Equipment Discussions >> Classic Telescopes
terraclarke
Reged: 05/29/12
Loc: Just South of the Mason-Dixon ...
Vixen Polaris RA Drive question
      #5952722 - 07/03/13 09:01 AM
Does anyone know if the Vixen Great Polaris RA drive and clutch will work on an original (black 1980s) Vixen Polaris drive? My Vixen Polaris drive has the tapped hole on the right side do the drive housing for a RA drive bracket just like my late model Celestron Omni CG4 drive. The Vixen Polaris uses a 144 tooth gear for the RA drive axis. I used to have a Vixen Great Polaris mount (mint green version) but I sold it 8 years ago and all I remember was that the drive went into a little box on the drive housing, I don't remember if it had a mounting bracket. It's my understanding that the gear ratio has remained the same throughout all three versions of the Vixen mount (VP, SP, AND GP).
Thanks much,
rolo
Reged: 01/14/07
Loc: GA, USA
Re: Vixen Polaris RA Drive question new [Re: terraclarke]
      #5952828 - 07/03/13 10:14 AM
Terra, the Vixen GP & SP can share the same MT1 motors but they will not work on the Polaris mount. The gears are the same 144 teeth but that's where the similarities end...
terraclarke
Reged: 05/29/12
Re: Vixen Polaris RA Drive question new [Re: rolo]
      #5952898 - 07/03/13 10:59 AM
Thanks Rolo. I heard somewhere that the Orion Eq-3 RA drive will work. Perhaps I will look further into that.
Terra
Bill Griffith
Reged: 08/12/09
Loc: Ca.
      #5955021 - 07/04/13 05:07 PM Attachment (21 downloads)
Terra,
I machined an aluminum block to accept an Orion #7832 True Track R.A. motor drive to an SP.
My opinion is the drive is adequate vs cost even if the dec. drive is never used.
Someday I'll fabricate the dec. motor as well.
I've built a few for others and sent the dimensions to a few to build their own. The feedback was positive.
The cost of the True Track dual axis is less than other alternatives investigated.
Bill
Bill Griffith
Reged: 08/12/09
Loc: Ca.
Re: Vixen Polaris RA Drive question new [Re: Bill Griffith]
      #5955023 - 07/04/13 05:10 PM Attachment (21 downloads)
2
Bill Griffith
Reged: 08/12/09
Loc: Ca.
      #5955028 - 07/04/13 05:15 PM Attachment (17 downloads)
3
terraclarke
Reged: 05/29/12
      #5955046 - 07/04/13 05:33 PM
That certainly looks like a viable option Bill. I like the way that it has a clutch. The Orion EQ3 option does not. I will look into your design further. Thanks.
Chassetter
Reged: 07/08/09
Loc: New Brunswick, Canada
      #5955208 - 07/04/13 07:50 PM
EQ3 dual axis drive with hand controller and battery case on CN here
Brian RisleyModerator
Reged: 09/04/06
Loc: SW Florida
Re: Vixen Polaris RA Drive question new [Re: Chassetter]
      #5955238 - 07/04/13 08:28 PM
Just to keep everyone straight here, Terra appears to be talking about the original Polaris mount, not the Super/Great Polaris series which mounted drives in a different manner.
I know the Dec mounting is completely different, and from the pictures and manuals I have seen, so is the RA. There is no position to mount the motor on the mount below the worm, the only motor mount has to connect with the shaft extending away from the mount.
Brian
orion61
Reged: 10/20/07
Loc: Birthplace James T Kirk
      #5955251 - 07/04/13 08:39 PM
I have an Orion SA drive from the EQ1 mount it mounts on the Right (from front) side I had it on my SP Vixen but it tracked a bit slow but it tracked steady. PM Me!
I wonder if there is a Pot you can tweek the speed?? havent checked that far.
I hope you find a drive.
Edited by BRisley (07/04/13 10:14 PM)
Bill Griffith
Reged: 08/12/09
Loc: Ca.
Re: Vixen Polaris RA Drive question new [Re: Brian Risley]
      #5955751 - 07/05/13 09:28 AM Attachment (14 downloads)
Terra,everyone,
My apologies for misreading the original post.
The Orion#7829 EQ-3M Single axis bolts right to a Vixen Polaris mount.
The Vixen MD-5 that were original to the mount will interface fine to the Orion motor. The Orion controller interfaces with the Vixen motor as well.
That said, there is a DC voltage step up with a MD-5 of 3 volts DC. The Orion # 7829 is 6 volts DC.
I will confirm sidereal.
The drive systems appear to mount identically although the Vixen bracket is slightly heavier gauge metal and the motor has (in my opinion) a smoother pulse.
The motors are offset from the EQ mount by a significant amount. I have installed a counterweight (dummy shaft) that is attached on the opposite side of the mount on the worm shaft. This eliminates a slight imbalance on the mount.
Clear Skies
Bill
Edited by Bill Griffith (07/07/13 06:08 PM)
terraclarke
Reged: 05/29/12
      #5955830 - 07/05/13 10:29 AM
Yes, mine is exactly like what is shown in your last pic Bill. There is a drive bracket tapped hole on the right side of the drive housing and it looks like the drive would have to go directly on the slo-mo axle just like on my CG4 mount. It wish it were otherwise and would use a geared clutch like my great Polaris did but this is the older Polaris. I am only interested in the RA drive so the Orion EQ 3 drive would be the only easy solution. It's fairly cheap too at around 80 bucks.
Astrosetz
Reged: 10/05/03
Loc: Wisconsin
      #5955913 - 07/05/13 11:07 AM
For my Polaris mount, I use an inexpensive Celestron "Logic Drive" that can be had on eBay for about $20 to $30 bucks. It adds solid tracking to my Celestron C4.5
terraclarke
Reged: 05/29/12
Re: Vixen Polaris RA Drive question new [Re: Astrosetz]
      #5955940 - 07/05/13 11:24 AM
Hi Bill, do you or anyone else have a solution to a converter for my 12V power supply outputting a 6V stream to the 6V drive rather than using the 4 D-cell battery pack? I am going with the EQ3 drive as I like the hand drive controller and the 8X slo-slew.
Terra
Bill Griffith
Reged: 08/12/09
Loc: Ca.
      #5956031 - 07/05/13 12:31 PM Attachment (10 downloads)
Hi Terra,
I would guess a small DC transformer or resistor would work.
Sorry, that's not much help!
But...
Surprisingly, the Orion battery pack with soft case and strap hangs conveniently between the Polaris tray and the leg on the attachment and just stays there.
The Polaris mount is the grab and go for about 4 different OTAs.
Consequently, It is used almost every clear night so it stays setup in the family room.
I get many many hours out of the battery pack and just use rechargeable D cells.
Bill
Edited by Bill Griffith (07/05/13 01:12 PM)
terraclarke
Reged: 05/29/12
      #5956534 - 07/05/13 06:30 PM
Then I will go with that then Bill. I have a similar battery pack to power my Omni CG4 duel axis drives and that one last a surprisingly long time. I just thought it would be nice to use the big rechargeable power supply as an alternative. My Vixen Polaris has my 76 x1218 mm "Jaegertron" on it and remains set up in a corner of the telescope room/dining room where it is easy to carry it out through the kitchen door to the deck.
terraclarke
Reged: 05/29/12
      #5956544 - 07/05/13 06:37 PM Attachment (15 downloads)
Here's the 'Jaegertron' on its vintage Vixen Polaris mount in the corner of the room. Interestingly, this scope seems bigger than the AstroTelescopes 4 inch F11 behind it. A 4 inch Unitron would dwarf the room.
terraclarke
Reged: 05/29/12
      #5956553 - 07/05/13 06:42 PM Attachment (14 downloads)
The Vixen Polaris mount. The tapped hole for the RA drive bracket is on this side of the housing.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
      #5957070 - 07/06/13 03:03 AM
>a converter for my 12V power supply outputting a 6V stream to the 6V drive <<
I use a car audio converter, it can select 12, 9, 6 or 3 volts output. It plugs into a cigar socket and has various output plugs, cost about £5 iirc.
http://www.choiceful.com/categories/productdetail/1863?utm_source=google&...
I found mine in Maplins (UK), I imagine Radio shack would have them?
turk123
Reged: 07/09/10
Loc: N.E. Ohio
Re: Vixen Polaris RA Drive question new [Re: John Carruthers]
      #5957194 - 07/06/13 08:36 AM
Terra, I have several mounts using a battery pack including a great Polaris. Go with the battery pack. My hand controller flashes when batteries are low. Uses "c" cells and lasts a year. Why even think of a cord?
4 registered and 13 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
