EyeSage
Reged: 06/08/12
Loc: Canukistan
Adapting old mount for autoguiding new
      #5955284 - 07/04/13 09:34 PM
As the EQ6 I've been coveting isn't likely to be in the budget for a while I am currently modding my old Meade Starfinder mount in hopes of making it suck a little less for astrophotography. The model I have uses an AC synchronous motor driving it in RA and have a servo motor giving me slow motion on the dec. axis. My great hope is to be able to adapt it to enable me to use an autoguider. I would think this should be doable but haven't been able to find the technical details that would apply for a setup like mine.
Currently I use a standard 555 based inverter circuit with push button speed controls for the RA motor and a simple DPDS toggle switch to trigger the dec. motor with alternate polarity. I have been to the Shoestring Astronomy site and it looks like their EQ kit might work but would need to be wired differently in my case. Is there anyone who could point me towards how a setup like mine would need to be wired to make it ASCOM compatible? Alternatively I'm open to making changes like swapping motors if this could be made to work.
Iver
Reged: 10/12/07
Loc: Monterey County,Ca.
Re: Adapting old mount for autoguiding new [Re: EyeSage]
      #5955317 - 07/04/13 10:15 PM
Joe, here are two links to some info. from Shoestring Astronomy that may help.
http://www.store.shoestringastronomy.com/downloads/HCModGuidance.pdf
http://www.store.shoestringastronomy.com/eq_mod.pdf
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: Adapting old mount for autoguiding new [Re: Iver]
      #5955341 - 07/04/13 10:32 PM
The easiest solution would be to pick up an old drive corrector with guide inputs.
Don't worry about ASCOM compatibility; that's a communications protocol and has nothing to do with autoguide ports (they don't communicate).
EyeSage
Reged: 06/08/12
Loc: Canukistan
Re: Adapting old mount for autoguiding [Re: Iver]
      #5955428 - 07/05/13 12:04 AM
Thanks Iver,
The EQ mod I've seen before but the handcontroller mod guide might be just what I need.
16 registered and 37 anonymous users are browsing this forum.
