Equipment Discussions >> Classic Telescopes
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
How can you tell if you have an early Astroscan new
      #5951833 - 07/02/13 06:12 PM
I came across a Astroscan 2001, with a silver base, chrome focuser tube , and D rings on the strap , a sticker on the glass that states, "Edmund Scientific Company pat. pend." and a white oval sticker inside the focuser tower , with the number 2615 hand written in ink pen. Could this be one of the first 3000 made ?
Eric P
Reged: 04/04/05
Re: How can you tell if you have an early Astroscan new [Re: TOM KIEHL]
      #5951843 - 07/02/13 06:19 PM
Yes, that is the serial number. Welcome to the club!
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
Re: How can you tell if you have an early Astroscan new [Re: Eric P]
      #5951865 - 07/02/13 06:30 PM
Eric P, The chrome eyepiece focuser tube has a Aluminum ring with a brass thumb screw to hold the eyepiece in, and what appears to be a Barlow or some sort of corrector lens at the bottom of the chrome tube. My later Astroscan 2001 has none of this. Did the early ones come with a finder?
Eric P
Reged: 04/04/05
      #5952002 - 07/02/13 08:05 PM
hmmm ... That sounds like a modification by a previous owner. Can you post a pic? It would be interesting to see the mod.
The early ones did not.
Fred Janicke ('amicus sidera' on this forum) produced an excellent article on Edmund history including the Astroscan. Here is the link: http://www.classictelescopes.com/articles.html
Lew Chilton
Reged: 10/20/05
Loc: SoCal
      #5952408 - 07/03/13 01:39 AM
You can tell that it's an early one like mine - 1978 - because the primary mirror support has sagged causing a gross misalignment.
amicus sidera
Reged: 10/14/11
Loc: East of the Sun, West of the M...
Re: How can you tell if you have an early Astroscan new [Re: Lew Chilton]
      #5952658 - 07/03/13 08:11 AM
Thanks for the plug, Eric!
Tom, that sure is an early one, from 1976; is that base a shiny silver, or more a grey color? The earliest ones had grey bases before they went to tan. If yours is grey, and is original, that would mean that almost all of the Astroscan bases made in that first run of 3000 were that color, and that the changeover to tan occurred in early 1977. Any chane you could post a photo of the scope?
Lew, you probably are aware of this, but that miscollimation is almost certainly due to the deterioration of the foam pad that sits behind the primary and holds it in place against its retaining ring. My 1992-vintage Astroscan recently went out of collimation, and I used a piece of 1/2" charcoal-type camera case foam, cut to fit, to replace the old foam.This entailed the removal and replacement of the mirror; I'd done this before, but it's never a pleasant experience, and involves much frustration and accompanying colorful language The result, however, was a perfectly aligned mirror.
If one doesn't wish to go through all that, there's an easier fix for a sagging mirror: get hold of some of that camera case foam, and julienne-cut it into small strips, of a size that can fit through the screw hole on the bottom of the sphere... this should be done with the scope standing on end, so that the mirror is pulled by gravity into alignment against the ring that aligns and captivates it. This requires a bit of time and patience, but once enough of the little strips are up inside there, behind the mirror, they'll hold it in place. This won't be quite as stable as having a solid disc of foam inside, but it does work, and is nowhere near as nerve-fraying as the only other alternative.
It's also a good idea to add safety wires to the diagonal mirror and its support on these scopes; the glue used to hold them in place is getting pretty old. See this CN thread for information on using such safety wires; the pertinent section appears near the middle of the page.
Fred
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
Re: How can you tell if you have an early Astroscan new [Re: amicus sidera]
      #5952883 - 07/03/13 10:53 AM Attachment (25 downloads)
#1
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952887 - 07/03/13 10:54 AM Attachment (21 downloads)
#2
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952889 - 07/03/13 10:54 AM Attachment (20 downloads)
#3
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952890 - 07/03/13 10:55 AM Attachment (20 downloads)
#4
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952892 - 07/03/13 10:56 AM Attachment (21 downloads)
#5
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952894 - 07/03/13 10:58 AM Attachment (19 downloads)
#6
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952936 - 07/03/13 11:31 AM Attachment (12 downloads)
#7
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952939 - 07/03/13 11:32 AM Attachment (16 downloads)
#8
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952940 - 07/03/13 11:33 AM Attachment (18 downloads)
#9
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952941 - 07/03/13 11:34 AM Attachment (17 downloads)
#10
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952943 - 07/03/13 11:35 AM Attachment (19 downloads)
#11
TOM KIEHL
Reged: 11/17/12
Loc: N.E. Ohio
      #5952945 - 07/03/13 11:36 AM Attachment (21 downloads)
#12
Eric P
Reged: 04/04/05
Re: How can you tell if you have an early Astroscan [Re: TOM KIEHL]
      #5952955 - 07/03/13 11:40 AM
Interesting! I have that lens component as well, but it arrived in the tube of a diagonal instead of the draw tube of the Astroscan. Possibly an early Edmund barlow? Looks like it would be difficult to remove from the tube once installed.
Dave M
Reged: 08/03/04
Loc: Ohio
      #5953242 - 07/03/13 02:26 PM
Tom, Nice pics
24 registered and 24 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
