Telescope Specific Forums >> Questar Forum
starboy1954
Reged: 11/26/10
Loc: Aurora, Il
Astropier
      #6023803 - 08/13/13 07:32 PM
I have the short Tristand so when viewing I sit pretty low to the ground. I'm thinking about getting the taller Astropier so I can stand sometimes. Here is my question to those of you who have experience with the Astropier. With an adjustable observer's chair, is it also possible to view while seated?
Bob
Billydee
Reged: 01/23/08
Loc: Winter Haven, FL
Re: Astropier new [Re: starboy1954]
      #6023904 - 08/13/13 08:33 PM
Bob,
FJR made most Tristands over the years and they still are making them and selling via various vendors. I also understand they still sub-contract for Questar whtn the new owners need an additional source (the new owners are also a CNC company). FJR also sells the Tristand and Astropier at a lower cost than Questar.
I'm not sure of the height difference but you can call FJR at 262-338-3389 and they will provide you with this information. You will then be able to raise your Tristand that height and see if you like it for viewing (might use a wooden box, be careful).
The nice part is FJR will be able to sell you the mount without the head. You can then move your head to the new Astropier base. A new Tristand head lists at $799 and the new whole Tristand is $1399 so an Astropier base will probably cost about $650 ($600 + $50 for the extra height). The last used Astropier I saw went for $1200.
Give them a call, Bill
Billydee
Reged: 01/23/08
Re: Astropier new [Re: Billydee]
      #6023951 - 08/13/13 08:55 PM
Bob,
Here is the data you need.
TRISTAND SPECIFICATIONS
SPECIFICATIONS
Approx. Eyepiece Height: 41 inches (104 cm)
Stored Height: 26 inches (66 cm)
Standard Latitude Range: 26 to 90 Degrees
Stand Leg Spread Extended: 28 inches (71cm), point to point
Tristand Weight: 15 lbs. (6.8 kg)
TRISTAND SHIPPING DIMENSIONS
Number of packages Two: Head and Pier/Legs
Package 1 Dimension 13 x 13 x 18 inches (33 x 33 x 45 cm)
Package 2 Dimension 13 x 13 x 31 inches (33 x 33 x 78 cm)
Package 1 Weight: 9 lbs. (4 kg)
Package 2 Weight: 23 lbs. (11 kg)
ASTROPIER SPECIFICATIONS
SPECIFICATIONS
Height from Ground to Level Platform**: 47 inches (119 cm)
Approx. Eyepiece Height**: 57 inches (145cm)
Weight: 28.8 lbs. (13.1 kg)
ASTROPIER SHIPPING DIMENSIONS
Package 2 Dimension 13 x 13 x 40 inches (33 x 33 x 102 cm)
Package 2 Weight: 29 lbs. (13.2 kg)
Bill
Billydee
Reged: 01/23/08
      #6023958 - 08/13/13 09:03 PM
Bob,
Here is a great writeup about the Tristand and Astropier from Company7. I states you can custom order any height Pier you want.
http://www.company7.com/questar/products/questristand.html
Bill
starboy1954
Reged: 11/26/10
Loc: Aurora, Il
      #6025563 - 08/14/13 05:01 PM
Thanks for the info, Bill!
0 registered and 2 anonymous users are browsing this forum.
Moderator:  cbwerner, Brian Risley
