Telescope Specific Forums >> Meade Computerized Telescopes
CharlieB
Reged: 12/11/07
Loc: Southern NH
LXD750/650 controller
      #6034869 - 08/19/13 04:17 PM
I know the Meade LXD 750 & 650 must have, at some time, been available without the 1697 Computer Drive System as the instructions for installing the system are in the original user's guide. I was wondering if anyone knows what kind of control system was available before the 1697? And if so, was it used in other Meade mounts? I ask because I blew C2 in the power control board and was using the mount manually until I received a package of 35v 6.8 mf tantalums to replace it and other well-know culprits. It would have been nice to have some drive mechanism, even if it was not-goto.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: LXD750/650 controller new [Re: CharlieB]
      #6035168 - 08/19/13 06:43 PM
Those mounts were offered in three versions, though by far the most common included the #1697 goto system. Another option was tracking-only. It used the same motors but a simplified internal controller and a simple handbox. I've only ever seen one of those. It was also offered (at least on paper; never saw one) as a manual-only mount with no drives. That version actually had the motors inside but not connected to anything.
CharlieB
Reged: 12/11/07
Loc: Southern NH
Re: LXD750/650 controller new [Re: jrcrilly]
      #6035271 - 08/19/13 07:51 PM
Thanks for the great information. When (if) the mount every really dies, I'll take the knobs off and grind a flat spot on them for flex cables. It worked quite well manually and takes a load rather well. When I had the mount apart, I was pleased to see well-designed and well-made boards - quality you don't see very often any more. Sure wish they'd used higher voltage caps, though. Man, was there ever a lot of smoke from that little capacitor! Fortunately, that was all that went. It happened when I connected the 12-18v adapter (without checking the output voltage first). My error and I got very lucky.
southmike
Reged: 11/22/04
Loc: Fayetteville, NC
      #6035690 - 08/20/13 12:44 AM
Open your controller and wrap a piece of duct tape around the ribbon.. At way if it blows it won't blast a hole through the ribbon..
southmike
Reged: 11/22/04
      #6035693 - 08/20/13 12:48 AM
Which leads me to another question if you blew the power control board..even the dummy non goto version would probably not function....
Would not be as hard to rig up a fix.but just saying.
Reged: 04/30/03
Loc: NE Ohio
Re: LXD750/650 controller new [Re: southmike]
      #6035750 - 08/20/13 02:01 AM
There's no separate, independent power control board. Each controller incorporates its own. If he replaced the #1697 with the tracking-only controller the only parts that would remain in place are the motors and encoder boards.
CharlieB
Reged: 12/11/07
Loc: Southern NH
      #6036308 - 08/20/13 11:44 AM
I didn't make it very clear that the board I was referring to is the first of the two that are sandwiched together inside the mount - the one with the voltage regulator. I had already replaced the tantalums in both of my handboxes. I also had shielded the ribbon cables, although I do have one of the replacement cables Ron Sampson made a few years back - just as extra insurance.
Skywatchr
Reged: 06/03/06
Loc: North-Central Pa.
      #6040586 - 08/22/13 06:16 PM
Hi Charlie, I converted my LXD650 to use Autostar (and Audiostar) so you do have options just in case.
CharlieB
Reged: 12/11/07
Loc: Southern NH
Re: LXD750/650 controller new [Re: Skywatchr]
      #6040999 - 08/22/13 11:25 PM
I've only read about that conversion kit. Is it still available?
Skywatchr
Reged: 06/03/06
      #6044055 - 08/24/13 06:42 PM
Yes it is still available. Go to the website http://tech.groups.yahoo.com/group/LX200Autostar/ and send George a message.
CharlieB
Reged: 12/11/07
Loc: Southern NH
      #6045999 - 08/25/13 09:15 PM
Thanks! Will do.
JAT Observatory
NOT a Wimp
Reged: 02/20/05
Loc: In the Primordial Soup
      #6064064 - 09/05/13 10:04 AM
I have a LXD650 and I can't decide if I should just replace the caps or go with the AutoStar upgrade.
CharlieB
Reged: 12/11/07
Loc: Southern NH
Re: LXD750/650 controller new [Re: JAT Observatory]
      #6067479 - 09/07/13 09:58 AM
If you need a few 35v tantalums, let me know. I have a few left over.
0 registered and 4 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
