smitty0
Reged: 03/17/12
Volcano on the Moon? new
      #5980261 - 07/19/13 05:52 PM Attachment (57 downloads)
It could be a active volcano on the Moon? I think is dome 'Herodotus 1'
Longitude: 50 56 ' West
Latitude: 25 28 ' North
Quadrant: North - West
Area: Aristarchus crater region
Video:
http://www.youtube.com/watch?v=EHb9S0-DCTU&feature=youtu.be
2013-07-20 00:04
Celestron C9.25 [235/f25], camera QHY5L-IIm, IRpass filter 720nm.
desertstars
Reged: 11/05/03
Loc: Tucson, AZ
Re: Volcano on the Moon? new [Re: smitty0]
      #5980323 - 07/19/13 06:25 PM
I believe that's the tip of Mons Herodotus catching the first rays of the morning sun.
Reged: 07/06/07
Re: Volcano on the Moon? new [Re: desertstars]
      #5980343 - 07/19/13 06:37 PM
Yep.
smitty0
Reged: 03/17/12
      #5980350 - 07/19/13 06:45 PM
But it so bright... Ok, tomorrow will try to make more pictures of this location.
azure1961p
Reged: 01/17/09
Loc: USA
      #5980873 - 07/20/13 03:47 AM
I'd be highly inclined to believe its not an active volcano.
Pete
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Re: Volcano on the Moon? [Re: azure1961p]
      #5980886 - 07/20/13 04:29 AM
IMHO looks like a mountain top still in the dark side
already hit by sunlight.
smitty0
Reged: 03/17/12
Re: Volcano on the Moon? new [Re: Mert]
      #5980921 - 07/20/13 05:43 AM
Understood - i think is peak of Mons Herodotus. His albedo is very high. Snow cap
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
      #5981090 - 07/20/13 09:46 AM
If you wanted to analyze the possibility that this was a hot source (i.e. active volcano) you could make measurements at multiple wavelengths, including IR, and compare the shape of the pseudo-radiance curve with the shapes from other illuminated areas of the Moon. (Pseudo-radiance because you have not corrected for the filter transmission). If the "volcano" has a stronger red-IR response versus other areas it may be due to a higher surface temperature. The other possible cause would be a difference in rock composition, but this is likely to be relatively subtle in a radiance measurement.
I don't think it is a volcano, but just wanted to point out that amateurs could easily collect data to characterize these sorts of features if so inclined.
JimC
AlanL
Reged: 11/11/10
Loc: Kansas, USA
Re: Volcano on the Moon? new [Re: Mirzam]
      #5981491 - 07/20/13 02:01 PM
JimC - I like your thinking!
Conventional wisdom is the moon is geologically inactive. If this is an active volcano, it would be the first we have seen!
Mirzam
Reged: 04/01/08
Re: Volcano on the Moon? new [Re: AlanL]
      #5981552 - 07/20/13 02:48 PM
Actually, an even simpler way to monitor the Moon for hotspots would be to create ratio images, for example, IR/G. There would be variations across the lunar surface, and no doubt noisy data within shadows (easily masked out), but extremely high values that appear localized to a small area would be interesting to examine more closely.
Of course you might have to persist for a long time to discover anything (Hundreds, thousands, millions of years?)
JimC
4 registered and 11 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
