Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Does anyone measure double stars anymore? new
      #6058202 - 09/01/13 07:33 PM
I've been doing some research and reading and there were some articles in the mid 2000s about "contributing to science" and measuring the separations of double stars.
Ronald Tanguay's name comes up quite a bit and he seemed to be an advocate for this sort of thing. Indeed, it looks like he once even published a journal of sorts on it.
What is the state of amateurs doing separation measurements these days?
(And what became of Ronald Tanguay? His journal seems to have vanished and his house (address listed in some of his S&T articles) seems to be owned by someone else, so I fear the worst.)
fred1871
Reged: 03/22/09
Loc: Australia
Re: Does anyone measure double stars anymore? new [Re: Michael Rapp]
      #6058213 - 09/01/13 07:44 PM
These days, if you want to see what amateur astronomers are doing in measuring double stars, look at the JDSO (Journal of Double Star Observations), which is online at:
www.jdso.org
There are quite a few individuals and groups nowadays measuring doubles.
The JDSO appears every three months, has been running since 2005, and the archive of past issues is on the website. You can read your way through the lot, and be inspired. And it's free, but worth much more than the price.
Edited by fred1871 (09/01/13 08:14 PM)
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
Re: Does anyone measure double stars anymore? new [Re: fred1871]
      #6058233 - 09/01/13 08:02 PM
I have been using small telescopes and video cameras to measure double stars for a few years.
You can read more about this method here:
http://www.clearskyobserver.com/index.php/22-doublestar
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: Does anyone measure double stars anymore? new [Re: StarDusty]
      #6059760 - 09/02/13 06:11 PM
Ecco Fred 1871: Check out the JDSO. Double star measuring if alive and well and a large percentage of the measures on visual doubles are done and published by self-funded (read "amateur") astronomers. Some are even publishing astrophysical papers (see the latest paper by Rica).
http://www.jdso.org/
Ed
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
Re: Does anyone measure double stars anymore? new [Re: Ed Wiley]
      #6059942 - 09/02/13 08:24 PM
Echoing Ed, here is a link to a "self-funded" paper I submitted to JDSO. It is in the July issue by JDSO.
http://www.jdso.org/volume9/number3/Malsbury_5_11.pdf
gregj888
Reged: 03/26/06
Loc: Oregon
      #6060138 - 09/02/13 10:21 PM
Here's another source...
http://www.iadso.org/
Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Re: Does anyone measure double stars anymore? new [Re: gregj888]
      #6060665 - 09/03/13 09:11 AM
Wow, thanks all. How I missed these in my Googling is beyond me.
I even found a FAQ in the JDSO from the U.S. Naval Observatory on submitting observations. That is probably the strongest pro-am link I've ever come across!
Now I wonder if visual measurements are useful. I know they have to be calibrated else are worthless. Still researching on how to do that....
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #6061134 - 09/03/13 02:24 PM
Hi Michael:
If you read the various articles in the JDSO you will find a variety of way to measure from ToUCams to filar micrometers. For example, I use a DMK21 video camera for image acquisition (reel off a video file, convert to separate frames). Then I use REDUC to determine angle and separation. There is a bit more to it than that, like establishing your plate scale (pixels/sec) and camera angle, but this is easily accomplished.
Visual measures requite a micrometer. An eyepiece micrometer may be used to produce publishable measures, but I find the video camera route much easier. Filar micrometers are very expensive but visual measures do have advantages -- I am limited to pairs with less than 2.5 or so magnitude difference using video.
Hope you give measuring a try,
Ed
WRAK
Reged: 02/18/12
Loc: Vienna, Austria, Europe
      #6061180 - 09/03/13 03:20 PM
Visual measurement of faint wide doubles (as these are usually neglected) is on my long term list, but my current topic resolution of unequal binaries will occupy me for some time. And next comes probably sketching of open clusters.
Wilfried
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
Re: Does anyone measure double stars anymore? new [Re: WRAK]
      #6061778 - 09/03/13 10:11 PM
I am using the same method Ed mentioned. I have been using small 6" diameter or less reflectors with low cost webcams and more recently a more sensitive Imaging Source monochrome camera. For closer doubles, when I am above f/12, I find that minor stars fainter than magnitude 9 are difficult to record with the equipment I have. Also, doubles closer than 2 arcsec are generally not measurable with my small telescopes and the video method.
R Botero
Reged: 01/02/09
Loc: Kent, England
      #6062133 - 09/04/13 04:58 AM
Thoroughly recommend the book "Observing and Measuring Visual Double Stars" (Argyle ISBN 978 1 4614 3944 8). Several methods are reviewed and it makes for very interesting reading!
Roberto
Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Re: Does anyone measure double stars anymore? new [Re: R Botero]
      #6062346 - 09/04/13 09:22 AM
I just picked up Argyle's book (2nd edition from last year) and have skimmed a few chapters. I also read with interest his chapter on what amateurs can contribute. If I am reading this right, there are over 800 doubles that are neglected that are in the range of visual measurement.
Am I reading this right?
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #6062681 - 09/04/13 01:21 PM
Michael:
You can get the list from the USNO, look for the neglected doubles link:
http://www.usno.navy.mil/USNO/astrometry/optical-IR-prod/wds/WDS
As StarDusty relates, it does not take expensive equipment or large scopes. But, it does require that the difference in magnitude be relatively small and you have to match your scope's capabilities to the doubles. That said, there are plenty to measure with a small scope.
Ed
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
      #6063331 - 09/04/13 08:25 PM Attachment (16 downloads)
I have looked at the neglected double lists a few times, although maybe not in the last 6 months. I recall that many of the neglected doubles were relatively faint pairs. I concluded that these were too faint for me to measure.
I am toying with the idea of imaging a few with my DLSR using techniques similar to what I already do for Deep Sky Object (DSO's) using a guide scope system for long exposures.
My 4" f/28 Schiefspiegler might be able to do it. Here is M13 taken through the Schief. I should be able to go for a fainter doubles if I can image this?
Lots to work out yet regarding the best way to determining image scale, PA, etc, but it might work out....
Maybe when the weather improves.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #6063497 - 09/04/13 10:32 PM
Allen: See the following web site
http://www.astrosurf.com/hfosaf/index.htm
Look at Florent's discussion of how he measures doubles in the link "The webcam is a micrometer." His REDUC program is the way forward and you can use any camera you like, not just a video camera. And, of course, if your DSLR takes videos, then that is the way forward. Using REDUC does not require plate solving, just camera angle and plate scale, parameters that can be easily determined using calibration doubles. Your 4" Schiefspiegler will make an excellent platform if on a equatorial mount.
Ed
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
      #6068600 - 09/07/13 09:53 PM
Yes, I forgot that the double star calibration can be used to determine plate scale and PA. I was going to give it a try last night, but just ran out of time.
I was imaging DSO's because of the clear conditions and moonless night we enjoyed at UACNJ in Hope NJ last night.
We also were able to observe the LADEE mission rocket as it pasted by New Jersey headed north after its launch last night at 11:27pm.
Here is a description of what we saw:
It was a crystal clear night right down to the horizon.
There was a group of us on the rock, maybe 8 in all standing on the rock together. About half the group was there because it was so clear and dark, the other half came just to watch the launch.
We spotted the rocket within 30 seconds after the 11:27 launch time, first as a bright red ball, like a flare less than 5 degrees above the hill tops on the other side of the valley.
The red ball changed colors and became a distinct and crisp white-yellow streak of light, like a long narrow cone with the large end up.
As it rose out of the southeastern horizon the long cone of light became more horizontal. It was headed north up the valley. It became dimmer, changed back a pinpoint of white light and disappeared. By now it was 10 maybe 15 degrees up and directly across the valley from us.
I thought is was over, but then there was a buff of white smoke followed by the lighting of the next stage. This left behind a gray cloud in the clear night sky. The rocket continued in the northerly direction and soon I could not see it any more.
Nice treat on a super clear and dark night. .
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #6069191 - 09/08/13 10:11 AM
There are two common ways to measures doubles using a camera.
(1) If you are using a regular CCD with an decent FOV (say 15-30') and lots of other stars in the image, then you can use almost any available software that can "plate solve." No need to determine camera angle or image scale as they have been "solved." You simply use your software to measures the positions of the two stars.
(2) You are at a very narrow FOV because you are working at a very narrow FOV due to long effective focallength with either a video camera or CCD. There are few if any background stars that can be used to plate solve. In this case you calibrate camera angle and plate scale by first "shooting" one or more pairs of known angle and separation. You use the values obtained in REDUC to determine angle and separation of your unknown pairs. You also shoot another "calibration pair" at the end of the session to insure that the camera did not move during the session.
Caution: The use of calibration pairs assume a very accurate polar alignment. Best to pick calibration pairs fairly close to the pairs to be measured.
Ed
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
      #6070950 - 09/09/13 10:10 AM
I downloaded a plate solving program called uniMap. It works for my 6" f/5.6 deep sky images capture with a XS Canon. There are plenty of stars in these FOV's to match. So far no luck on the few images I have using the 4" Schiefspiegler.
This software seems to provide image scale information, but I am just learning you how to use it and extract the plate scale and plate angle data it can provide. Pretty cool software. I never used anything like this before.
Are their other programs that will run under windows that might be better for this?
Edited by StarDusty (09/09/13 10:13 AM)
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: Does anyone measure double stars anymore? [Re: StarDusty]
      #6071011 - 09/09/13 10:48 AM
I have no experience with that program, so I cannot comment on it. Before I went into high resolution work I used MPO Canopus. Astrometrica and programs like AIP4Win can do the same thing although I have never used them for this purpose. No doubt Maxim and CCDSoft can also do the same thing, and probably others that do no come to mind.
I used MPO Canopus because it has a very nice double star routine and automatic plate solving, but it does require attending to the learning curve inherent in all such programs.
The point of the plate-solving route is that you do not need to determine camera angle and plate scale -- this is solved by the fitting. All you have to do is determine the angle and separation between two stars on the plate and at least in MPOCanopus and AIP4WIN the calculation are done for you once you select the two stars in correct sequence.
I suggest you do some reading. The Bob Buchhiem chapter in the second edition of Observing and measuring Visual Double Stars (not the first edition) is a "must read" IMO as it summarizes the basic principles. Bob is one of the best science writers around. Many of the other chapters are very valuable.
Good measures, Ed
StarDusty
Reged: 10/02/07
Loc: Parsippany, NJ
      #6084962 - 09/16/13 10:54 PM Attachment (14 downloads)
Here is my first try at imaging and plate solving using my 4" Schiefspiegler and a stock Canon DSLR. I was able to image down to mag 14.4 The target was 20135+3912. A and B stars are listed at mag 10.7 and 10.8 with a C of 14.4. With two minute exposures at ISO1600. Separation for A-B is listed at 6.1 arcsec. I used uniMap to plate solve and Startools to confirm the target. Plate solving provided a believable image scale that I can use in REDUC. I will need to use the drift or calibration method to determine PA going forward.
3 registered and 11 anonymous users are browsing this forum.
Moderator:  PJ Anway, Rich (RLTYS), rflinn68
