AndreyYa
Reged: 12/05/06
Loc: Sunnyvale, CA
Re: Mach1 Remesh new [Re: blueman]
      #5952506 - 07/03/13 04:01 AM Attachment (8 downloads)
Gents, thank you for your comments and answers.
Just to make things clear: I'm happy with current tracking performance of my Mach1. These numbers are hardly possible with Atlas or Sirius: having 0.25'" RMS error for 7 sec guiding exposures. I'm just afraid it will be not enough for 1000-1500mm FL.
I'm still not familiar with PemPro. I analyzed tracking log with PecPrep and didn't see there any suspicious signs. Just in case please see attached PecPrep chart for guided tracking (510mm FL, QHY5, guiding exposure 7 sec). But... it explains nothing regarding DEC tracking.
Edited by AndreyYa (07/03/13 04:08 AM)
AndreyYa
Reged: 12/05/06
Loc: Sunnyvale, CA
Re: Mach1 Remesh new [Re: AndreyYa]
      #5952510 - 07/03/13 04:11 AM Attachment (8 downloads)
And unguided tracking looks nice as well - about 5" p-p periodics.
Edited by AndreyYa (07/03/13 04:11 AM)
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Mach1 Remesh [Re: AndreyYa]
      #5952534 - 07/03/13 05:01 AM
It will be enough. My RMS guiding on my Mach1 is about 0.5" and I successfully was able to do 5- and 10-minute exposures of Cleopatra's Eye and the Eskimo at 2350mm, and 2 minutes on Cleo with a 2X barlow (e.g. 4700mm). This was using a C9.25 so about 30lb of payload and a QHY8, so the pixel scale was 0.68" (at native FL) and 0.34" barlowed.
My RMS guiding never gets better than 0.5" to 0.6" - I think it's the seeing.
Cleo's Eye at 4700mm @ 2 minute subs
Eskimo @ 2350mm
These aren't particularly good images, took them from my balcony with mag 3 skies (!!!) and I didn't use an OAG, just a Meade 60mm f/9 as a guide scope.
AndreyYa
Reged: 12/05/06
Loc: Sunnyvale, CA
Re: Mach1 Remesh new [Re: orlyandico]
      #5953475 - 07/03/13 05:01 PM
Thank you Orlyandico.
I'll check guiding capabilities for longer focal length with my Mak-Cass, I expect to have about 1200mm FL with reducer.
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
      #5953868 - 07/03/13 09:35 PM
This all looks pretty good really. 5" PE is good, my AP900 is 6-7" and I image at 740mm and 980mm with great looking stars.
I am sure it could handle long f/l with out a problem.
But as I said before, it is possible that conditions could still be an issue.
Blueman
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5953922 - 07/03/13 10:05 PM
Mine is either 5" or 7" depending on whether it's east heavy or west heavy. In both cases PEM knocks it down below 1". I don't think AndreyYa would have any trouble whatsoever at 1200mm.. that's the reason people buy these mounts, so you don't worry about pedestrian concerns like these
AndreyYa
Reged: 12/05/06
Loc: Sunnyvale, CA
      #5956195 - 07/05/13 02:45 PM
Last session demonstrated that DEC problems disappear when I'll do less precise Polar Alignment.
Scott99
Reged: 05/10/07
Loc: New England
Re: Mach1 Remesh new [Re: Calypte]
      #5957460 - 07/06/13 12:30 PM
Really, anyone with an issue concerning an A-P mount, especially a new one, should call A-P. Part of the reason you paid all that money for Astro-Physics is their exemplary customer service. Use it! As for the DEC gear mesh, in 3 years of owning a Mach1GTO, I've never had to touch the DEC gears.
same here, it would be surprising for a mount shipped from AP to need it. However, I have had to do this for Tak and AP mounts that I purchased used.
No need to be afraid of this, it's easy. You'll notice if the mesh is too loose - turning the counterweight shaft back & forth as described above is an easy way to test it. If it's too loose, just tighten by very slight amounts, keep turning the shaft a bit and you'll feel backlash being taken up.
18 registered and 27 anonymous users are browsing this forum.
