pjglad
Reged: 01/29/11
StarSense Behavior new
      #6075769 - 09/11/13 08:06 PM
I have a CPC800 and StarSense. The alignment works great. All objects dead center. I have had a few weird issues with the HC. I entered M057 and M062 appeared in the LCD. I then entered the NGC equivalent of M057 and same thing - a different NGC number appeared in the LCD. Also, I entered the Moon then slewed to it. However, about an hour later when the Moon was at 10 degrees it was no longer in the Solar System list - Just Uranus, Neptune and Pluto. Anyone else having these kinds of issues?
Sorny
Reged: 03/15/12
Loc: Southern MN
Re: StarSense Behavior new [Re: pjglad]
      #6075893 - 09/11/13 09:17 PM
Sounds like slew limits and filter issues. Change the limits and you'll be fine.
pjglad
Reged: 01/29/11
Re: StarSense Behavior new [Re: Sorny]
      #6076904 - 09/12/13 12:28 PM
Thanks. I've never used slew limits. I checked and the default slew limits for the HC that ships with the CPC800 are 0/90. Also, I checked the default slew limits on the StarSense HC and they are 10/70.
Bob Griffiths
Getting Grouchy
Reged: 10/10/05
Loc: Frederick Maryland
      #6077270 - 09/12/13 03:25 PM
Glad to see you figured it out with the help of Sorny..
We all learned something about the starsence unit overriding the scope
Good thing to know..
BobG
pjglad
Reged: 01/29/11
Re: StarSense Behavior new [Re: Bob Griffiths]
      #6077528 - 09/12/13 06:00 PM
Actually StarSense does not override the scope. StarSense AutoAlign consists of a StarSense Camera and a new HC. The new HC's firmware manages the catalogues based on slew limits.
Sorny
Reged: 03/15/12
Loc: Southern MN
      #6077698 - 09/12/13 08:46 PM
Glad it was an easy "fix" for you. I suspected that is what it was since I've seen things "disappear" from the menus after I set custom slew limits on my NexStar 5SE and my CPC1100, and your description sounded almost identical to what I experienced with slew limits set.
I think the SS handcontroller defaults to 10/70 as a safety precaution since it is a universal hand controller, and not all mounts can always move to 0/90 (many SLT mounted scopes could run into serious issues with wide open slew limits).
The manual does mention slew limits under setup, but not that they default to 10/70.
I'm still waiting for my StarSense... Not because I have issues with alignment, but because I'm all about nifty gadgets.
pjglad
Reged: 01/29/11
Re: StarSense Behavior [Re: Sorny]
      #6077799 - 09/12/13 09:42 PM
Sorny - Thanks for your help. StarSense is awesome! I purchased a replacement coiled cable which is shorter. Let me know if you want after you get your StarSense.
5 registered and 16 anonymous users are browsing this forum.
