Pages: 1 | 2 | 3 | (show all)
Jmax
Reged: 09/28/10
Loc: Alabama
Terrified of Cleaning Corrector new
      #6046815 - 08/26/13 11:31 AM
My pride and joy C9.25 needs its corrector cleaned. It has pollen on it. It is not a lot, but I know it needs to be removed. I am actually more 'petrified' than 'terrified' at the thought that I could scratch it or damage it. I've tried a blower brush, and it does nothing.
I know pollen is 'grainy,' so I can't see how I can remove it without scratching, since it won't blow off. I know that others say to use windex and lens papers, or alcohol with a little Dawn. I just can't seem to overcome this fear that I will mess it up. It is so little that it doesn't effect the view, but I know it is damaging if left on the corrector.
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Re: Terrified of Cleaning Corrector new [Re: Jmax]
      #6046839 - 08/26/13 11:42 AM
It's really not that scary. I bought this kit and it works just great! Just follow the instructions and you'll be good to go. Just so you know, the coatings on a corrector are quite robust, kinda' like your eyepieces. It's not like cleaning a mirror.
David
Jmax
Reged: 09/28/10
Loc: Alabama
Re: Terrified of Cleaning Corrector new [Re: David Pavlich]
      #6046844 - 08/26/13 11:45 AM
That already makes me feel much better! Thanks David.
John
JoeR
Reged: 03/07/10
Loc: Columbus, OH
      #6047103 - 08/26/13 02:27 PM
Yes I just did mine with a home made solution of mostly distilled water and a little Windex & isopropyl alcohol cleaned with a microfiber cloth. Looks real nice now and even passes the flashlight test.
mgwhittle
Reged: 08/24/11
Loc: Chattanooga, TN
Re: Terrified of Cleaning Corrector new [Re: JoeR]
      #6047163 - 08/26/13 02:58 PM
Go to an art supply house, buy a wide flat white nylon Loew Cornell Artist brush. I am being specific about the brush because the white nylon brushes are very soft and will not scratch your corrector. Clean the brush with dish detergent and water and let dry thoroughly. Take said brush and while using a blower bulb gently brush off and blow the pollen away.
Then clean using a recommended procedure. That's how I do it.
Qwickdraw
Reged: 03/03/12
Loc: Ann Arbor, MI
Re: Terrified of Cleaning Corrector new [Re: mgwhittle]
      #6047336 - 08/26/13 05:01 PM
Its scary until you do it the 1st time. best to get that pollen off now.
      #6047378 - 08/26/13 05:25 PM
Don't worry! Despite the recommendations of Doc Clay's method, and using several other methods, I've concluded that if you're really picky like I am, it is IMPOSSIBLE to get a corrector back to day-1 levels of cleanliness. Every method I've ever used, and I've used most of them, has left residues of some kind on the corrector. Around the secondary and at the edges are particularly hard to get clean.
My advice - do the best you can. Don't expect perfection. Use and enjoy the scope no matter what results your method returns. As long as you use a soft brush and blower bulb to dislodge any big pieces, you're no going to hurt the glass or coatings using any modern cleaning solution - Zeiss, ROR, Pursol, etc.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Terrified of Cleaning Corrector new [Re: Qwickdraw]
      #6047380 - 08/26/13 05:26 PM
I bought the same kit as David. Works great! It's not as difficult as you think it will be. You just have to decide it needs to be done.
Joe Aguiar
Reged: 02/10/07
Loc: none of your buss
Re: Terrified of Cleaning Corrector new [Re: Raginar]
      #6047591 - 08/26/13 07:46 PM
ya I was gonna say what david said the coating are real durable I mean don't use sandpaper but normally cleaning of it shouldn't hurt it
joe
ewave
Reged: 05/16/09
Loc: northwest NJ
Re: Terrified of Cleaning Corrector new [Re: Joe Aguiar]
      #6047631 - 08/26/13 08:12 PM
I just cleaned my C9.25 a month ago. I also used the same kit as David. I clean my corrector about once every two years, depending on the pollen seasons of that year. I've gotten so good I can clean it and dry it within 20 minutes now.
Jmax
Reged: 09/28/10
Loc: Alabama
Re: Terrified of Cleaning Corrector new [Re: ewave]
      #6047779 - 08/26/13 09:43 PM
Thanks guys! I'm going to do it this weekend. It's been in my observatory and my new 80ed and 102gt are arriving this week to go in there as my viewing/photography setup. So I need to clean the 9.25 before putting it back in its case. I think I like the sound of the Televue method as it minimizes touching. Have any of you used this method? I'll report back after I do it.
A. Viegas
Reged: 03/05/12
Loc: New York City/ CT
      #6047792 - 08/26/13 09:52 PM
A bit over a year-ago when I resurrected my interest in Astronomy, I had my 1993 Celestar C-8 sitting in a box for nearly 20 years... the corrector had gunk and the primary also had something growing there... Luckily, fellow CN member "Orion61" offers a cleaning service for a very low and reasonable price. I shipped it to him, he cleaned it, re-greased my focuser and flocked the inner tube. My Celestar C-8 has excellent optics and its like brand-new. I would never want to take it apart, but then again I am all thumbs... My advice, send it to Larry...
Al
Transmographied
Reged: 05/18/05
      #6047854 - 08/26/13 10:30 PM
joe
Some 600 grit wet sand isn't too bad. What I do for around the edges is get a handful of cotton swabs and as you sweep around the edges with the swab, rotate it. I said a handful and that's because when I do it, I allow one rotation of the swab and toss it. An 11" SC takes a LOT of swabs.
David
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Terrified of Cleaning Corrector new [Re: jrbarnett]
      #6047870 - 08/26/13 10:39 PM
Jim, I agree totally. For some reason, and despite vigilant efforts with various processes, it does seem impossible to get them back to factory clean. I really don't understand why that is nor why the flashlight test (which we should ignore?) makes us cringe. I've even tried to clean to the flashlight test standard to no avail. We love our optics, so such attention to them has a diminishing return way up the time and effort scale.
Qwickdraw
Reged: 03/03/12
Loc: Ann Arbor, MI
Re: Terrified of Cleaning Corrector [Re: Asbytec]
      #6048257 - 08/27/13 06:49 AM
One thing I have read which makes sense but I cannot say I have examples as I have only cleaned one corrector. If you can be choosy do it on a day of low humidity or in an well air conditioned home and you well have much less streaking.
Paul Schroeder
Reged: 06/05/03
      #6048402 - 08/27/13 09:00 AM
joe
David
I agree with David. I've found the Q tip approach works well for the final stubborn small spots. I'll often combine it with breathing on the glass to fog it up slightly prior to the final Q tip wipe.
It makes it fairly easy to eliminate most cleaning spots.
Paul
REC
Reged: 10/20/10
Loc: NC
      #6048446 - 08/27/13 09:25 AM
Jim, good advise and sure would like to get it like the day I got it, but can see it ain't gonna happen. I would also like to get rid od all those little spots from the dew. Unfortunately I waited too long to get a dew shield at first and went through to many dew cycles.
As far as Zeiss goes, can I use those little wipes they have, works great on my glasses?
Bob
Full Sun
Reged: 11/19/06
Loc: Ontario
Re: Terrified of Cleaning Corrector new [Re: REC]
      #6051039 - 08/28/13 04:47 PM
I will soon have to address the numerous water spots on my nearly new C-14 corrector to improve my prevailing, ongoing daily mood.It is a long story but I was in the final stages of my initial All-Star Alignment procedure- after two hours of restarts(center Altair in the eyepiece- a 2 minute procedure) when it suddenly clouded over. I was seeing glimpses of the bright star and hanging on until I realized that it started to rain in my observatory. So , that was a first for me! No harm done essentially but numerous H2O deposits were left all over on the corrector. I left it uncovered to dry and headed for bed at 2:30 AM a bit rattled.
Anyhow, after some research into cleaning ideas, I don't think Rolands' finger method with saliva is going to work; the scale of the deposits is too broad. I wonder if anyone has a word of advice on how to proceed working with a clean corrector and what cleaning solution might be more effective for these numerous tiny pin points that have invaded my glass?
Hijacking the thread a little but my motive is for the collective good.
Jerry
Edited by Full Sun (08/28/13 06:31 PM)
Binojunky
Reged: 12/25/10
Re: Terrified of Cleaning Corrector new [Re: Full Sun]
      #6051089 - 08/28/13 05:10 PM
Pollen will if left on over time etch into a coating, nuf said,DA.
HowardK
Reged: 10/20/10
Re: Terrified of Cleaning Corrector new [Re: Binojunky]
      #6051096 - 08/28/13 05:15 PM
The genuine Zeiss lens wipes work great for me
Finish off with my breath and pentax micro lens cloth
11 registered and 15 anonymous users are browsing this forum.
Moderator:  Starman27, kkokkolis
