Observing >> Solar System Observing
Sarkikos
Reged: 12/18/07
Loc: Nyctophobia, Maryland, USA
Re: What to expect of Jupiter? new [Re: christheman200]
      #6032747 - 08/18/13 12:12 PM
Well, seeing started off good tonight, some of the best seeing in a long time. Saturn looked much better than I have seen it through my scope before, and I decided to take it to a dark sky site about 40 minutes away. Little did I realize/remember just how bad a nearly full moon would be on the seeing! We decided to just head straight home.
You don't need to go to a dark site for viewing planets! If you're just going to look at planets or the Moon, you can stay home.
It shouldn't matter if the Moon is nearly full or not if you're observing a planet, unless maybe the Moon is right next to the planet in the sky. Planets are not like deep sky objects. These are completely different animals. You need a dark site and a moonless night for DSO, but not for planets.
Also, the Moon has absolutely no affect on the seeing. Seeing is the level of turbulence of the atmosphere. But the Moon will limit how deep you can go, what will be the faintest objects you can see.
I should be ordering a glatter laser and tublug soon and will see how this affects my collimation accuracy/viewing.
These are good tools but more than you really need. A simple Cheshire/sight-tube followed by an autocollimator will do just as well if not better. The advantage to the Glatter laser and Tublug is that you can collimate in the dark with them.
Sarkikos
Reged: 12/18/07
Re: What to expect of Jupiter? new [Re: Sarkikos]
      #6032752 - 08/18/13 12:14 PM
In Maryland, we often enjoy better seeing during summer and fall. Winter and spring are usually worst for seeing here.
christheman200
Reged: 06/12/13
Loc: Toronto, Canada
      #6033326 - 08/18/13 06:02 PM
I went to a dark sky site after Saturn had set. We were going to go for some DSO observing, and honestly half of the sky wasn't too bad so we could have stayed but there were others that were supposed to come and none did, so it wasn't worth staying. By seeing I meant light pollution from the moon affecting viewing, I guess that word isn't really appropriate. I generally collimate once or twice while I'm outside and I don't want to have to shine a flashlight down the tube to do it. It's more expensive but it's worth it.
wfj
Reged: 01/10/08
Loc: California, Santa Cruz County
      #6038472 - 08/21/13 02:39 PM
You don't need to shine a light to collimate - simply look at a bright star (or Polaris if you'd like it to not move) and tweak to perfection.
Planetary is all about constant practice / repetition. You do this enough times, with best performance learned out of equipment and tweaking and skill, that when good seeing happens, it all comes together.
It's hard to have expectations met, because many things not under your control can go wrong. It might be a better strategy to not have expectations but to improve skills incrementally - not likely to come all at once.
Jupiter is a highly dynamic planet - from the last few mornings I've observed it, this pass is already showing a different story than last year. With my modest equipment/skills, watching the "fluid dynamics" of GRS passage, the combination/split of other spots, the short lived activity along the equator all exceed my expectations on a weekly/monthly basis.
Suggest along with Mike that you observe from home - to increase frequency. Also DSO's and Jupiter are "night and day" different - I keep them on separate schedules.
Here's to a nice Jupiter, then Mars, then Jupiter ... observing season.
Sarkikos
Reged: 12/18/07
Re: What to expect of Jupiter? new [Re: wfj]
      #6038930 - 08/21/13 06:44 PM
Agreed ... but not so much to perfection. IME a closer collimation than checking the diffraction pattern of a star can be reached by using a Cheshire/sight-tube and then stacking the donuts with an autocollimator. Unfortunately, that combination needs a fairly bright source of light.
When I'm observing planets at home, I collimate my solid tube 10" Dob inside the house before I set it up outside. If I'm going to a dark site, I collimate at home before I leave. I try to get there while there's still some light in the sky so I can tweak the collimation, just in case it was loosened in transit. If I arrive well after sundown, I'm out of luck. I don't have the tools to collimate in the dark. Then I would have to check the diffraction pattern of Polaris.
It gets complicated with a truss scope, which needs to be put together again everytime it's used. It needs to be collimated every time on site after it's fitted together. There's no getting away with a little tweak to the collimation, as with a solid tube scope.
In any case, if you set up the truss scope either at home or at the dark site while there's still some light in the sky, you don't need an artificial light for collimation. This would also allow the scope's optics plenty of time to cool.
If I were to buy a truss scope, though, I think I'd be sure to get a good collimation kit - maybe the Glatter laser and Tublug - that can be used after dark. I wouldn't want to arrive after dark at a remote site and have no way to collimate my truss scope. That would not be good.
christheman200
Reged: 06/12/13
      #6042969 - 08/24/13 04:50 AM
I'm picking up a glatter/TuBlug, and I will also need to solve my collimation locking problems before it arrives.
I didn't notice this before, but it now seems that my collimation locking screws aren't doing there job.
Cranking them all the way down, it still shifts when I move up and down, and this is a substantial shift.
I think I will need to install tougher springs to stop this issue, it should make the locking screws useless.
corpusse
Reged: 04/11/10
Loc: Mississauga, Ontario, Canada
      #6043348 - 08/24/13 10:48 AM
I only image, so I'm not quite sure why I'm reading this thread, but I'd like to point out the seeing in Mississauga is usually terrible to fair. Last year I did not get one real good Jupiter image despite trying many times. I got one good Saturn this year (the low alt didn't help).
I'm not really sure why but real good seeing seems to be very rare here.
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #6043793 - 08/24/13 03:15 PM
On Friday we at long last had clear skies at dawn and got my first look at Jupiter this season. Seeing was good and I was using a 5 XO and 7 XW barlowed to 175X-240X in my WO ZS-110. The two main belts and 3 others were sharp with a little detail and the polar hoods were easy to see. Europa, Ganymede and Callisto were the moons seen. In San Diego County seeing for lunar-planetary is often better on the coast than in the mountains or desert. David
Edited by dscarpa (08/24/13 03:24 PM)
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #6043809 - 08/24/13 03:24 PM
On Friday we at long last had clear skies at dawn and got my first look at Jupiter this season. Seeing was good and I was using a 5 XO and 7 XW barlowed to 175X-240X in my WO ZS-110. The two main belts and 3 others were sharp with a little detail and the polar hoods were easy to see. Europa, Ganymede and Callisto were the moons seen. David
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
Re: What to expect of Jupiter? new [Re: dscarpa]
      #6044033 - 08/24/13 06:20 PM
@ the OP,
There are already a lot of good pieces of advice about observing Jupiter in this thread so I'll try not to repeat them. An altitude of 35 is still pretty low and will definitely affect your ability to see detail in Jupiter's cloudtops, all other variables being equal.
The important thing is to keep trying. The good news is as the apparition progresses, Jupiter's altitude will increase. Now is the time to start training your eye to see detail. I was glad to read that you sketch--that's probably the best way to train your eye and sharpen your observing skills.
I suggest you sketch your observations even if you can't see any more detail than the 2 main belts. As time goes on, you will be surprised how much detail will reveal itself and your sketching skills will benefit from the practice as well.
Another suggestion--as far as magnification is concerned, the sweet spot for Jupiter is often 200x-260x. From your report, that is exactly the hole in your eyepiece collection. If your budget is tight, maybe you can borrow an ep from a friend in RASC that will yield that range in your scope. BTW, that 12" scope should provide you with some fine views of the King and the larger aperture makes color easier to see, in my experience.
Good luck with your Jupiter observations and please share your sketches here and/or in the Sketching Forum.
@ dscarpa--congratulations on your first look this apparition and thanks for the report. Jupiter is never the same from one apparition to the next--looking forward to my own first look.
Best regards to all.
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #6045227 - 08/25/13 01:46 PM
I find that to be the sweet spot power wise for Jupiter as well. View at dawn. Last night my ZS was only pulling in 2 fuzzy belts when it wa low. Later on it was 5 belts and 3 moons but no spot. Next session my IM-715 or C9.25 is going to get a crack at it. David
christheman200
Reged: 06/12/13
Re: What to expect of Jupiter? new [Re: corpusse]
      #6046379 - 08/26/13 03:55 AM
Yeah, we normally have *BLEEP* weather here, but we've had a decent stretch for the past two weeks.
I haven't been able to make a sketch yet because of bad turbulence for the last while.
christheman200
Reged: 06/12/13
Re: What to expect of Jupiter? new [Re: Special Ed]
      #6046380 - 08/26/13 04:00 AM
@ the OP,
I will definitely try to sketch all of my Jupiter observing sessions in the future!
Of course, the seeing got worse progressively after that one good night, so no sketch yet.
I'm looking at getting a 6mm when it is possible. I fear I've already asked around for too many things in my local RASC (mount, barlow, diagonal, you name it!).
However, a friend, Jo, may have an eyepiece I could borrow for a while but I don't want to bother anyone until our next viewing session.
TG
Reged: 11/02/06
Loc: Latitude 47
Re: What to expect of Jupiter? [Re: christheman200]
      #6047122 - 08/26/13 02:38 PM
However, when I push it to 340x with my ultima barlow it loses almost all of it's detail, and even the bands are hard to make out. This is odd because seeing was great, no wind no nothing. Jupiter was about 35 degrees up (a rough guess). Is this to be expected? Or is my barlow deteriorating the view? Could it also be other parts of the optical chain not being up to snuff?
Jupiter, unlike the other planets, doesn't take power well. I've noticed that that an exit pupil of about 1mm gives the most pleasing view, large enough yet containing a lot of details. Higher powers will make the lower contrast features on Jupiter, such as ovals and festoons, harder to make out. I'm not sure why this is the case. It may be that the image dimming at higher powers causes the eye to lose its ability to discern low contrast features.
The power for a 1mm exit pupil is easy to calculate: it's the same as your aperture in mm.
If you know how to star test, do it just when you are observing Jupiter. It'll quickly tell you if everything is ok with your optical train. The things to watch for are seeing, collimation and thermals. If all three are ok, then you can worry about other possible problems.
Tanveer.
Scott in NCAdministrator
80mm Refractor Fanatic
Reged: 03/05/05
Loc: NC
Re: What to expect of Jupiter? new [Re: TG]
      #6049677 - 08/27/13 09:08 PM
And another easy to remember formula is that the focal length of the eyepiece needed to produce a 1mm exit pupil is the same length (in mm) as the f/ratio of your scope. E.g., an f/6 scope would need a 6mm eyepiece to give you an exit pupil of 1mm.
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #6050444 - 08/28/13 10:56 AM
Sunday AM the mak showed about the same as the ZS. This AM I had the 9.25 with a 10 XW for 260X and there was quite bit more detail including the GRS! That side of Jupiter does have more to see. As to the spot it didn't jump out at you but it was easy. David
Edited by dscarpa (08/28/13 10:58 AM)
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #6050452 - 08/28/13 10:58 AM
Sunday AM the mak showed about the same as the ZS. This AM I had the 9.25 with a 10 XW for 260X and there was quite bit more detail including the red spot! That side of Jupiter does have more to see. As to the spot it didn't jump out at you but it was easy. David
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #6054619 - 08/30/13 03:15 PM
This AM I was viewing Jupiter with my IM715 using a 12 Delos for 250X with very good conditions. All four different colored moons were there with Io's shadow black and sharp but rather small. The GRS was coming over the limb and 5 belts with quite a bit of detail in them and the polar hoods was visable! What to expect of Jupiter? It would appear to be a lot given good conditions! David
christheman200
Reged: 06/12/13
      #6060128 - 09/02/13 10:15 PM
I have a post up in the reflector forum, but I might be able to get some help here too. It is now very obvious that my collimation locking screws are not doing anything or possibly making my collimation worse. No matter what I do the collimation drifts a LOT past 75 degrees up. Does anyone know of a possible fix? When I posted my thread originally, it was about shimming my mirror but it quickly turned into asking about my collimation locking problem. At first, I thought I had finally nailed the problem as a loose spider or secondary, but once that was dealt with it was clear that the mirror was drifting. I am using a collimation cap and once I get the dot centred at around 45 degrees, I tighten up the collimation locking screws. However, no matter how tight the locking screws get they do not stop the dot from drifting around 2-4 donut diameters across the surface of the mirror. Most drift is noticeable past 75 degrees upwards, with some noticeable past 25 degrees downwards. Any help is appreciated, thanks.
1 registered and 3 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), star drop, dr.who
