Silicon Owl
Reged: 11/25/05
Loc: Waimea, Hawaii 20N
Some Notes on Autoguiding the ZEQ25 with an STi new
      #5955106 - 07/04/13 06:27 PM
I put together a posting with my notes and experience in using an SBIG STi and iOptron ZEQ25. There are some issues... The ST4 port on the ZEQ25 is not directly compatible with the STi. Pinout is fine, voltages are another issue.
Autoguiding the iOptron ZEQ25 with an SBIG STi
Astronewb
Reged: 09/19/11
Loc: Connecticut
Re: Some Notes on Autoguiding the ZEQ25 with an STi new [Re: Silicon Owl]
      #5955247 - 07/04/13 08:37 PM
Very nice post on your link Andrew. I don't think you'll need RA and DEC max's of 2000ms on this mount though?
It will usually run almost box stock, 1000 and 150 with good results, but I usually get the best at less than 750 in RA and DEC.
I guide with a Lodestar and 50mm Borg @ 250mm, so my results may be a little tighter than typical.
M51 Phd by Astronewb2011, on Flickr
Good luck with the ST1, keep us posted.
Pau;
ramasule
Reged: 04/12/12
Re: Some Notes on Autoguiding the ZEQ25 with an STi new [Re: Astronewb]
      #6044622 - 08/25/13 02:59 AM
Can you please post your pinout... I was unable to get a couple cables, or the ascom driver to guide my scope this evening. Guide camera was sbig 2000xm.
The ascom driver connected and I was able to move my scope but for some reason it wouldnt work in the guide programs.
I tried maximdl 5 and phd.
Also please post your phd settings.
Thank you,
Derek L
rsbfoto
Reged: 06/10/06
Re: Some Notes on Autoguiding the ZEQ25 with an STi [Re: ramasule]
      #6047250 - 08/26/13 03:56 PM
Here is an image of the Pin Out of the ST-4 guiding port of the ZEQ 25GT
and it is NOT optocoupled on the circuit of the ZEQ 25GT mount.
This is an important thing as if both sides do have a different ground you can get Ground Loop problems. Maybe the STi is not optocoupled at the output. I had many many problems many years ago with 2 SBIG cameras due to this optocoupling topic until I decided to build a optocoupler adapter and then it worked fine with the Losmandy Gemini System.
I have been experimenting with a Sol guider and due to past experience I have integrated for the switching for each line an Optocoupler.
http://astroforo.net/astro/Sol/solseeker/RS-olGuider-02.jpg
I am switching the lines directly from my circuit. Just pull down any line 3,4,5 or 6 against ground and the mount will move accordingly.
Edited by rsbfoto (08/26/13 04:01 PM)
22 registered and 43 anonymous users are browsing this forum.
