      #5915278 - 06/11/13 03:34 PM
The autocollimator is seemingly bewilderingly confusing at first, but though learning what the various multiple reflections actually are is worthwhile (and a bit complicated)...the ESSENCE of what you're trying to do is stunningly simple: tweak the secondary adjustment screws until ALL the other center-spot reflections merge and disappear behind the brightest one (which is the direct single-pass image of the center spot rather than a multiple-pass reflection of the center spot like the fainter ones are). Once you succeed at this, you're not quite done: recheck your primary's alignment with your cheshire. If (as is more likely) tweaking the secondary to satisfy the autocollimator has nudged the primary alignment off a bit, adjust the primary back into alignment using the cheshire and then repeat tweaking the secondary with the autocollimator. Two or three iterations back and forth will, most of the time, be sufficient to get cheshire and autocollimator to agree.
BTW: don't overly obsess at first on trying to make all the fainter reflections *perfectly* disappear, as opposed to being content with a tiny sliver of one peeking out from the main reflection; you'll find that even a slight tweaking of the thumbscrew adjusting how tight the autocollimator is held in the focuser will quite noticeably change how the reflections stack (or don't). Your ultimate goal is to try to make 'em entirely disappear, but don't let the absolutely perfect be the enemy of the very good here.
YES, there is an alternative method called the "carefully decollimated primary" procedure which short-cuts this iterative process, but while this alternative procedure (invented an popularized by collimation guru Vic Menard) is definitely worth *eventually* learning, LEARN THE ITERATIVE PROCESS FIRST, because the goals of the two key iterative steps are so straightforwardly simple that you're less likely to get confused.
In short, focus FIRST on what simple thing you need to accomplish with each of the two key iterative steps, and THEN that successfully accomplished, it will become much easier to understand *what* each step is actually doing, and then subsequently, to learn the alternative "carefully decollimated primary" procedure.
Edited by FirstSight (06/12/13 01:05 AM)
UmaDog
Reged: 09/15/10
Loc: Long Island, NY
Re: Cateye Autocollimator new [Re: FirstSight]
      #5916040 - 06/11/13 11:01 PM
I second the iterative method. It works very well and is simple to learn. In fact, I find it sufficiently convenient that I've not bothered with the CDP method.
rlmxracer
Reged: 11/09/11
Re: Cateye Autocollimator new [Re: UmaDog]
      #5916111 - 06/11/13 11:48 PM
X2, my issue w/ the CDP is two fold. 1.My mirror needs a recoat and the area around the center spot has a small bit of residue that I can't get off. That makes it hard for me to precisely stack the images.
2. I also find it difficult to figure out which primary adjustment screw to turn because I can't look through the center pupil and adjust the screw at the same time. When I use my cheshire to adjust the primary it is more obvious because I'm only dealing with one reflection.
Jason D
Reged: 10/21/06
Loc: California
      #5916134 - 06/12/13 12:04 AM Attachment (10 downloads)
my issue w/ the CDP is two fold... I also find it difficult to figure out which primary adjustment screw
CDP is meant for the secondary mirror. You are not suppose to adjust the primary mirror to stack reflections P&3 but rather only the secondary mirror set screws. See attachment.
rlmxracer
Reged: 11/09/11
      #5916147 - 06/12/13 12:12 AM
Sorry I wasn't clear my bad. It is after this step when you recolimate the primary I have a dificult time. Thanks Jason.
Jason D
Reged: 10/21/06
Loc: California
      #5916175 - 06/12/13 12:38 AM Attachment (8 downloads)
If you have the triangle or the Hotspot center spot then it makes it easier to figure out which knob to use providing each corner of the triangle/Hotspot is pointing towards a primary adjustment screw.
Jason
rlmxracer
Reged: 11/09/11
      #5916193 - 06/12/13 01:02 AM
Jason
I have a Hotspot and as with the above pic it is easy for me with the cheshire (single reflection). It is just the final stacking of mulitple images I cant seem to get the stacked perfectly. In part it's due to the small bit of haze around my center spot and the fact that I can't watch the reflections as I'm recollimating the primary (arms arent long enough lol).
Jason D
Reged: 10/21/06
Loc: California
      #5916286 - 06/12/13 02:52 AM
With the XLK, you iterate between the stacking of P+2 from the offset pupil and the Blackcat cheshire -- in case you select not to use CDP. Checking the stacking of P+1 from the central pupil is only meant for final confirmation.
hungerford
Reged: 08/23/08
      #5918434 - 06/13/13 09:45 AM
Thank you very much for your help.
I think I must learn to identify all the reflection properly and then use it.
Vince
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #5918518 - 06/13/13 10:51 AM
I understand just a little. No comprende it's a riddle. David
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
      #5918587 - 06/13/13 11:45 AM
This is exactly how I collimate my Newts. The result is very close collimation, especially advantageous for planet/lunar observation, but I also notice improvement in sharpness and contrast for DSO.
hungerford
Reged: 08/23/08
Re: Cateye Autocollimator [Re: Sarkikos]
      #5952511 - 07/03/13 04:16 AM
I now understand the Cateye collimator unfortunately the secondary holder is giving me some problems.
Basically it is of poor quality and when I try to adjust it, it jumps and I cannot get a good collimation of the secondary.
Any idea what can be done to remedy this problem.
The scope is a GSO 10".
Thank you for your help.
Vince
panhard
It's All Good
Reged: 01/20/08
Loc: Markham Ontario Canada
      #5952620 - 07/03/13 07:30 AM
Cut out the side of a plastic milk container, to make 2 washers. Insert them next to the secondary holder. That way the small screws act on the washers not the rear of the secondary holder. You will need a hole for the centre screw to go through. Then reassemble everything, do this with the tube horizontal so nothing hits the primary mirror. It sounds like you have put dents in the rear of the secondary holder.
maakhand
Reged: 09/15/09
Loc: florida, usa
      #5952910 - 07/03/13 11:09 AM
the trick i use to collimate my Z10 is that i sit on my denvar chair, look through autocollimator/cheshire, swing the focuser end of tube from me so the primary end of tube reaches my extended right hand, half a turn on a screw, pushing bottom end away so focuser end reaches my left hand, peek through focuser and so on
14 registered and 27 anonymous users are browsing this forum.
