Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
Cg-5 goto problem
      #6044415 - 08/24/13 11:38 PM
I got a cg5 that has work very well since I got it about five mos ago.
Last time I tried it wouldn't boot up and stated that there was an error booting up. Does anyone have an idea as to what happened and how to fix it w/o having to send it back?
Clear skies
Itz
SKYGZR
Reged: 08/14/09
Loc: Planet Earth, Milky Way Galaxy...
Re: Cg-5 goto problem new [Re: Itz marcus]
      #6044424 - 08/24/13 11:45 PM
You will probably have to flash load the software again to the hand controller. Will have to have a serial port on the computer/laptop. The software is on Celestron's website.
http://www.celestron.com/c3/support3/index.php?_m=downloads&_a=view&p...
RTLR 12
Reged: 12/04/08
Re: Cg-5 goto problem new [Re: SKYGZR]
      #6044437 - 08/25/13 12:00 AM
This is the specific program that you need. Download it to your desktop.
Stan
http://www.celestron.com/c3/support3/index.php?_m=downloads&_a=viewdownlo...,7
Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
Re: Cg-5 goto problem new [Re: RTLR 12]
      #6044463 - 08/25/13 12:23 AM
Can you buy the cable anywhere, say staples or does one have to buy it from an astronomy dealer?
RTLR 12
Reged: 12/04/08
      #6044476 - 08/25/13 12:32 AM
You can buy this one from OPT that is a sure thing to work correctly or you can get some advise from some others here that may save you some money, but it may not work.
Stan
http://www.optcorp.com/celestron-usb-to-rs232-converter.html
cn register 5
Reged: 12/26/12
      #6044645 - 08/25/13 03:33 AM
Mike Swanson's NexStar site http://www.nexstarsite.com/ has details of the serial port connector, it's the one with the small 4 pin connector that fits in the base of the HC. This will help if you want to make one.
The cable has to be specific for the Celestron because there's no standard for the 4 pin connector and 24 different ways to connect it.
Chris
frito
Reged: 10/05/12
Loc: Fremont, CA
Re: Cg-5 goto problem new [Re: cn register 5]
      #6044670 - 08/25/13 04:35 AM
yea you can make one if your even remotely handy with electronics/electrical/wiring etc. its pretty simple. all you really need is a normal serial cable and an old school wired phone handset cord (it is the same as the 4 pin connector on the HC) some electrical tape, a multimeter to continuity test and if you want to make a decent one solder and an iron but that is optional really.
then you just splice the two cords together, just don't do what i did and get mixed up with what end of the serial cable you need i did and ended up having to get a gender changer when i made a serial cable for my camera shutter control lol.
here is the pinouts
http://www.nexstarsite.com/PCControl/RS232Cable.htm
RTLR 12
Reged: 12/04/08
Re: Cg-5 goto problem new [Re: frito]
      #6044726 - 08/25/13 06:27 AM
You guys are only making the hand controller end. You still need the SR232 to USB adapter that I posted. It takes both cables to complete the connection to a computer unless your computer has a serial port. Here is the Celestron equivalent to the cable you are suggesting the OP makes. They are supplied with the mount.
http://www.optcorp.com/celestron-rs-232-cable-for-nexstar-cge-mounts.html
The RS232 to USB adapter w/diver is the other cable.
Stan
frito
Reged: 10/05/12
Loc: Fremont, CA
      #6044756 - 08/25/13 07:39 AM
Stan is correct, unless you have a computer with a serial port and most made the last 4+ years do not you will need a USB to Serial adapter and not all of them will work correctly but most should. if you have a local computer or electronics store they should carry one and are pretty cheap, usually around 10-20 dollars or you can buy everything he linked that is guaranteed to work.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #6044915 - 08/25/13 10:22 AM
radio shack
Kasey
RTLR 12
Reged: 12/04/08
Re: Cg-5 goto problem new [Re: dragonslayer1]
      #6044983 - 08/25/13 11:09 AM
Do you know which RS232/USB adapter from Radio Shack works for sure?
Stan
cn register 5
Reged: 12/26/12
      #6045013 - 08/25/13 11:26 AM
My recommendation is a FTDI based USB to RS232 adaptor. I find them to be reliable. The serial port name doesn't change if you plug it into a different USB port.
I find Prolific adaptors to be unreliable. I've got one that's OK with some programs but not another or through a hub, or with a longer RS232 cable, or after a Windows update.
Other people say the Keyspan adaptors are OK. I've never tried them.
The Edgeport adaptors are also good but expensive.
Chris
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #6045027 - 08/25/13 11:33 AM
No Stan, as been so long sense I've had mine not sure where I got it, may have come with scope, bought it used. I just used to use their components building stuff and get some things from there, knick knack stuff, and they are usually close by to all locations.
Kasey
Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
      #6069715 - 09/08/13 03:08 PM
I'm really frustrated. I bought the rs232 cable ( had to buy a serial cable adapter so now I'm 55 dollars down) I downloaded what I have to but I can't get the handset to programmable mode. It just says boot loader invalid pkg 0040. I presse both the info and undo button and nothing. Any help wld be greatly appreciated.
Clear skies
Itz
frito
Reged: 10/05/12
Loc: Fremont, CA
      #6069901 - 09/08/13 04:48 PM
from celestron's site word for word make sure you are doing it correctly.
"Keep the power to the telescope off. Hold down the INFO and UNDO buttons simultaneously. Turn on the power to the mount while still holding the buttons. Upon power up, release the buttons once you see the Initializing message. You will then see a Transmit Data message. Your hand control is now ready to be programmed using the HCupdate program you installed earlier."
in short, power is off, hold down both buttons (make sure you are pressing them good!) then power on the mount and realease the buttons when it says Initializing and it should go into programming mode. if it does not work the first time try again. if it fails and you are certain you are doing everything correctly you HC is bad or its software is too corrupted to get even into bootloader mode and you will need to buy a new or used HC.
frito
Reged: 10/05/12
Loc: Fremont, CA
      #6069905 - 09/08/13 04:51 PM
also on the note of USB to serial adapters, i've got two, neither are FTDI based and both work perfectly fine with my CG-5, the one i'm currently using is a super cheap "Rhino" brand from Fry's. it was a real pain to find the right drivers for windows XP but once i did it works perfectly. the actual chip used is a CH340 made by some random obscure chinese company.
RTLR 12
Reged: 12/04/08
      #6069946 - 09/08/13 05:13 PM
Itz,
Are you using the CFM program or are you using HCupdater?
Stan
Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
      #6070226 - 09/08/13 08:45 PM
Hi cfm doesn't work keeps saying error hcupdate can't move out of bootloading error!
RTLR 12
Reged: 12/04/08
      #6070229 - 09/08/13 08:48 PM
If you are under warranty, contact Celestron and see about exchanging the hand controller.
Stan
Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
      #6125620 - 10/08/13 06:35 PM
Thanx guys CFM work I just wasn't unzipping it and it wasn't working. I extracted it and the problem has been solved.
Clear Skies
Itz
15 registered and 31 anonymous users are browsing this forum.
