Mekon
Reged: 11/08/09
Loc: Brisbane Australia
Ladies and Gentlemen I give you my new observatory
      #5990750 - 07/26/13 05:27 AM Attachment (163 downloads)
This project took me 12 months from laying the concrete to lifting the turret in place.
Here is what I did. I spent a long time thinking about ways to do this and made many mistakes. The pad was my first. I tried to save money by having it poured at the same time as another slab was laid. Next time, I'd make the slab 3 meters square not four, and have it stand proud of the soil. Much less opportunity for water to get under the walls. I would also get the pipe for the pier positioned before the slab was laid, rather than rely on reo and a box of concrete to attach the pier, I'd buy it a meter longer and bury it in the slab footings. I think I probably went overkill on the central concrete column, but there is no way to tell.
I had a couple of data pipes laid underground, and got the sparky to connect the power and internet/phone line.
After seeing my workshop built, I had the idea of building a three meter cube with the same method. The garage people said their engineers weren't happy about making a building and not a roof. But they were persuaded and It was a terrific solution. I put up the framing for three of the walls and then built a scaffold to hold the joists in place. Once the joists were in position I slid the floor up onto the joists attached it securely and cut the floor hatch out. The floor is just above the doorway so the top of the wall is about hip height. I then fixed a drilled steel plate to the pier, aligned it roughly N/S and welded it on. The main plate duplicates the shape of my tripod but made of a substantial slab of steel. I hadn't taken into account a protruding part of my CGEM mount, so I had enormous fun, making sparks and grinding some of the slab away.
I then had to think about the top. I couldn't get anyone to respond when I tried to buy the domes made around here and couldn't afford the one other I looked at. ($11K)
My first turret was made of ply. Heavy exterior ply. I had a building designer friend tell me where I went wrong So I pulled it apart and rebuilt it.
I went through a lot of ideas trying to work out how to do a cut the friction as the turret rotates. Eventually I found these little Chinese rollers that are used in screen door applications and ordered 600, they are rated at 20Kg each and the turret weighed 350kg.
A mate has a truck with a crane so he loaded
the turret onto his truck and put it in place. It rotated, but it was just too hard to push. I had no alternative but to scrap the turret and do something else.
I had built a little 3D model that showed me I had the proportions right. (I got that idea from Medieval cathedral builders!) So I took the turret to a couple of metal fabricators and gave one the job. They did a great job and it is now on the cube and rotating well. In the next few days, I'll get my scope together, carpet both floors, put some furniture in and open the hatch to space.
JMKarian
Reged: 03/18/13
Loc: Northwestern PA
Re: Ladies and Gentlemen I give you my new observatory new [Re: Mekon]
      #5990784 - 07/26/13 06:36 AM
Mekon
Nice!
Many years of clear Southern skies!
John
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Ladies and Gentlemen I give you my new observatory new [Re: JMKarian]
      #5990915 - 07/26/13 09:19 AM
Pretty cool Mekon, are you going to put the turret on a motor?
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: Ladies and Gentlemen I give you my new observatory new [Re: Raginar]
      #5990921 - 07/26/13 09:24 AM
Looking good!
Do as much work as possible before putting the scope in. Putting the scope in kills tou motivation for building and makes you want to use it.
I still have some flooring and wiring in my obs, but most of my clear akies time has gone to observing.
Midnight Dan
Reged: 01/23/08
      #5990931 - 07/26/13 09:29 AM
Very nice, and unusual design! How about some inside photos showing some more of the construction details?
-Dan
seryddwr
Innocent Bystander
Reged: 02/19/10
Loc: La-la land.
Re: Ladies and Gentlemen I give you my new observatory new [Re: Midnight Dan]
      #5991295 - 07/26/13 01:31 PM
I like it!
Greyhaven
Reged: 05/11/04
Loc: Greater downtown Maine
      #5991310 - 07/26/13 01:41 PM
Melon, your generosity overwhelms me. I am truly humbled by the gift. I must insist that you keep it for yourself and hope your observatory gives you as much enjoyment as mine has given me.
Great looking job! Enjoy
Be Well
Grey
nicklane1
Reged: 03/04/08
Re: Ladies and Gentlemen I give you my new observatory new [Re: Greyhaven]
      #5991324 - 07/26/13 01:50 PM
Congrats. Very innovative. Please show pics of the inside.
RobertED
Reged: 07/11/03
Loc: Smithfield, RI
Re: Ladies and Gentlemen I give you my new observatory new [Re: nicklane1]
      #5992067 - 07/26/13 09:57 PM
Fantastic job!! Clear Skies, my friend!!
Mekon
Reged: 11/08/09
Re: Ladies and Gentlemen I give you my new observatory new [Re: RobertED]
      #5992277 - 07/27/13 12:45 AM
Thank you all, do you want to see construction pics as well as the inside?
There are no plans to put in a motor, but I'd like to see others' powered setups for ideas. I guess I should be able to push it around for another ten years. Should I reach 70 I think I'd have to do something like that.
Thanks again,
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5992691 - 07/27/13 10:07 AM
Sure do!
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
      #5992723 - 07/27/13 10:29 AM
Let's see some interior shots.
Starman27
Reged: 01/29/06
Loc: Illinois, Iowa
Re: Ladies and Gentlemen I give you my new observatory new [Re: tim57064]
      #5995215 - 07/28/13 05:45 PM
Great concept and well executed. Can't wait to see inside.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Ladies and Gentlemen I give you my new observatory new [Re: Starman27]
      #5995320 - 07/28/13 07:02 PM
No thanks I already have one. Mike
Dr Morbius
Reged: 02/06/07
Loc: ManorvilleNY-but not for long
Re: Ladies and Gentlemen I give you my new observatory new [Re: mikey cee]
      #6001607 - 08/01/13 04:19 PM
Any more shots?
5 registered and 5 anonymous users are browsing this forum.
Moderator:  Christopher Erickson, Mitchell Duke
