Daniel Mounsey
Vendor (Woodland Hills)
Reged: 06/12/02
New StarGuy soft cases are here! new
      #5917571 - 06/12/13 07:29 PM Attachment (69 downloads)
The new StarGuy cases have finally arrived and are currently available for shipment in three sizes. Depending on what size your optical tube is, it would be wise to take measurements of your existing OTA.
Model (SGC650) can accommodate most refractors up to 103mm and includes three interior wall dividers which can be configured to your preference. It also allows some room for additional accessories including a finder and includes luggage wheels.
Interior dimensions 31.8" x 10" x 8"
Exterior dimensions 32.8" x 11" x 9"
Weight 8.25 lbs
Price $99.95
Model (SGC10) can accommodate the Vixen VMC200L, VC200L, 8" SCT's and similar models along with a few accessories. The interior padded walls are about 1" thick and it offer more additional support for the focuser area of an OTA. It also includes a padded shoulder strap.
Interior dimensions 22.8" x 11" x 11.8
Exterior dimensions 25.5" x 13.7" x 14.5"
Weight 9 lbs
Price $149
Model SGC30 can accommodate the Vixen VMC110 and similar size optical tubes along with some space for accessories. The interior padded walls are about 1" thick and include two 1" thick padded dividers which can be configured to your preference. It also includes a padded shoulder strap.
Interior dimensions 16.5" x 7.8" x 8.6"
Exterior dimensions 19" x 10" x 11"
Weight 6 lbs
Price $89.95
For questions, inquiries or orders, please visit our website at
http://www.vixenoptics.com/acc/indiv/Soft_case.html
http://www.mrstarguy.com/scripts/prodView.asp?idproduct=449
http://www.mrstarguy.com/scripts/prodView.asp?idproduct=451
Or contact us at 949-429-6363
Clear skies!
Daniel Mounsey
aka Doctor D
Daniel Mounsey
Reged: 06/12/02
Re: New StarGuy soft cases are here! new [Re: Daniel Mounsey]
      #5917577 - 06/12/13 07:32 PM Attachment (31 downloads)
StarGuy SGC650 interior
Daniel Mounsey
Reged: 06/12/02
      #5917586 - 06/12/13 07:36 PM Attachment (23 downloads)
StarGuy SGC30 left and StarGuy SGC10 right.
Daniel Mounsey
Reged: 06/12/02
      #5917590 - 06/12/13 07:38 PM Attachment (22 downloads)
StarGuy SGC30 interior.
Daniel Mounsey
Reged: 06/12/02
      #5917592 - 06/12/13 07:39 PM Attachment (35 downloads)
StarGuy SGC10 interior.
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
      #5917933 - 06/12/13 10:50 PM
Some nice looking cases Daniel! Will you be expanding into typical SC sizes?
David
Daniel Mounsey
Reged: 06/12/02
Re: New StarGuy soft cases are here! new [Re: David Pavlich]
      #5917977 - 06/12/13 11:22 PM
Hi David,
Vixen is aware of this concern regarding compatibility with other slightly larger optical tubes and it's being discussed. Honestly I'm not one to act bias, but these cases are pretty cool and they're quite affordable when compared to other cases. The other thing too is that they're really made nicely when seen up close. Even the zippers are covered from moisture with rubber seams.
Transmographied
Reged: 05/18/05
      #5919317 - 06/13/13 06:42 PM
Thanks, Daniel. The pictures look like they'd make a great carrying case for the typical SC. I'll keep an eye open.
David
Dragonwatcher
Reged: 01/21/08
Loc: Coupeville, WA
      #5924538 - 06/16/13 10:26 PM
I went to order the SGC650 but the picture looks wrong - it is of one of the other models. And it indicates it is not available. If I "preorder", what can I expect in terms of wait time?
Thanks.
Daniel Mounsey
Reged: 06/12/02
Re: New StarGuy soft cases are here! new [Re: Dragonwatcher]
      #5924621 - 06/16/13 11:18 PM
You can ignore the picture on the website for now, it will be updated. If you order the SGC650, you will get the long case.
Clear skies!
Dragonwatcher
Reged: 01/21/08
Loc: Coupeville, WA
      #5926157 - 06/17/13 07:05 PM
Did & done. Thanks.
Daniel Mounsey
Reged: 06/12/02
      #5929790 - 06/19/13 05:57 PM
Thanks Jackie.
Dragonwatcher
Reged: 01/21/08
Loc: Coupeville, WA
      #5939987 - 06/25/13 03:21 PM
Daniel,
That totally did not work out. I ordered the SGC650 & got either a SGC10 or 30 from HOO. The invoice shows SGC650 and the amount is correct. So obviously there is a confusion with this vendor about model numbers & actual item. Do I need to contact HOO and try to work out a return?
Daniel Mounsey
Reged: 06/12/02
      #5942227 - 06/26/13 10:07 PM
Hi Jackie,
Sorry to hear that. Feel free to contact me directly at d.mounsey@vixenoptics.com and I'll try to assist you.
Clear Skies!
Daniel Mounsey
Reged: 06/12/02
      #5945457 - 06/28/13 07:40 PM Attachment (15 downloads)
More new StarGuy cases.
The new StarGuy Mount/Binocular hard case is designed to accommodate GP, SX series mounts, BT81 binoculars and more. Inside dimensions and price are as follows.
Item# SGPC945-001
Price $299.00
ID 22" x 17" x 6"
For details, please visit http://mrstarguy.com/scripts/prodView.asp?idproduct=459
StarGuy is also offering the new Vixen Storage Cases. These are nice for accommodating various eyepieces as well the Vixen Starbook while observing at the telescope by attaching to the tripod leg.
Item# 35651 Eyepiece Case (6.8" x 10" x 3.7") $59.95
Item# 35652 StarBook Ten Case (7.2" x 10" x 3") $59.95
Item# 35653 Accessory Case (7.2" x 10" x 4") $59.95
To order, visit http://mrstarguy.com/contact_us.asp
949-429-6363
Clear Skies!
Daniel Mounsey
Reged: 06/12/02
      #5945461 - 06/28/13 07:42 PM Attachment (22 downloads)
Eyepiece Case. Note, the upper foam fitting compresses the eyepieces in place and they do not move around inside during transport.
Daniel Mounsey
Reged: 06/12/02
      #5945467 - 06/28/13 07:45 PM Attachment (14 downloads)
StarBook Ten Case.
Daniel Mounsey
Reged: 06/12/02
      #5945473 - 06/28/13 07:47 PM Attachment (20 downloads)
Vixen logo.
Dragonwatcher
Reged: 01/21/08
Loc: Coupeville, WA
Re: New StarGuy soft cases are here! [Re: Daniel Mounsey]
      #5960580 - 07/08/13 01:37 PM
I got the refractor case & I am very pleased with it. I can replace a very bulky trunk with this well-built & much lighter case for my 4" refractor and save my back. Well worth the money. It's all I can do to resist buying another one for my other refractor but it already has a good case. Still, two matching cases would look nice....
3 registered and 4 anonymous users are browsing this forum.
