Tamiji Homma
Reged: 02/24/07
Loc: California, USA
Swarovski ATX 95 binoculars
      #5983041 - 07/21/13 01:41 PM
I came across interesting binoculars using new Swarovski spotting scope module and Matsumoto-san's EMS. The owner said that it produces good image even at 158x (Nagler 3.5T6), and Nagler 16T5 is most used eyepiece (34.5x).
http://blogs.yahoo.co.jp/narabuh/GALLERY/show_image.html?id=64042218&no=0
http://blogs.yahoo.co.jp/narabuh/GALLERY/show_image.html?id=64042218&no=3
Tammy
edwincjones
Close Enough
Reged: 04/10/04
Re: Swarovski ATX 95 binoculars new [Re: Tamiji Homma]
      #5983047 - 07/21/13 01:45 PM
interesting - yes
quality- high
cost
SMark
Reged: 08/29/11
Loc: Atlanta, GA USA
Re: Swarovski ATX 95 binoculars new [Re: edwincjones]
      #5983527 - 07/21/13 07:35 PM
interesting - yes
quality- high
cost
I don't think it would be too hard to finish this one...
interesting - yes
quality - high
cost -
edwincjones
Close Enough
Reged: 04/10/04
Re: Swarovski ATX 95 binoculars new [Re: SMark]
      #5983641 - 07/21/13 09:02 PM
$10,000+
hallelujah
Reged: 07/14/06
Loc: North Star over Colorado
      #5983671 - 07/21/13 09:24 PM
http://www.longrangehunting.com/forums/f40/swarovski-30x80-binoculars-55264/
edwincjones
Close Enough
Reged: 04/10/04
Re: Swarovski ATX 95 binoculars new [Re: hallelujah]
      #5984068 - 07/22/13 06:54 AM
I wonder how hard these are to adjust for only one, equal image?
edj
Tamiji Homma
Reged: 02/24/07
      #5986931 - 07/23/13 10:05 PM
I read some more with great interest
In terms of cost, two ATX 95 objective lens modules $3,800, EMS $1,600, guesstimate of other parts $1,000+. I guess around $7,000 compact 95mm f/5.8 binoscope.
I think Swarovski ATX objective lens module includes field flattener. There is a report below, stating that it produces pin-point star to the edge with Nagler.
Yes, it is expensive binoculars but it is fun to read someone is having fun.
Mostly in Japanese but you can use Google Translation.
http://www.page.sannet.ne.jp/mazmoto/f5process5.htm
http://www.mazmoto.sakura.ne.jp/image/kuroki3.shtml
Tammy
DRodrigues
Reged: 08/08/11
      #6040712 - 08/22/13 07:49 PM
... The owner said that it produces good image even at 158x (Nagler 3.5T6)...
Tammy
Very interesting Tammy!
I was thinking if the Swaro 95 could replace my TMB92 on my cr-birding combo http://www.pt-ducks.com/cr-telescopes.htm#Test%20of%2082%C2%BA,%20100%C2%BA%20and%20102%C2%BA%20AFOV%20zooms and your links reinforce my idea. For bino-cr combo http://www.pt-ducks.com/cr-telescopes.htm#CR-binoviewing it has probably too long focal length and I'm not sure if wouldn't need an additional focuser to allow focus on all power range...
Joe Ogiba
Reged: 02/14/02
Loc: NJ USA
Re: Swarovski ATX 95 binoculars new [Re: DRodrigues]
      #6040752 - 08/22/13 08:35 PM
I wonder if a pair of 13mm Ethos would work with that setup since they work great in my Denk II binoviewer .
Kimmo Absetz
Reged: 10/12/05
Re: Swarovski ATX 95 binoculars new [Re: Joe Ogiba]
      #6043497 - 08/24/13 12:21 PM
David, Tammy,
I have been using an ATX 95 since last Spring, and have no doubt it can hold up well up to 158x providing you get a good sample of the scope. Mine has essentially perfect optics, star-testing better than any scope I have tested previously, and that includes by now probably over a hundred scopes by Nikon, Zeiss, Leica, Swarovski and Kowa. When the ATX became available in the US, Henry Link posted on Birdforum about comparing the ATX 95 and 85 to his Astro-Physics 92mm Stowaway, noting that although that particular sample of the ATX 95 had some mild SA and very slight astigmatism, it resolved the same. I have by now seen several samples of the 95 which are about as good as mine, although obviously they are not all cherries.
The only other scope that has exhibited similar overall quality aberration-wise is the Kowa 883, but it has 8% smaller aperture and over 10% lower light transmission.
What I don't know is how the quality of the prism system used in this binocular version compares with the ATX prism assembly, but the objectives certainly have very high potential.
Kimmo
Mark9473
Reged: 07/21/05
Loc: 51N 4E
Re: Swarovski ATX 95 binoculars new [Re: Kimmo Absetz]
      #6043814 - 08/24/13 03:28 PM
Kimmo, how do you get to 158x with the ATX95? And do you have a link to Henry's test?
Kimmo Absetz
Reged: 10/12/05
Re: Swarovski ATX 95 binoculars new [Re: Mark9473]
      #6044653 - 08/25/13 03:49 AM
Mark,
I use a Zeiss 3x12 monocular as a tripler, allowing magnifications up to 216x on the ATX 95. This is plenty for star-testing, and is fun on the moon and planets as well.
Here's the link to Henry's observations: http://www.birdforum.net/showthread.php?t=242134
I would add that my own ATX 95, which I did not yet have when I wrote the contributions I made to that thread, has so little SA that if I could have it corrected further, I don't actually know which way it should be tweaked. It also has no coma and no astigmatism on axis. The only deviation from perfect I can see is that in optimally focused Airy disk, the very faint and thin first diffraction ring thins out to almost vanishing at NE, SE, SW and NW if you imagine the ring as a compass ring with north at top. To see this at all, you need to boost the magnification above 150x. This is, I believe, the residual effect of a really excellent quality Schmidt prism roof edge, which in less successful prism units usually causes pinching type aberrations or even outright astigmatism. Not all the ATX prism units I have seen are this good, but a surprisingly large percentage of them are easily good enough not to compromise the performance of the scope.
Kimmo
Mark9473
Reged: 07/21/05
Loc: 51N 4E
      #6044662 - 08/25/13 04:17 AM
Thanks Kimmo. It sounds like it would make a great compact lightweight telescope for astronomical use.
Kimmo Absetz
Reged: 10/12/05
      #6044924 - 08/25/13 10:29 AM
Mark,
It is a great compact relatively lightweight telescope for any use, but only if you are satisfied with the range of its zoom, which is 30-72x. Unless, that is, you use something like the prism units in the original post. And since Swarovski has obviously optimized the optical design for their whole package, objective, prism and integrated eyepiece, it may well be that the aberrations would be less well controlled with something else behind the objective.
The Zeiss tripler is fine for star-testing, but puts quite a lot more glass between the scope and the eye. Thus the image brightness and contrast are significantly reduced and the combo is no match to a proper astronomical scope. The scope itself at 72x or below, on the other hand, is about as good as it gets.
For a great, compact lightweight telescope for astronomical use and more, the just-introduced Nikon Monarch Fieldscope series, if it turns out it can utilize 1 1/4" astro eyepieces as seems possible from the specs, could be a better choice, although the max aperture is only 82mm.
Kimmo
Mark9473
Reged: 07/21/05
Loc: 51N 4E
      #6045414 - 08/25/13 03:36 PM
Thanks; that's something to keep in mind.
Tamiji Homma
Reged: 02/24/07
      #6046784 - 08/26/13 11:10 AM
Thanks, Kimmo for valuable feedback on ATX 95.
I am good with 30-72x as spotting scope.
The heavy TMB 92SS can retire from spotting scope duty.
I'll give ATX 95 a try
Thanks.
Tammy
DRodrigues
Reged: 08/08/11
      #6048801 - 08/27/13 01:06 PM
Unfortunately I need higher mags...
Tammy
It's also my idea on using the 95 mm X lens module with the rest of my combo - I'm trying to keep also the 100 AFOV...
Tamiji Homma
Reged: 02/24/07
      #6049596 - 08/27/13 08:18 PM
Hi Kimmo,
I received Swarovski ATX 95 today.
I'll test both ATX 95 and TMB 92SS side by side when I get a chance. I'll report in Refractor Forum after I have enough time to play with.
ATX 95 is a lot more portable than TMB 92SS. I am sure TMB 92SS is going to retire from spotting scope duty.
Tammy
Tamiji Homma
Reged: 02/24/07
      #6154747 - 10/24/13 02:01 AM
I got word from Matsumoto-san today.
The Swarovski ATX 95 binoscope will be ready in a few weeks.
He has been busy working on other binoscopes for Japanese star party called "Soh-bo-e", two-observe-meeting or binoculars star party on Nov. 1st-3rd.
http://soboe.web.fc2.com
You can follow link to see many unique ATM binoculars, scopes there.
http://soboe.web.fc2.com/report.html
Some photos from 2012
http://soboe.web.fc2.com/2012/report/report2012.html
I found interesting binoscope, built with two Nikon 600mm f/4 camera lenses.
Tammy
Kimmo Absetz
Reged: 10/12/05
      #6154816 - 10/24/13 04:38 AM
Tammy,
How much will the parts from Matsumoto-san come to cost? Although I doubt I'll ever do it, some mild interest is beginning to well up in me as I already have 1/4 of the binoscope in my TX 95 objective. Only one more objective, two eyepieces and the binoscope kit.
Kimmo
2 registered and 38 anonymous users are browsing this forum.
Moderator:  Greyhaven, Knuklhdastrnmr, WOBentley
