Speciality Forums >> Science! Astronomy & Space Exploration, and Others
ColoHank
Reged: 06/07/07
Loc: western Colorado
Re: Transparent atmosphere link to intelligent life? new [Re: petrus45]
      #5995016 - 07/28/13 03:59 PM
Assuming you're right, maybe we haven't evolved much at all.
Exactly. I think you could take a newborn from a surviving stone-age culture (admittedly hard to find nowadays), immerse it in our 21st-century setting with access to decent healthcare and schools, and it'd do just fine.
llanitedave
Humble Megalomaniac
Reged: 09/26/05
Loc: Amargosa Valley, NV, USA
      #5995028 - 07/28/13 04:06 PM
Assuming you're right, maybe we haven't evolved much at all. Maybe astronomy is just a re-channeling of the hunter/gatherer inclination to chase an animal over the next hill. Sort of takes the grandeur out of it for me though.
We've evolved a lot in 6 million years, but not much in the past 10,000. Anyway, I enjoy chasing animals over hills (or did when I was fast enough to at least pretend to keep up with them), and I don't think there's anything at all wrong with the hunter-gatherer mentality. Seems to suit our adaptable ways just fine. If I were a hunter-gatherer, I'd still think the stars were grand. I appreciate that a trait that has adapted us well for one behavior has also pre-adapted us for something revolutionarily different. That's the kind of serendipitous opportunity that evolution takes advantage of, and I'm optimistic it can take us to the next level.
ColoHank
Reged: 06/07/07
Re: Transparent atmosphere link to intelligent life? new [Re: llanitedave]
      #5995097 - 07/28/13 04:37 PM
Indeed, it's possible to observe modern-day hunter-gatherers in the aisles of just about any department store.
petrus45
Reged: 01/31/11
Loc: SW Ohio / N Ky.
Re: Transparent atmosphere link to intelligent life? new [Re: ColoHank]
      #5995167 - 07/28/13 05:18 PM
They tend to hang out in the Classifieds section. However, just as a test, let's see what happens when I do this:
dickbill
Reged: 09/30/08
      #6009644 - 08/06/13 02:54 PM
Hi all, it's been a while.
I'd say a transparent atmosphere is necessary for photosynthesis, the basis for a sustained 'global metabolism' of our planet, which occurs in the visible.
I'don't know if IR-or longer wavelenght-based-photosynthesis
would be energetic enough to sustain hydrocarbon synthesis, probably not, and in the UV and shorter wavelenght, there is probably no 'molecular antenna' strong enough to do the job, i.e, a chlorophyle system working in the UV would be destroyed by the UV photon (could anybody confirm that?). So, i suppose hydrocarbon sysnthesis using an organic antenna works best between IR and UV and so the atmosphere had to be transparent in this part of the spectra.
The link to intelligent life is that only photosynthesis generates enough biomass to sustain 'higher' lifeforms. Also, since the energy gathered by the molecular antenna in grren plants or cyanobacterias goes all the way down to the photolysis of water, to release protons and oxygen (O2 as a byproduct), it's a good thing that organic photosynthesis released a byproduct transparent for organic photosynthesis.
There would have been no future for photosynthesis, had the photolysis of water opacified the atmosphere.
Even if the primitive earth atmosphere was not as transparent as today's, there still must have been enough transparency to initiate the process.
UND_astrophysics
Reged: 01/19/13
Re: Transparent atmosphere link to intelligent life? [Re: karstenkoch]
      #6010167 - 08/06/13 07:29 PM
Your assumption about observing and intelligence is indeed correct.
Before I started my astrophysics graduate degree, my first field of study was paloeanthropology, evolutionary psychology of hominid species. There is indeed a link between observing and intelligence, and the evidence lay off the southern tip of Africa, When the Sahara pump failed and Africa became barren, H. Sapiens moved to the southern tip, driven by drought and famine. By observing the moon, they were able to predict lunar tides, and thus the cycle of lower ocean levels. They then began the first harvesting of crab near the Cape of Good Hope South Africa.
This was the impetus of advancement in intelligence known as regional determinism.
I hope that helped.
llanitedave
Humble Megalomaniac
Reged: 09/26/05
Re: Transparent atmosphere link to intelligent life? new [Re: dickbill]
      #6010715 - 08/07/13 01:16 AM
I partly agree and partly don't. Pretty much all you said is true for life on Earth. Hypothetically, though, a planet that's not Earth could under the right circumstances power a robust and energy-rich living community without photosynthesis. Under the right circumstances, I think that a planet more massive than Earth can retain its internal heat longer, pump out more of it over a longer period, and sustain an ecosystem based on chemotrophs. Alternatively, the internal heat of an Earth-sized planet can be sustained tidally, as in Io, by the gravitational influence of a close massive companion.
And, back to the OP's point and yours, an atmosphere can be translucent enough to allow sufficient light for photosynthesis while still remaining hazy enough that distant details are obscured. In none of these cases is the evolution of intelligence necessarily precluded, unless I'm missing something.
UND_astrophysics
Reged: 01/19/13
      #6011166 - 08/07/13 10:08 AM
The original question was in regards to visual observing
karstenkoch
Reged: 04/21/12
Loc: GMT+9
Re: Transparent atmosphere link to intelligent life? new [Re: UND_astrophysics]
      #6025756 - 08/14/13 06:37 PM
Wow, many thought-provoking replies! Thanks UND_astrophysics for the crab harvesting and moon connection. Speaking of harvesting and harvest time, it does seem that every early calendar system relied on a clear view of the heavens. Of course, the development of calendars has more to do with the rise of civilization rather than intelligence. But, now I'm wondering what kind of primitive calendars those crab harvesters may have etched on the side of a tree or rock wall
Doug Reilly
Reged: 07/29/08
Re: Transparent atmosphere link to intelligent life? new [Re: karstenkoch]
      #6028283 - 08/15/13 11:45 PM
I always thought that once humans started making tools, and altering their own environments more than the other way around, we sort of jumped the tracks of physical evolution and entered into a new stage. In a lot of real ways, we are driving evolution. Though we have not physically evolved much in 10,000 years, our thinking and technology has, dramatically. If you take our technology as a part or our bodies (and I swear today's generation is born with a smart phone or tablet where their hands should be) then we have certainly evolved.
To me, a transparent sky (not just our atmosphere but our region of space, relatively free of dust clouds) provided humans with a much deeper environment in terms of information. Time keeping, calendar making, predication of regular events, navigation, and then to the modern day revlelations of phsyics and astronomy, humanity has been challenged and rewarded by a night sky full of stars.
Since I think humans are in a different phase of evolution than saw the initial rise of intelligence, the incredible effect of the night sky on human thinking has played a role in our evolution, from the ancient times to the present day.
Douglas Adam's plotline for the planet Krikkit was one of the first things I thought of when I read the first post on this thread...
4 registered and 7 anonymous users are browsing this forum.
Moderator:  LivingNDixie, FirstSight, JayinUT
