sfugardi
Reged: 09/30/06
Loc: CT
Venus, Neptune, Uranus 8/17/13
      #6031836 - 08/17/13 10:00 PM Attachment (49 downloads)
Had some decent seeing last night and I tried to capture all 7 planets in 1 night. Only with tree blockage and early morning clouds I stopped after 5, not being able to see the dim 1.5mag Mars in daylight.
Here's my first UV-RGB Venus using the ZWO camera. Seeing was marginal so I opted for prime focus. I used the Schuler UV filter which is quite dark but seems to work fine with the ZWO. I combined IR-RGB then resplit out RGB and recombined with UV-RGB showing some reasonable cloud capture.
Steve
sfugardi
Reged: 09/30/06
Loc: CT
Re: Venus, Neptune, Uranus 8/17/13 new [Re: sfugardi]
      #6031838 - 08/17/13 10:05 PM Attachment (38 downloads)
Here's my attempt at Neptune, taken at prime focus late in the evening at low altitude, after wasting too much time collimating and trying to figure out the Compustar computer glitch. 500frames RGB stacked from 20fps data, resized 3x,
Steve
sfugardi
Reged: 09/30/06
Loc: CT
      #6031852 - 08/17/13 10:13 PM Attachment (45 downloads)
Attached is my best Uranus capture to date. Seeing was excellent and 2 moons were easily visible at the 312X eyepiece, which I can never remember ever seeing before. IR685 filtered data ran for 28min and I stacked 3000frames. Between the drift going left and a moon alignment with WinJupos, north is approx 1pm on these images. Some detail can be observed. 2000frames RGB were also combined out of 5000frame avis, making the IR-RGB image.
Steve
sfugardi
Reged: 09/30/06
Loc: CT
      #6031854 - 08/17/13 10:15 PM Attachment (28 downloads)
Last night was my first attempt at collimating with the ZWO and IR685 filter using Metaguide. Results were numerically the best I have ever recorded.
Steve
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #6031913 - 08/17/13 10:57 PM
Steve,
Quite an awesome night you had there! Definitely memorable.
I am "enjoying" a dust storm right now, so all the scopes will stay under wraps.
Paul
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
Re: Venus, Neptune, Uranus 8/17/13 new [Re: Sunspot]
      #6031926 - 08/17/13 11:09 PM
Very nice especially the Uranus
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Venus, Neptune, Uranus 8/17/13 new [Re: wenjha]
      #6032048 - 08/18/13 12:30 AM
A real tour de force Steve, no one works harder at achieving technical perfection than you and it shows!
Pete
sfugardi
Reged: 09/30/06
Loc: CT
Re: Venus, Neptune, Uranus 8/17/13 new [Re: lcd1080]
      #6032481 - 08/18/13 09:34 AM
Paul, Sam, Pete, thanks for the compliments! I really appreciate them.
Venus has always been challenge for me since the best views from my observatory are in the west and I have to fight heat buildup from my concrete. I locked onto Venus around 4:30pm and as it dropped in altitude, the seeing improved until I took this shot after 5pm. I am thinking of rigging up an old air conditioner from the garage to pre-cool my dome to ambient.
For focusing on Uranus, I tried to use Metaguide, but the software would not lock onto the disk so I focused by eye. This is probably not the best method for precision. With the sun coming up, I only had time for 1 avi run. At least it still very early in the Uranus imaging season...
Steve
Pete Gorczynski
Reged: 05/09/08
Loc: Oxford, CT USA
      #6032520 - 08/18/13 09:58 AM
Nice results, Steve.
Have you looked for Triton hiding in the noise of the Neptune image? Also you may want to look at your red capture a little closer to see if you detected any subtle brightening in the south polar region. I did Uranus captures that night as well. I ran a 30 minute avi run with an IR742 filter capturing 12000 frames. As far as I could tell, I could not see any real detail. A foggy river valley in Connecticut is not exactly the same as a mountain top in the Pyrenees!
Pete G.
sfugardi
Reged: 09/30/06
Loc: CT
Re: Venus, Neptune, Uranus 8/17/13 new [Re: Pete Gorczynski]
      #6032553 - 08/18/13 10:20 AM
Pete, thanks! I went back to the Neptune R data and could not find Triton. I suspect 2hrs past transit and a marginal focus is to blame. I have seen Triton on the computer screen in the past with longer exposures. With Nepture peaking at 1:30am, there is still a good couple of months left to recapture it. I think the deeper IR742 filter would have an advantage on Uranus as long as the fps rate doesn't drop off too much. For sure, it seems to work well on Mercury based on your recent excellent images. With Venus being so bright you should be able to go IR802 with no issue.
Steve
Steve
rolo
Reged: 01/14/07
Loc: GA, USA
      #6032682 - 08/18/13 11:36 AM
Great set of images! I particularly like the Venus image.
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: Venus, Neptune, Uranus 8/17/13 new [Re: rolo]
      #6033579 - 08/18/13 08:46 PM
Sounds like you've taken any respite needed and are up and running with full-scale imaging forays there Steve - that's quite an effort for one night..!
Kecktastic
Reged: 01/16/10
Loc: Broken Hill NSW Australia
      #6033610 - 08/18/13 09:04 PM
Well done Steve, for sure a top effort and demonstrates your dedication to our field.
Regards
Trevor
sfugardi
Reged: 09/30/06
Loc: CT
Re: Venus, Neptune, Uranus 8/17/13 new [Re: Kecktastic]
      #6034193 - 08/19/13 09:23 AM
Rolando, Mo, Trevor, Thanks for the positive feedback! I'd have to cut down some more trees to improve my eastern view, but for some reason my family wouldn't appreciate it... It's been over a year since my last Venus attempt and I completely forgot how difficult it is to focus. I am hoping for another chance or 2 this week.
Steve
PS: My Jupiter data from that morning was terrible, apparently it does not capture well in the daytime.
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #6034488 - 08/19/13 12:29 PM
That's remarkable work Steve. One of the best Venus images I've seen. Very well done!
Glenn
sfugardi
Reged: 09/30/06
Loc: CT
Re: Venus, Neptune, Uranus 8/17/13 new [Re: DesertRat]
      #6035546 - 08/19/13 10:51 PM
Glenn, thank you very much! I'm hoping to recapture Venus tomorrow. I've got the 1.8x barlow glass screwed to the short 2.0x body, so I am estimating a "1.6x" equivalent. Assuming conditions hold up. There's been a flurry of good seeing here in CT lately. The next 2 nights will be above average, so I need to get a couple hours of sleep and head out after 1am.
Steve
10 registered and 19 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
