sfugardi
Reged: 09/30/06
Loc: CT
Another Uranus IR685 f20 8/20/13
      #6036075 - 08/20/13 09:33 AM Attachment (31 downloads)
Under good seeing but poor transparency with a bright mooon, I was able to collect some new Uranus data. My plan was to go a little higher than f22 by switching the 2x barlow glass onto the longer 1.8x body, however, I outsmarted myself and grabbed the new 2x which is more like 1.6x at this point (tried on Neptune but still too much for the IR). By the time, I realized it the sky was brightening. So attached is a 1680sec capture at 5fps at approx f20 using IR685.
Steve
sfugardi
Reged: 09/30/06
Loc: CT
Re: Another Uranus IR685 f20 8/20/13 new [Re: sfugardi]
      #6036085 - 08/20/13 09:35 AM Attachment (11 downloads)
So, you will notice that I left off the N pole indication due to the fact that the drift test and WinJupos do not seem to agree. I must be missing something basic on the orientation. Any simple advice would be greatly appreciated.
Steve
Pete Gorczynski
Reged: 05/09/08
Loc: Oxford, CT USA
      #6036160 - 08/20/13 10:15 AM
Steve,
Try http://pds-rings.seti.org/cgi-bin/tools/viewer2_ura.pl to get the correct orientation. There is also a viewer for Neptune to which John Boudreau turned me on to.
Also I think tonight we may have an excellent oppotunity for good seeing in CT, but don't wait too long because I expect fog to roll in late. Have you tried to image at prime focus? Sure, the image scale is small, but both Uranus and Neptune are low surface brightness objects. I think using a barlow spreads out what little light is available too much.
Pete G.
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Another Uranus IR685 f20 8/20/13 new [Re: Pete Gorczynski]
      #6036261 - 08/20/13 11:11 AM
Another high quality effort Steve! As for grabbing the new 2x don't feel bad, at 4 in the morning my IQ regularly slips to a level where that kind of mistake is to be expected.
Pete
sfugardi
Reged: 09/30/06
Loc: CT
Re: Another Uranus IR685 f20 8/20/13 new [Re: lcd1080]
      #6036280 - 08/20/13 11:21 AM Attachment (11 downloads)
Pete G, thanks for the info link. I tried to pull out the new Neptune data from last night looking for your limb brightening but no luck. I found Triton easily. At only 4fps for the IR data, there is no chance for a barlow. I'll compile the RGB data and post later. Wow the CSC looks excellent all night. I hope I have some energy left.
Pete, Thanks! It's tough getting 2hrs of sleep and waking up at 1am...
Steve
CPellier
Reged: 08/07/10
      #6037086 - 08/20/13 06:31 PM
Hi Steve, the orientation of WinJupos seems correct to me as well .
The planet is quite well circular but I think it lacks frame stacking. 2000 is not a lot on Uranus
sfugardi
Reged: 09/30/06
Loc: CT
Re: Another Uranus IR685 f20 8/20/13 new [Re: CPellier]
      #6037449 - 08/20/13 10:59 PM Attachment (6 downloads)
Christophe, thanks for verifying the orientation. I can go back and try stacking 3 or 4K out of the 8K collected. Here's my IR-RGB Neptune pasted back onto the prior Ir stretched image,
Steve
sfugardi
Reged: 09/30/06
Loc: CT
      #6037488 - 08/20/13 11:28 PM Attachment (3 downloads)
Here's a 4000frame restack out of the 8403frames. The detail is not much different from the last 2K stack and does not seem to line up with the expected belt direction
Steve
3 registered and 9 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
