Speciality Forums >> Space Rocks
Kent10
Reged: 05/08/12
Difference Between these 2 MUONIONALUSTA new
      #6068535 - 09/07/13 09:04 PM Attachment (5 downloads)
These 2 have quite a different patina to them. Were they in different parts of the soil or was one treated? I am trying to figure out how they became so different. Thanks, Kent
Edited by Kent10 (09/07/13 09:06 PM)
Kent10
Reged: 05/08/12
Re: Difference Between these 2 MUONIONALUSTA new [Re: Kent10]
      #6068536 - 09/07/13 09:05 PM Attachment (5 downloads)
2nd
lee14
Reged: 12/19/09
      #6069162 - 09/08/13 09:54 AM
Muonionalustas are typically quite weathered, and therefore invite aggressive surface cleaning. Your two specimens which seem quite similar in size and shape have most likely been prepared differently. If you acquired them from different sources, that would certainly strengthen the case. I'm unsure about the lighter colored individual, but I'd guess chemical cleaning was involved, possibly something like phosphoric acid. The other has the look of being cleaned up with a wire wheel, then maybe coated with lacquer.
Lee
Edited by lee14 (09/08/13 09:55 AM)
Kent10
Reged: 05/08/12
Re: Difference Between these 2 MUONIONALUSTA new [Re: lee14]
      #6069195 - 09/08/13 10:12 AM Attachment (4 downloads)
Thanks for the info Lee. I wish these were mine but I have just been looking at these for sale here
http://www.ebay.com/sch/m.html?_odkw=meteorite&_sop=16&_osacat=3213&a...
And was curious. The shiny ones seem much more common. They do look like they might have a lacquer on them. They look shiny anyway compared to the other. Is that rust on the duller one? See pic. Thanks again.
Glassthrower
Vendor - Galactic Stone & Ironworks
Reged: 04/07/05
Loc: Oort Cloud 9
      #6069218 - 09/08/13 10:25 AM
Be careful with specimens that have been cleaned with chemicals - it often renders them unstable.
lee14
Reged: 12/19/09
Re: Difference Between these 2 MUONIONALUSTA new [Re: Glassthrower]
      #6069280 - 09/08/13 10:55 AM
Quite so. Hydrochloric ('Muriatic') acid will remove rust, but leaves behind the dreaded chlorine contaminant. Phosphoric acid will remove rust without the introduction of chloride compounds, but my experience with it is limited to only a couple of small specimens and I couldn't really speculate on long term effects.
Lee
lee14
Reged: 12/19/09
      #6069303 - 09/08/13 11:09 AM
Kent, the darker shinier Muon has almost certainly been wire brushed and lacquered. I've bought quite a few Campos from this dealer and that's how they've all been finished. I have mixed feelings about lacquer. It definitely prevents damage to the surface from handling, but if there's trapped moisture in the interior, it can accelerate the corrosion process.
The gray Muon definitely has a few rust spots, but that's not necessarily a bad thing. The issue with Muons is subsurface contamination, which can result in 'weeping', i.e. the formation of the greenish-yellow globules on the surface which is an indication of lawrencite disease. There's no way of knowing from the pic if it's been treated and the rust formed naturally, or if a more insidious process is at work.
Lee
lee14
Reged: 12/19/09
      #6069310 - 09/08/13 11:13 AM Attachment (6 downloads)
Here's an example of what I consider 'attractive' rust. This is a 24.3 kg Gibeon that exhibits a deep red patina and absolutely no tendency towards ongoing surface degradation. I've had it for nine years and it's my favorite piece.
Lee
Edited by lee14 (09/08/13 11:50 AM)
lee14
Reged: 12/19/09
      #6069363 - 09/08/13 11:50 AM Attachment (5 downloads)
another view...
Edited by lee14 (09/08/13 11:53 AM)
Kent10
Reged: 05/08/12
      #6069413 - 09/08/13 12:23 PM Attachment (7 downloads)
Oh yea. That's beautiful Lee. I bought these 2 from this dealer.
Kent10
Reged: 05/08/12
      #6069415 - 09/08/13 12:23 PM Attachment (5 downloads)
And
lintonius
Reged: 12/13/05
Loc: south-central Utah
      #6069457 - 09/08/13 12:49 PM
Lee
That's a beautiful Gibeon, Lee!
Indeed, 'cleaning' away that patina/rust would be vandalism, in my mind.
Linton
Glassthrower
Reged: 04/07/05
Loc: Oort Cloud 9
Re: Difference Between these 2 MUONIONALUSTA new [Re: lintonius]
      #6069559 - 09/08/13 01:49 PM
As Lee said, an oxidation layer can actually insulate the specimen for further and more serious damage. Many iron meteorites found in the field have a thick oxidation rind on them which protects the unoxidized core. When this rind is removed, it exposes the unoxidized material to terrestrial contamination.
If the rust is an aesthetic issue, then it should be left alone, IMO. If the rust is indicative of serious stability issues (weeping fluid, pieces flaking off), then one should consider stabilization measures.
lintonius
Reged: 12/13/05
      #6069560 - 09/08/13 01:49 PM Attachment (5 downloads)
Nice etch on that one, Kent.
Here's the nicest Muonion slice I've had.
It's moved on to the Falling Rocks collection now.
Linton
Glassthrower
Reged: 04/07/05
Loc: Oort Cloud 9
      #6069562 - 09/08/13 01:50 PM
I love that graphite inclusion Linton!
lintonius
Reged: 12/13/05
      #6069577 - 09/08/13 01:57 PM
Thanks Mike.
I couldn't remember if it was graphite or troilite.
Anyway, I always thought of that slice as 'Snoopy'... and that was his eye! ;^)
Linton
Kent10
Reged: 05/08/12
      #6069601 - 09/08/13 02:12 PM
Thanks Linton. I was looking for a nice etched something and was considering a MUONIONALUSTA. I liked it but the more I looked at the Gibeon and considering how stable they are I decided to get it. The MUONIONALUSTA was etched on only 1 side which is kind of neat because then you can see something different on the other side. Do people generally prefer a full slice over an end? And is one more valuable than the other? It seems to me they are about the same price per gram but the ends are usually thicker and so usually weigh more if the surface area is the same.
lintonius
Reged: 12/13/05
      #6069747 - 09/08/13 03:22 PM
Value is subjective, Kent. End-cuts are always nice, since you get the look of a whole individual, plus the interior on one end. But you can get a lot more surface area per gram (per dollar!) with a slice. And that applies to stoney meteorites, as well as etched irons.
Linton
lintonius
Reged: 12/13/05
      #6069761 - 09/08/13 03:29 PM Attachment (3 downloads)
You like inclusions, Mike? Check out this one!
Not for sale... ever.
Linton
494.2g Gibeon 'obelisk'
lintonius
Reged: 12/13/05
Re: Difference Between these 2 MUONIONALUSTA [Re: lintonius]
      #6069765 - 09/08/13 03:31 PM Attachment (3 downloads)
Another view...
0 registered and 0 anonymous users are browsing this forum.
Moderator:  Dave M, darklighteditor
