careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
Recommendations for Comet Plotting Software new
      #5970493 - 07/14/13 02:33 PM
When Comet ISON makes its perihelion dive on Thanksgiving Day, I would like to be able to observe it safely with a tracking sun-shield that keeps its edge close to the comet nucleus on the sun-ward side.
To do this I need to be able to accurately predict the position of both the sun and the comet in my sky - down to the very fast perihelion pinturn (I expect the nuclear region becomes non-observable at closest approach).
Being able to produce plots of the apparent comet movement in a sun-centered view as well as plots of both sun and comet in the sky would be useful.
Any recommendations for the best software for this purpose?
Such a tracking sun-mask system would be useful for daytime observing of Mercury and Venus also.
Matthew Ota
Hmmm
Reged: 04/30/05
Loc: Los Angeles, California
Re: Recommendations for Comet Plotting Software new [Re: careysub]
      #5971602 - 07/15/13 02:30 AM
I use TheSky to track comets and asteroids. TheSky enabled me to take this image of Comet 2006P1 McNaught in broad daylight:
OCA Web Gallery: Comets
Reged: 07/06/07
      #5971918 - 07/15/13 09:49 AM
Almost any software can do this, including the (free) Cartes du Ciel.
PhilCo126
Reged: 01/14/05
Loc: coastline of Belgium
Re: Recommendations for Comet Plotting Software new [Re: rmollise]
      #6045101 - 08/25/13 12:26 PM
Euh... Stellarium can't ?
Reged: 07/06/07
Re: Recommendations for Comet Plotting Software new [Re: PhilCo126]
      #6045455 - 08/25/13 04:10 PM
Oh yes it can. You may be using an old version, or just haven't looked at the routine, which is found in "plug-ins"...
It wouldn't be my choice for comets, and it would be easier with Cartes, but you can do it well enough.
Edited by rmollise (08/25/13 04:11 PM)
Mark9473
Reged: 07/21/05
Loc: 51N 4E
      #6045648 - 08/25/13 06:10 PM
Isn't this the same problem as we had with that NEO passage early in the year? The commonly available orbital elements, that these planetarium programs have access to, won't correctly calculate a passage through a strong gravitational field. I thought at the time SkySafari stood out as having a (slightly simplified) algorithm for calculating the effects of the gravitational pull.
Whatever program you use, you'd have to check that the orbital elements it imports are calculated to include the close passage to the Sun.
btschumy
Vendor - Simulation Curriculum
Reged: 04/13/04
Loc: Longmont, CO, USA
Re: Recommendations for Comet Plotting Software new [Re: Mark9473]
      #6045758 - 08/25/13 07:05 PM
Mark,
You are correct that SkySafari has special code to calculate the perturbed orbit of a NEO as it passes close to Earth. This is needed because the object is not actually orbiting Earth. However, because ISON does orbit the Sun, it is not being perturbed and the standard orbital elements should give an accurate prediction.
Bill
Edited by btschumy (08/25/13 07:07 PM)
BSJ
Reged: 12/22/08
Loc: Grand Isle, VT
      #6047466 - 08/26/13 06:11 PM
If you doubt the position, just download the latest data.
Easy pieesee with Stellarium
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
      #6050979 - 08/28/13 04:15 PM
Seconded! Typically I just go straight to MPC and get the ephem!
PhilCo126
Reged: 01/14/05
Re: Recommendations for Comet Plotting Software [Re: Mike Phillips]
      #6052786 - 08/29/13 03:21 PM
Software packages theSkyX and SkyMap Pro are regularly mentioned as comet plotting software of choice... to help decide how long a subexposure at the comet's motion can be...
Reged: 07/06/07
      #6054095 - 08/30/13 10:05 AM
TheSky is fine. I don't note that it's any better than CdC in this regard, though, and, frankly, I find the comet tools in TheSky 6 not as good. Plus, I just fraking like "free."
5 registered and 10 anonymous users are browsing this forum.
Moderator:  richard7, kkokkolis
