m1618
Reged: 09/18/12
Loc: Orange County - CA
LXD55 metal axis locks - clutch question
      #6056674 - 08/31/13 08:36 PM Attachment (5 downloads)
Perhaps I should have posted this under ATM/DIY. I found a perfect replacement for those plastic tabs aka axis locks on the LXD55/75 mounts. It's actually a universal shower lever (hot and cold) and as long as you don't mind the little "H" and "C" on them, they're quite durable!
Question: is there an extra bushing of sorts in the RA (where the knob screws in)? I must have dropped a piece in the dark because now the lock doesn't seem to reach the core to tighten. What would I need?
fetoma
Reged: 09/26/06
Loc: Southern New Jersey
Re: LXD55 metal axis locks - clutch question new [Re: m1618]
      #6056822 - 08/31/13 10:31 PM
You lost one of the clutch pads that fit between the worm and the clutch knob screw face. It's a cylindrical piece that won't mar the worm when the clutch knob is tightened.
m1618
Reged: 09/18/12
Re: LXD55 metal axis locks - clutch question new [Re: fetoma]
      #6056848 - 08/31/13 10:58 PM
Aha! Friction brake pad of some sort huh? Any idea what that material may be? I suppose I can try a wooden dowel unless there's a better choice... please advise.
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6057032 - 09/01/13 02:49 AM
It's some kind of hard plastic. Don't use the clutch without it, you'll score the ring gear. Maybe a cutout from a milk jug will do.. I would avoid wood. It might splinter and then the bits will scatter around the ring gear and get stuck in the grease.
obin robinson
Reged: 10/25/12
Loc: League City, TX
      #6057198 - 09/01/13 07:22 AM
Go to the store and get a nylon screw which is about the same diameter. Trim it until it fits in the clutch friction pad area. It may take several attempts but it will work.
obin
25 registered and 44 anonymous users are browsing this forum.
