gatorengineer
Reged: 02/28/05
Loc: Hellertown, PA
Any Interest in an 8" Al Travel Scope group build? new
      #6033111 - 08/18/13 03:50 PM
We have some very talented designers and alot of great ideas, any interest in an 8" travel scope group build. Thinking of something that could be waterjetted out of aluminum.. Would need to account for various focal lengths of primaries...
Seeing what people think.
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: gatorengineer]
      #6033409 - 08/18/13 06:51 PM
I'll bite. Need to see some ideas though. How about a 1/2 ring UTA with two poles? Lawnmower blade style spider?
JimC
kfrederick
Reged: 02/01/08
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: Mirzam]
      #6033463 - 08/18/13 07:28 PM
Maybe Danny will do some 3d drawings Of some of the ideas . Maybe a scale of the James Web all folded up for launch then opens up . Just kidding
Mirzam
Reged: 04/01/08
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: kfrederick]
      #6033470 - 08/18/13 07:32 PM
I'll add that f/5 is a good number for a small travel scope. Longer than this requires counterweighting. Shorter requires more sophisticated collimation tools, which add weight. Although you can use the tools as counterweights.
JimC
Pinbout
Reged: 02/22/10
Loc: nj
      #6033563 - 08/18/13 08:38 PM
I could eve animate it and put it on youtube
jwaldo
Smart Mime
Reged: 04/26/04
Loc: Simi Valley, CA
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: Pinbout]
      #6033838 - 08/19/13 12:26 AM Attachment (39 downloads)
I've doodled around a bit with a 6-8" all-aluminum travel dob a bit, never got beyond some half-done 3D models though...
Arjan
Reged: 01/21/09
Loc: Netherlands
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: jwaldo]
      #6033950 - 08/19/13 03:46 AM
If you want to save a bit more on weight, you could get rid of the focuser-side trunnion and replace it with a 1/2" or so axle?
Pinbout
Reged: 02/22/10
Loc: nj
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: Arjan]
      #6034066 - 08/19/13 07:29 AM
Like a litescope
kfrederick
Reged: 02/01/08
      #6034536 - 08/19/13 12:57 PM
Because every part and every hole drilled can be done on the CNC Jet [If people wont ] And compound curves or anything that can be drawn can be made very accurate .003 . Go wild .Danny looks great your work You need a CHief . Hope you come down some time
Arjan
Reged: 01/21/09
Loc: Netherlands
      #6034697 - 08/19/13 02:40 PM
Yes, for example like Litescope or like Toshimi Taki
Edited by Arjan (08/19/13 02:43 PM)
gatorengineer
Reged: 02/28/05
Loc: Hellertown, PA
      #6035147 - 08/19/13 06:36 PM
was actually hoping to come up with an aluminum version of this in the 8" size... Jetted out of 0.25" aluminum and tig welded together..... maybe even anodized......
http://www.sumerianoptics.com/products/alkaid/
polaraligned
Reged: 12/26/08
      #6035345 - 08/19/13 08:38 PM
I would definitely be into a well designed 8" travelscope.
I can donate CNC mill time to the cause.
I like the sumerian optics scope, but think a single pole would be easier setting up. Now if we could design a telescoping pole that was stiff enough, that would be huge. I can't make the mirror myself, but would like a quality f/4 mirror. Maybe cellular if some amateur casters want to get into the game...
Dave O
Reged: 12/21/11
Loc: Sri Lanka
Re: Any Interest in an 8" Al Travel Scope group build? [Re: gatorengineer]
      #6035407 - 08/19/13 09:24 PM
Looks a lot like the scope shown by bertb, message #4495943 in this thread: http://www.cloudynights.com/ubbthreads/showflat.php?Cat=0&Board=atm&N...
Would aluminum be stiff enough?
Wonder how he did the trusses?
Arjan
Reged: 01/21/09
Loc: Netherlands
      #6035814 - 08/20/13 03:13 AM
Ah! Nothing wrong with a Dutch design...
Arjan
Reged: 01/21/09
Loc: Netherlands
Re: Any Interest in an 8" Al Travel Scope group build? new [Re: Dave O]
      #6035819 - 08/20/13 03:26 AM
IMHO, trusses are usually over-designed, there's a lot of weight to save. A German design even uses lightweigth foldable rules, 8 of them apparently made it stiff enough.
Pinbout
Reged: 02/22/10
Loc: nj
      #6035912 - 08/20/13 06:59 AM
and then there's teeter's design
http://www.youtube.com/watch?v=2kCitl8BHUM
rob contacted mr.sumerian but mr. sumerian didn't want to license his designs. whatever.
Dave O
Reged: 12/21/11
Loc: Sri Lanka
      #6036154 - 08/20/13 10:12 AM
My goodness! I'd have never even considered that! If those folding rules truly are stiff enough to support the upper cage, I think that they would be a tough choice to beat as far as convenience for packing is concerned? Surely the design could be improved upon -- but perhaps there is no need? Certainly easy enough to procure. Thanks for sharing that bit of intel.
Pinbout
Reged: 02/22/10
Loc: nj
      #6036172 - 08/20/13 10:23 AM
and if you mess up measuring their lengths...
kfrederick
Reged: 02/01/08
      #6036337 - 08/20/13 12:00 PM
One thought is interlocking plates to build the tube they could be hinged so each is short . When interlocked should be strong optical tube . Or tripod legs they slide into them self and make short poles . Just ideas .
Chriske
Kijkerbouw Urania
Reged: 08/15/04
Loc: Boechout, Belgium
      #6036361 - 08/20/13 12:07 PM
We tested the foldable rules. It was not stiff enough. While rotating the rocker the scope flexed quit a lot and did not return to its 'starting point', as expected.
8 registered and 30 anonymous users are browsing this forum.
