vferrari
journeyman
Reged: 06/18/13
Attaching Camera Directly to SE or SLT Mount
      #6055689 - 08/31/13 09:16 AM
I have an SLT and a 4/5se mount. I am looking for the best way to attach a camera directly to the mount vertical arm slot. Ideally I like to use the built in wedge on the 4se mount and polar align and track. I recognize that in this config I would be limited to <1min exposures without a guide scope, but wanted to keep it simple as I get my feet wet.
This would be an alternative to piggybacking to the OTA because I have not figured out how to do so with the my smallish 127 SLT MAK tube - unless someone has advice on how to do that. Would the Celestron piggyback adapter bracket sold for the 5/6/8se work on the 127 SLT MAK?
Thanks in advance for any help you can provide.
Midnight Dan
Reged: 01/23/08
Re: Attaching Camera Directly to SE or SLT Mount new [Re: vferrari]
      #6055738 - 08/31/13 09:57 AM
If you have an Orion/Synta sized finder dovetail shoe on your scope, you can use this to attach a camera via the finder dovetail:
http://www.scopestuff.com/ss_sbcm.htm
To attach in place of the OTA as you suggest, you can just get a short piece of vixen-size dovetail rail and bolt the camera to it. A camera's tripod screw is a 1/4-20 thread so you can get a bolt with that thread size at any hardware store. Here's a source for dovetail rails:
http://www.scopestuff.com/ss_eqdb.htm
-Dan
vferrari
journeyman
Reged: 06/18/13
Re: Attaching Camera Directly to SE or SLT Mount new [Re: Midnight Dan]
      #6055940 - 08/31/13 12:08 PM
-Dan
Dan,
Thanks so much for the link to the finder dovetail mount adapter. That item reminded me of a small clamp mount I was using for a webcam that should provide enough adjustablity, yet rigidness to prevent vibration to allow me to piggyback my digicam to the OTA by clamping onto the finder mount. Much appreciated.
Arctic_Eddie
Reged: 12/30/07
Loc: St. Petersburg, FL
      #6056267 - 08/31/13 03:03 PM
Here's some ideas. Check the second generation camera mount near the end.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/4933017/page...
vferrari
journeyman
Reged: 06/18/13
Re: Attaching Camera Directly to SE or SLT Mount new [Re: Arctic_Eddie]
      #6056321 - 08/31/13 03:51 PM
Arctic Eddie,
Thanks for the link to that nice SE mount AP camera setup. When I get a "real" DSLR (I'm working with a superzoom with significant limitations, but hey I'll push it to its limits) I will have plenty of ideas for setting up my AP rig.
Pharquart
Reged: 11/11/09
Loc: Southwest Minneapolis Metro
      #6058421 - 09/01/13 10:36 PM Attachment (17 downloads)
And if you're really cheap (like me) and have a table saw (like me) you can make your own dovetail. Rip a piece of 3/4" thick wood (a pine 1x4 will work fine) with 15 degree angles, about 1-7/8" on the long side of the resulting trapezoid. My 8SE mount accepts a wide variation in width, so if you miss the 1-7/8" you should still be fine. However, I needed to add a spacer between the camera and the dovetail so the camera would clear the clamp. (The rail pictured was made in a hurry out of bad scrap, including one piece that wasn't exactly square, or free of cracks!)
If you're mounting something heavier, use oak.
Brian
vferrari
journeyman
Reged: 06/18/13
Re: Attaching Camera Directly to SE or SLT Mount new [Re: Pharquart]
      #6067535 - 09/07/13 10:25 AM
Brian,
Thanks for the pics of the DIY wooden dovetail. I'm a terrible carpenter but even I could probably pull that off. Thanks for the additional ideas.
7 registered and 19 anonymous users are browsing this forum.
Moderator:  Brian Risley, panhard, Mitchell Duke, mayidunk
