JJK
Reged: 04/28/08
Re: my new NGC7000 narrow band image /UPDATE 1 new [Re: CounterWeight]
      #5965357 - 07/11/13 09:12 AM
It'd be nice to have some RGB data to give the stars their true color.
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5965366 - 07/11/13 09:16 AM
The difference is subtle but noticable. Your stars seem diminished, was that intentional? I like both versions. Maybe you missed my q's above...how do you rate the FSQ-85 now that you have some time with it? Worh the cost difference from the Orion scope?
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: my new NGC7000 narrow band image /UPDATE 1 new [Re: terry59]
      #5965404 - 07/11/13 09:43 AM
thanks John - maybe someday, I've not felt compelled to do that so far as I like the overall effect this way.
Terry - look up about 15 responses from here (#5963949 - 07/10/13 08:58 AM ), I made a long response to your question there. Interesting about the point sources and I'm uncertain why/how that is as I followed identical steps on processing both. It is apparent in the full size TIFF I convert from as well.
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5965421 - 07/11/13 10:01 AM
Thanks Jim, I've no idea how I missed that! Focusers are a concern of mine on any scope based on my experiences. I don't consider your issues to be nit picking at all. For the cost I expect darn near perfect but really don't see it that way. I will be wanting to upgrade from the AT72ED within the next year but am not sure what I should do.
Wouter D'hoye
Reged: 06/27/03
Loc: Belgium
      #5966726 - 07/12/13 01:37 AM
Your new version is obviously better. The noise levels have dropped dramatically. Truly a wonderful image.
Wouter.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: my new NGC7000 narrow band image /UPDATE 1 new [Re: Wouter D'hoye]
      #5966770 - 07/12/13 02:33 AM
Thank you Wouter! I'm going to try and get duplicate data for the Pelican (just next door so to speak) before I add more to this, I'm hoping for a minimum of 16 per channel before calling it good but we'll see.
Terry - glad you found my reply Sky Watcher is introducing a FPL53 based objective f/5 for about $1k (this includes a flattener), and there is some about Vixen reviving the Pentax 100 or 125 design - so it seems that 'they' are paying attention! what in my mind I compare all to is the Orion FPL53 based 80mm triplet using an 'off the shelf' inexpensive focal reducer - total cost also about $1k and an stunning performer optically. but there too, the focuser is the weak part of the system when it comes to a fully loaded 8300M setup with a big filter wheel. In the case of the Orion it just ends up the length of the stuff on the focuser tube taxes it enough to be a problem at times.
But then too we at 1/3 the cost of the Tak FSQ, which I see as being 'in trouble' because of the lax engineering and poor performance of the focuser 'overall' because of the CAA issues.
Then for not much more $ Stellarview has this objective on a tube with a FT focuser. With reducer still less than half the Tak and a half stop FASTER and by my results flat enough for the 8300 chip.
Would be nice if someone went total overkill (I wish the SV had the larger FT focuser even if it looked funny) on the focuser for a change - it really makes all the difference, how can we make them hear us? It is not just great optics, it is that plus getting the CCD perfectly focused without worry. Not sure anyone has that in that bag - yet. But it's getting far more affordable and there is getting to be more competition.
zerro1
Reged: 08/02/09
Loc: Smokey Point , 48.12°N 122.25...
      #5967295 - 07/12/13 12:09 PM
Really Nice work Jim!!
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: my new NGC7000 narrow band image /UPDATE 1 new [Re: zerro1]
      #5967348 - 07/12/13 12:42 PM
Thank you Robert, it sure is nice having some clear skies and being able to put up some work after such a long time. How are things behaving up/over your way?
zerro1
Reged: 08/02/09
      #5967369 - 07/12/13 12:56 PM
I have not set up a mount or turned on an astro cam since last weekend. Currently working 4 X 10's so sleep is the priority. I may attempt a trip to Slate Peak tomorrow night though...
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: my new NGC7000 narrow band image /UPDATE 1 [Re: zerro1]
      #5967428 - 07/12/13 01:30 PM
Predictions are for more clear weather, for what that is worth.. hope you can get out and enjoy if it is true
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5977181 - 07/18/13 02:04 AM
I'm adding some more SII and OIII subs to this so it will match up better to my 'Pelican project'.
I'm going to try and splice the two images together at some point after I learn how to do it.
rflinn68Moderator
Reged: 03/09/12
Loc: Arkansas
      #5977302 - 07/18/13 06:05 AM
This is a really nice image Jim. I like it a lot. Excellent job!
Just over the last two days I've been looking into the 8300M and these 36mm Astrodon filters. I'll probably get these someday but the new 12" concrete pier and ROR observatory is at the top of my list at the moment. Do you think the 3nm filters are worth the added cost over the 5nm? I live in a blue zone (but very close to green) if that matters any at all. Thanks....Now I know who I'll be bugging when I'm ready to make the jump.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: my new NGC7000 narrow band image /UPDATE 1 new [Re: rflinn68]
      #5978262 - 07/18/13 04:32 PM
Thank you Richard. I agree with the ROR/pier priority every time, glad to hear you are going that route. Having the imaging platform 'rock steady', aligned, and ready to go, protected from the elements - what's not to love there?!
Monochrome for me is a necessity and I doubt I'd be imaging without it. I started with the Baader filters that are about 7 or 8nm for financial reasons. though they made a titanic difference from OSC here in the 'white zone', I often had gradient issues in my OIII and SII data. My Ha data was good as far as gradients though in comparing to other imagers using even more narrow filters maybe not as finely detailed or crisp'. My own opinion on the SII and OIII is go the narrowest you can afford. It's not just LP but Luna, and you can image anytime it is clear - no show stoppers. And what you get has that clean crisp look as far as signal to noise even if it's not very strong.
There is something to go into here that I think important. When you go monochrome and filters and use long exposures for nebula there are two ways to go about it from a time perspective. You can image sequentially until getting enough data for all bands, or you can go one band at a time. In the summertime when nights are short, it's taking me near a week of nights to capture all the data for the 3 filters using 20 minute sub exposures. It takes a lot of patience, no more getting an object overnight. (this just with ha/NII/OIII, I think RGBL it's possible)
Importantly you want to go long exposure for nebula in Ha/SII/OIII, the longer the better on most objects if not all. What really matters is that if you are going sequentially, that the filters are par focal. I had no problem with the Baader or now the Astrodons as long as they were a set. I did run into a big focus shift trying to keep the 7nm Baader Ha and use the Astrodon SII and OIII. So in the 'mixed filter' arrangement I would take the Ha and then go after the SII and OIII.
Another consideration with a mono/filter setup is the focuser quality is critical. It's more important than OSC. If you need to add a coma corrector or flattener or reducer on the focuser tube it adds length and any play at all, ANY, is magnified by the length added... tilt and offset, play, shift, all become a force to contend with.
17 registered and 28 anonymous users are browsing this forum.
Moderator:  nitegeezer, WOBentley, dr.who, rflinn68
