Doc Willie
Reged: 03/31/10
Loc: Mid-Hudson Valley, NY, USA
NexStar 8SE azimuth broken
      #5982728 - 07/21/13 10:45 AM
My NexStar 8SE was blown over in a wind gust.
The azimuth now rotates freely by hand. When activated by the hand controller, the motor can be heard running, but the mount does not rotate.
Am I likely to be able to fix this myself. Where are parts available if necessary? Or if necessary where can it be shipped for repair?
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
Re: NexStar 8SE azimuth broken new [Re: Doc Willie]
      #5982856 - 07/21/13 11:45 AM
I think I would have been more worried about the scope than the mount. How did the scope fair? I think you may end up purchasing a used replacement mount,as it may be cheaper in the long run than shipping it back for repair.
If you are so inclined to repair yourself,disassemble it taking images of each procedure so as to remember where everything goes and see if you can find the broken part. Contact Celestron to see if you can get the part and if so, good,if not, you should be able to locate a used mount on here or on Astro Mart. Sorry to hear about your misfortune.
Midnight Dan
Reged: 01/23/08
Re: NexStar 8SE azimuth broken new [Re: tim57064]
      #5982962 - 07/21/13 12:50 PM
Hi Willie:
Hard to tell what might be wrong without opening it up. It sounds likely that a gear tooth was broken or something similar, but it could also be that a drive gear was moved on its shaft and can simply be repositioned and the set screw retightened. If you're handy with tools, I'd suggest opening it up.
If anything is broken, you won't find too many parts available for replacement. Like Tim says, you're probably better off getting a used one. Then you can keep your old one for spare parts for the next time the scope gets blown over.
-Dan
Tel
Reged: 03/31/06
Loc: Wallingford England
Re: NexStar 8SE azimuth broken new [Re: Midnight Dan]
      #5983164 - 07/21/13 02:57 PM
Hi Willie,
So sorry to hear of your misfortune.
As others have already stated, it's impossible to say at this stage what may or may not be damaged.
However, you do say that the azimuth axis now rotates freely by hand, which, clearly before this misfortune, it was not designed to do.
This therefore might indicate that the motor (drive pinion) has become dislodged, (or disengaged) from the main, large, static (cog) wheel: hence the motor turns, as evidenced by the sound you hear when the HC is operated, but, without the engagement of the two sets of intermeshing teeth, does not rotate the azimuth axis.
I'm afraid you will have no alternative but to open up the azimuth axis drive if you wish to investigate this (any) possibility yourself, but perhaps, the attached archived text might help. (?)
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/2309497/page...
Just a thought.
Best regards,
Tel
Doc Willie
Reged: 03/31/10
Re: NexStar 8SE azimuth broken new [Re: Tel]
      #5983220 - 07/21/13 03:42 PM
Thanks for the recommendations. I'll open it up.
As far as the OTA, it seems to have survived quite well. No visible damage, and an out of focus star was quite even and circular. Looked at the (filtered) sun today with it, and it performed quite well.
Doc Willie
Reged: 03/31/10
      #5983615 - 07/21/13 08:37 PM
OK. Got it open. What I see is a small brass gear that is supposed to mesh with the large gear in the base of the mount. The small gear is rotating freely, and moving up an down easily on its shaft, with no visible means of securing it to the shaft. What next?
Doc Willie
Reged: 03/31/10
      #5983688 - 07/21/13 09:37 PM
On closer exam, I see the set screw, hidden by grease. The gear itself is slightly messed up, the teeth on the narrow side of the set screw opening are bent.
Looks like I need a new gear, unless I can put it back in and the damaged tooth is out of the way.
Tel
Reged: 03/31/06
      #5983990 - 07/22/13 02:41 AM
Hi Willie,
There are, (according to the above link), two set screws which hold the gear (pinion) to the motor shaft.
It might be possible to reshape that bent tooth and retighten depending on your overall assessment of the damage, otherwise it does sounds like a new gear is required.
Is though the motor shaft and gear still in line with the toothed disc, (i.e. the az. motor/shaft/gear have not been bent or otherwise damaged as a result of the impact) ?
Best regards,
Tel
Arctic_Eddie
Reged: 12/30/07
Loc: St. Petersburg, FL
      #5984113 - 07/22/13 08:19 AM
It's not likely that you can return the small gear to the original shape. As that gear meshes with the large gear in the repaired area you will see a tracking error. It could lead or lag depending on how you bent the teeth back into position. Damage to the large gear will show a problem only in one small region of azimuth. This you can probably ignore. There are many sources of small metric gears. It's likely that you can find a replacement. Try this source.
https://sdp-si.com/web/html/products.htm
Arctic_Eddie
Reged: 12/30/07
Re: NexStar 8SE azimuth broken new [Re: Arctic_Eddie]
      #5984179 - 07/22/13 09:26 AM
I have a spare AL motor/gearbox assembly which may use the same final gear. These are the specs for that hubless gear.
Bore diameter = 5mm
Number of teeth = 18
Body length = 11mm
Body material = brass
Body diameter = 10.45mm
Pitch diameter = ??? but slightly less and likely 9.5mm ( 10.45 * 0.91 )
Pitch = 48 ( Number of teeth divided by pitch diameter in inches )
I did not find the right gear at the above link but there are literally hundreds on that site just in brass.
Edited by Arctic_Eddie (07/22/13 10:03 AM)
Arctic_Eddie
Reged: 12/30/07
      #5984257 - 07/22/13 10:27 AM
If your gear is long like mine then you can slide it on the shaft, or reverse it, and use an undamaged area. The shaft has only one flat so one of the setscrew holes will be empty.
Doc Willie
Reged: 03/31/10
      #5984348 - 07/22/13 11:42 AM
I was thinking of this. Does the big azimuth gear mesh at the bottom or top of the brass gear?
Arctic_Eddie
Reged: 12/30/07
      #5984426 - 07/22/13 12:50 PM
Not sure about the AZ gear as mine is a replacement AL unit. However, the gear meshes at the opposite end as the setscrew. As long as the large gear doesn't hit the screw, it can mesh anyplace along it's length. The small gear can also be reversed if that will help.
You should also note the AZ position of the damaged portion of the large gear and avoid using it in that region. Even though the small gear has been replaced, there will still be a tracking error in that region as the bent teeth will cause a lead or lag when engaged. It will be a small angle, a few degrees.
Doc Willie
Reged: 03/31/10
      #5985183 - 07/22/13 09:41 PM
Fixed it!
I think. I put the gear back on, with the set screw on the other side, where the hole was undamaged. Put the gear as far on the end of the shaft as I could, so the damaged tooth would be out of the way. It seems to be working, at least mechanically. Will have to wait until the next clear night to field test it.
Thanks for all your help.
Midnight Dan
Reged: 01/23/08
      #5985187 - 07/22/13 09:43 PM
Excellent! We'll keep our fingers crossed!
-Dan
tim57064
Reged: 08/23/12
      #5986209 - 07/23/13 02:45 PM
Glad to hear it! Now let us know when you test the tracking.
Peter9
Reged: 10/30/08
Loc: Yorkshire - Born & Bred
      #5986368 - 07/23/13 04:20 PM
Hope your mount stands up to the test and it is truley fixed.
Regards. Peter.
Doc Willie
Reged: 03/31/10
Re: NexStar 8SE azimuth broken new [Re: Peter9]
      #5988161 - 07/24/13 05:23 PM
Just took it out, and tested it with the 60mm solar scope. Seems to be tracking fine. Hope it holds up over time.
Just in case, I ordered a spare drive gear.
Cloudy Nights folk are the best!
Arctic_Eddie
Reged: 12/30/07
      #5988224 - 07/24/13 06:01 PM
Where did you find a drive gear, Celestron or elsewhere? My searches never found an alternate supplier.
Doc Willie
Reged: 03/31/10
      #5988347 - 07/24/13 07:37 PM
One of the contributors of the Yahoo NexStar group had a couple.
10 registered and 14 anonymous users are browsing this forum.
