James Cunningham
Reged: 08/07/10
Loc: Maryland
What camera to use for Solar imaging?
      #6073554 - 09/10/13 04:48 PM
Which camera is best for Solar imaging? Which is the cheapest but still good? Which camera do you use and why? Thanks.
frolinmod
Reged: 08/06/10
Loc: Southern California
Re: What camera to use for Solar imaging? new [Re: James Cunningham]
      #6074278 - 09/11/13 01:07 AM
That depends on what you want to do and how you want to do it.
Always a mono camera, never color. For solar imaging the bayer matrix on color cameras just wastes resolution and provides no benefit. Colorize the image after the fact if you want.
Do you want to make full disk solar images? All in one shot? Using a reducer or not? Using mosaics or not?
Or do you want to do high power imaging of small areas of the disk or closeups of prominences?
So far I've been using the DMK41 and DMK51. With these cameras I have to use a reducer to obtain full disk images. I haven't done mosaics because they're more work and I'm too lazy.
dcornelis
Reged: 10/09/12
Re: What camera to use for Solar imaging? new [Re: frolinmod]
      #6074385 - 09/11/13 04:08 AM
For detailed solar work I use the DMK21AS618, only 640x480 but no problems with newton rings like my ASI120MM and even low in resolution, I can make every pixel count. I typically use 1200 to 2400 mm focal lenght ...
D.
jerwin
Reged: 05/17/12
Loc: Romeoville IL
Re: What camera to use for Solar imaging? new [Re: dcornelis]
      #6074659 - 09/11/13 09:35 AM
I just started using this PointGrey Blackfly, the monochrome version with the Sony chip. I really like it. http://ptgreystore.com/blackfly-13-mp-mono-gige-poe-icx445
I have to do a mosaic in photoshop as the chip isn't big enough to fit the whole disk, but I've been pretty impressed with it so far. I needed a few extra attachments, the nose piece and external power. I went with the Gigibit ethernet model because my laptop doesn't have USB 3. I can't believe how small it is.
Clear Skies,
BYoesle
Reged: 06/12/04
Loc: Goldendale, Washington USA
Re: What camera to use for Solar imaging? new [Re: jerwin]
      #6074823 - 09/11/13 10:51 AM Attachment (13 downloads)
PGR Chameleon, incredible Sony ICX445 sensor, dirt cheap. Now available USB 3.0 in a metal enclosure Grasshopper.
As noted by Jerwin, today I'd consider the GigE Blackfly with metal enclosure; only $395!
ICX445 sensor @ 900 mm FL:
BYoesle
Reged: 06/12/04
Re: What camera to use for Solar imaging? new [Re: BYoesle]
      #6074832 - 09/11/13 10:54 AM Attachment (12 downloads)
Six pane full-disk mosaic w iMerge:
Old Dinosaur
Reged: 05/08/07
Loc: Down there on the river
      #6074849 - 09/11/13 11:00 AM
iMerge is a great mosaic tool.
I'm still using the IS DMK21AUO4 I bought when they first came out, Great camera and good frame rate ability, but getting a bit long in the tooth now.
Beginning to think about a new camera with probably a larger chip.
Aboy
Reged: 07/17/12
Loc: Thousand Oaks, CA
      #6075091 - 09/11/13 01:22 PM
Wow mosaic.
Where I can get the program Imerger?
Old Dinosaur
Reged: 05/08/07
Re: What camera to use for Solar imaging? new [Re: Aboy]
      #6075122 - 09/11/13 01:35 PM
http://jaggedplanet.com/iMerge.html
will w
Reged: 08/13/06
Loc: oxford,ms
Re: What camera to use for Solar imaging? new [Re: Old Dinosaur]
      #6075904 - 09/11/13 09:22 PM
jimmy, you might wont to look at a Samsung SDC-435 or SCB-2000 same cam just different numbers. you can find them on ebay and at 123 security products less than a $100.00 Craig, Tacoma Sky uses one to do solar with.you can use just about any cam to do solar with. will w
ValeryD
Vendor (Aries)
Reged: 11/26/05
Loc: Kherson, Ukraine.
      #6075949 - 09/11/13 09:55 PM
Hello Bob,
What is your configuration for double stack pictures (as seen on this larger picture) ?
Valery.
BYoesle
Reged: 06/12/04
Re: What camera to use for Solar imaging? new [Re: ValeryD]
      #6076172 - 09/12/13 12:32 AM Attachment (6 downloads)
Hi Valery, not sure exactly which configuration you are referring to, so here's everything in a "nutshell":
My filter configuration can be found here (Optimizing the Double Stack):
http://www.cloudynights.com/ubbthreads/showflat.php?Cat=0&Board=solar&...
Camera config: I use a TEC to cool the Chameleon ~ 20 C below it's normal operating temp (Cooling a Chameleon):
I use FireCapture in 8 bit avi mode (screen shot). My gain is usually set at the lowest setting of 160, and my gamma at 1000 or 1500. The exposure at 900 mm is usually 5 ms, which keeps the bright areas from being overexposed, and there is plenty of dynamic range to bring out prominence details with appropriate histogram adjustments... I capture usually at ~ 18 fps for 20 seconds, and stack the best 10% of images (usually about 35) in RegiStax6, where linked wavelets are applied. Results for screen shot here (July 9, 2013 Sun):
In processing I opt for more subtle contrast enhancement by using unsharp masking @ 0.5 pixels and reiterative sharpening, and increasing gamma and mid-tone compression to keep the prominences from fading... Double-stacking allows this to be more successful in my opinion, and much more easily than with single-stacked imaging (disk brightening form the photosphere is eliminated).
Hope I answered your question -- let me know if not...
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
      #6077574 - 09/12/13 06:36 PM
Dang, Bob!! These two images (mosaics above) are amazing!!!!!!!!
Edited by Tom and Beth (09/12/13 06:37 PM)
ValeryD
Vendor (Aries)
Reged: 11/26/05
      #6077670 - 09/12/13 08:17 PM
Thanks, Bob!
Two questions, if you allows.
1. What is the advantage(s) of the linked wavelets over standard wavelet procedure?
2. How do you perform the mid-tone compression?
BTW. This info - how do you take and process the double stack images is interested for many. Can you create a different topic about this and post your info there?
Valery.
BYoesle
Reged: 06/12/04
      #6078033 - 09/12/13 11:54 PM Attachment (7 downloads)
Thanks T&B! (you should see the full-res versions).
Hi Valery. I will attempt to put something together along the lines of a tutorial in the coming weeks. Please be advised I really don't have that much expertise -- you should be asking Alan Friedman how he accomplishes his magic!
I have used both linked an unlinked wavelet processing, and at times I can't tell which is better. Even at the same image scale, seeing conditions can make a group of settings that worked well in one session pretty poor in another.
For guidance on wavelets and linked wavelets I found this page and those linked to at the top of the page useful:
http://www.astronomie.be/registax/previewv6-3.html
The mid-tone compress is accomplished in the Histogram function (in Paint Shop Pro) -- Along with adjusting gamma:
axle01
Reged: 01/26/13
Loc: Townsville Nth Qld Australia
      #6078107 - 09/13/13 01:06 AM
Ok so if the Genie popped up and said what camera do you want to image the Sun what would ask for, knowing the Genie is going to pay for it.
BYoesle
Reged: 06/12/04
Re: What camera to use for Solar imaging? new [Re: axle01]
      #6078150 - 09/13/13 02:04 AM
PGR Grasshopper3 w CMOSIS CMV4000 (4.1 MP @ 90 fps) or Sony ICX694 (6 MP @ 13 fps):
http://grasshopper3.ptgrey.com/USB3/Grasshopper3
axle01
Reged: 01/26/13
      #6078164 - 09/13/13 02:20 AM
So the Genie says why don't you want the 6mp or the 9.1mp Grasshopper??????
BYoesle
Reged: 06/12/04
      #6078185 - 09/13/13 03:25 AM
... or Sony ICX694 (6 MP @ 13 fps)
6 MP is also listed above, but at some point -- 10 fps in this case, I draw the line.
ValeryD
Vendor (Aries)
Reged: 11/26/05
      #6078683 - 09/13/13 12:44 PM
2 BYoesle
Thank you very much, Bob. Now it is more clear.
4 registered and 7 anonymous users are browsing this forum.
Moderator:  Phillip Creed, nitegeezer
