Seanem44
Reged: 09/22/11
Loc: Woodbridge, VA
Are savings on a CG-5 ASGT worth not getting AVX? new
      #6048262 - 08/27/13 06:55 AM
I have a decision coming up soon. I need a mate for my AT65EDQ in the form of a mount. I have posted questions about the AVX vs. the ZEQ25. They seem pretty evenly matched. Now I have a different question.
The CG5s are at a very very enticing price. Am I missing out on much if I take one of those over the AVX (or ZEQ)? I have seen spectacular results with the CG5.
The bottom line is I am a noob in imaging. Well, not a complete noob. I do widefield milky way, have gone as far as I can, and am moving on up. Does the AVX offer anything to a noob in DSO imaging that the CG5 will not that is make or break or will significantly help my learning curve?
Thanks.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Are savings on a CG-5 ASGT worth not getting AVX? [Re: Seanem44]
      #6048323 - 08/27/13 08:07 AM
AVX. Because of integer gearbox and permanent PEC.
ZEQ25 doesn't have permanent PEC.
For these reasons, for imaging I'd spend the extra bucks for the AVX unless weight was the main priority in which case the ZEQ25 would be my choice.
Seanem44
Reged: 09/22/11
Loc: Woodbridge, VA
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: orlyandico]
      #6048335 - 08/27/13 08:18 AM
Weight is not an issue at all. I'm 32 and in relatively good shape.
I also like the 2 inch legs over the ZEQ which charges more.
I guess I will have to wait a bit, as funds are available yet and the AVX goes back up to full price with the sale ending at the end of August.
Thanks for the insight though. I am 80% leaning towards the AVX right now. Hopefully some more of those one-off issues don't crop up on this forum.
A. Viegas
Reged: 03/05/12
Loc: New York City/ CT
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: Seanem44]
      #6048630 - 08/27/13 11:22 AM
Sean if you are going to use it for your small refractor I think the CG5 will be fine. I used to own one and using it with my C8 and auto guiding I easily could get 2-3 min exposures. Using just my C80ED I could go almost 60s with no auto guiding and passable polar alignment. If I auto guided with the small refractor I bet I probably could get 5 mins....
I moved up to the cgEM for the weight... But I liked how lightweight and easy to move the CG5 was. There are decent deals on this used... I sol mine for $450. I think around that price you can find a decent one... I can not argue that it's better than the AvX but I don't think the AVX is 200% better either...
Just my 2c
Al
frito
Reged: 10/05/12
Loc: Fremont, CA
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: A. Viegas]
      #6048959 - 08/27/13 02:16 PM
i get 2 minute unguided exposures at very high sucess rate with my WO 66SD (388mm fl) on my CG-5 just using the all star polar alignment. for that scope it will work fine. the AVX is a better mount but if you compare ~400 for a used CG-5 vs 700-800 for a new AVX if i was spending that much i'd go for a used Sirius or Atlas class mount, something that is better than the AVX and costs around the same used as the AVX does new.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: frito]
      #6049074 - 08/27/13 03:18 PM
I am using a CG-5 ASSGT with a C9.25 and video A/P. Is a lot of weight but am happy. Use it unguided and eye ball polar align. Kasey
Madratter
Reged: 01/14/13
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: dragonslayer1]
      #6049377 - 08/27/13 06:05 PM
For AP, if you are never going to upgrade that AT65EDQ then the CG-5 is adequate. However, if you are going to get into anything with longer focal lengths down the road, I would hold out for at least something as capable as the AVX or ZEQ25.
Now for visual, the CG-5 is good even with a C8 on it. I did AP with a C8 on my CG-5 at f/6.3, but it was an exercise in frustration.
cn register 5
Reged: 12/26/12
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: Madratter]
      #6049399 - 08/27/13 06:17 PM
I find the AVX much easier to set up for guiding and imaging than the CG5.
People have been saying that they would like things such as RTC, integer gears and PEC added to the CG5 and saying they would pay for this.
Now they have the option to have these things they go for the CG5 because it's cheaper.
Chris
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: cn register 5]
      #6049490 - 08/27/13 07:20 PM
Well you know what Roland says...
The three most important things for astrophotography are the mount, the mount, and the mount.
I would disagree about used Sirius or Atlas vs AVX. The Celestron mounts have better software. Also there is the weight. You say its not an issue but weight will weigh you down (pun intended) and can be demotivating.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6049582 - 08/27/13 08:11 PM
If you want to dip your feet in, a CG5 gives you everything you could ever want as long as you don't try to stack a 12" SCT on it.
Frankly, the other mounts close really offer very little reason to get them. The late model cg5 is a beast. There is nothing on an AVX that isn't on a CG5.
Bill McNeal
Reged: 10/07/07
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: Raginar]
      #6050729 - 08/28/13 01:38 PM
Also remember the AVX is rated 5 lbs. less in payload capacity than the CG-5, 30 vs. 35 lbs. Could be a dealbreaker depending on your setup.
FacEngRet
Reged: 02/27/13
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: Bill McNeal]
      #6050753 - 08/28/13 01:56 PM
I have both mounts and have used both with 6", 8" and 11" SCT. My experience tells me that the 30 pound weight rating on the AVX is a conservative rating and the 35 pound rating on the CG5 is optimistic.
Moromete
Reged: 02/15/12
Loc: Romania
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: FacEngRet]
      #6051063 - 08/28/13 04:58 PM
Is AVX much better than CG5 for AP and GOTOs with a C8/ C11 at F6 on it or not really? If yes, why?
Seanem44
Reged: 09/22/11
Loc: Woodbridge, VA
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: Moromete]
      #6051506 - 08/28/13 09:10 PM
I plan on using the AT65 with a guider. That's it. At this point in my life, hard core AP will have to wait a while. Ill stick with the CPC 925 for viewing. No more upgrades for at least a decade after I get the mount. No new scopes for that same time.
Ranger Tim
Reged: 03/25/08
Loc: SE Idaho, USA
      #6051632 - 08/28/13 10:45 PM
"No more upgrades for at least a decade after I get the mount."
This is heresy!
bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: Ranger Tim]
      #6051642 - 08/28/13 10:53 PM
I sold a CG5 to get the AVX for imaging with a C8 and it helped a lot. With that said, the CG5 did work and with a 80mm refractor was more than adequate. The capacity of the AVX is higher than the CG5 - I don't care what the published specs say. But it's close and your scope and guider are well within limits. The only downside of the Cg5 is that, on a lot of thme (and mine), there was a ton of backlash in Declination which inhibited guiding in Dec. But with good polar alignment and guiding in RA (essentially PEC), I got up to 10 minute exposures at 400mm.
If money were no object, I'd go with the AVX for sure. But you say money is an object, and it most certainly is. From what you've said, go with the CG5 on sale and enjoy it.
-Oklahoma State, class of 1993
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Are savings on a CG-5 ASGT worth not getting AVX? new [Re: bunyon]
      #6051703 - 08/28/13 11:36 PM
But... 10 years of no upgrades argues for the best you can afford now...
frito
Reged: 10/05/12
Loc: Fremont, CA
      #6051800 - 08/29/13 01:30 AM
It's not exactly hard to adjust the mechanical backlash on the CG-5, i've adjusted the backlash on my club's Sirius mount and my CG-5 the Sirius had much worse backlash and was harder to adjust, the CG-5 was pretty easy to adjust. there are guides out there on the net but if you need help or have a question feel free to ask. i would not dare say it has zero backlash, thats impossible esp on a design like this but the vast majority of my backlash on my CG-5 is from the motor's interal gearboxes post adjusting mine.
frito
Reged: 10/05/12
Loc: Fremont, CA
      #6051803 - 08/29/13 01:33 AM
if that is all you plan to use the mount for for now the CG-5 will suffice, a 9-1/4" SCT visual is starting to push the mount but it will handle it and for AP you can easily get by on it with your AT65 with or without a guider, in fact i'd recommend starting off without one because it will make setup more simple with setup and software stuff until you get some time in to learn your setup.
cn register 5
Reged: 12/26/12
      #6051901 - 08/29/13 03:49 AM
Not true.
the AVX has a RTC, PEC, integer gearboxes and drive software that avoids the cogging issue. It's also more sturdy.
Chris
19 registered and 35 anonymous users are browsing this forum.
