Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: C11 on an Atlas??? new [Re: dragonslayer1]
      #5958811 - 07/07/13 11:55 AM
The only "pretty picture" astrophotography I do is DSLR on my Kenko Skymemo. You have an Astrotrac. You can spend years with such a setup using lenses 200mm and less and there are scores of good targets on which to perfect your skills. I have never, ever, tried a 500mm on my Kenko and I am betting that my Kenko set on a Losmandy G-11 tripod is more stable than your astrotrac. I have used a 300mm which is pushing even my rig.
Save yourself frustration, enjoy wide-field imaging for now, which can include some interesting variable work with a DSLR: see the Citizen Skies initiative. Google Citizen Sky.
Ed
BTW I do photometry, but not with my C11, I use my SN8" with my ST402ME and photometric filters. Much easier on the tracking. Watch out for hyperstar: AAVSO suggests that it is not good for variable work. (No, I do not wish to debate this, just passing on information I have read.)
Also, I feel that my C11 on a Losmandy G11 is pushing the limits for what I use it for: high resolution imaging with a webcam. I don't know much about the Atlas but I would not load it more than 50% capacity if you wish to do astrophotography through the OTA.
wz2
Most Boring Astronomer...
Reged: 07/30/10
Re: C11 on an Atlas??? new [Re: orlyandico]
      #5958849 - 07/07/13 12:24 PM
Jmandell,
Have you thought about a good, short focal length refractor? If your budget allows maybe one of the 4 element designs specifically intended for imaging. Light weight so not so hard on the mount. And you don't necessarily need real long subs with a faster instrument. People get great shots even using 60mm instruments.
Chris
Reged: 07/06/07
      #5959514 - 07/07/13 07:56 PM
Uncle Rod, I have given your statement a lot of thought. And I don't have a good theory to explain your findings. I can say though that the vignetting is very strong even on DX / APS-C sensor, in my experience.
I can't speak to every setup and every sky condition, but a flat field or just Gradient Xterminator will take care of this kind of problem and you really should be doing flats anyway.
I used to love to shoot widefield with my ST2000 and a fracking Meade 3.3 reducer. Vignetting? Hell, it looked like you were looking through a freaking porthole.
A good flat applied, and poof, gone.
Edited by rmollise (07/07/13 07:59 PM)
jmandell
Reged: 06/15/11
Re: C11 on an Atlas??? new [Re: rmollise]
      #5959702 - 07/07/13 10:07 PM
Taking the advice from everyone, I think that I will go with an atlas and a shorter focal length scope with my dslr, then move onto a CDC and bigger scope latter.
The two that I've been looking at are the at6rc and the at65edq. I chose these two because they seem to be very good based on the reviews and they are cheap enough so that I won't have to sell my 12"
jmandell
Reged: 06/15/11
Re: C11 on an Atlas??? new [Re: Ed Wiley]
      #5959711 - 07/07/13 10:12 PM
Ed
I would not recommend a 500mm on an astrotrac! Our lens is a 60's era Nikon mirror lens and it causes all kinds of problems (strange vignette, donut bokeh, etc.). If your alignment is off by a fraction of an inch, then everything is *BLEEP*
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
Re: C11 on an Atlas??? new [Re: jmandell]
      #5959818 - 07/07/13 11:21 PM
Go with the AT65EDQ in that case. The AT6RC while lighter is still a difficult scope at f/9 and some people really struggle with it, particularly if there is a collimation issue. I think that the EDQ also has a better focuser.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: C11 on an Atlas??? [Re: EFT]
      #5959932 - 07/08/13 01:24 AM
An imaging newtonian like the AT6IN would be faster and cheaper than the AT65EDQ, at the expense of needing a coma corrector and having fiddly collimation. A short fast APO is really the best first choice.
However.. I find myself wanting a longer-focal length instrument that isn't too slow (i.e. an SCT or RC is out) and the imaging newtonians give you that.
29 registered and 45 anonymous users are browsing this forum.
