PatHolland
Reged: 10/11/09
Loc: Clever, Missouri
Whole Disc Image 8-18-13 - Skyris 674M new
      #6032922 - 08/18/13 01:53 PM Attachment (130 downloads)
Here's an whole disc (single frame) taken with the Celestron Skyris 674M camera. Used the Lunt LS60T double stacked, Celestron CGEM Mount. Best 240 frames, processed in Registax and Photoshop CS3. Inverted to best show the flares...
PatHolland
Reged: 10/11/09
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: PatHolland]
      #6032931 - 08/18/13 01:57 PM Attachment (87 downloads)
And in a somewhat more conventional processing style...Seems to me the northern magnetic belt is weakening?
Aquarist
Reged: 08/27/12
Loc: Illinois
      #6033039 - 08/18/13 03:08 PM
I like both images. The first one is really cool!
Andy Devey
Reged: 05/06/11
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: Aquarist]
      #6033134 - 08/18/13 04:07 PM
Stunning images
Andy
sullij1
Reged: 11/08/08
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: Andy Devey]
      #6033165 - 08/18/13 04:25 PM
Great work Pat. I agree in the northern hemisphere. I hope that once the end of the polar flip is over sombody puts together a full disk animation over the 2 - 4 month period. Gotta have somthing to do with the weakning.
Aboy
Reged: 07/17/12
Loc: Thousand Oaks, CA
      #6033211 - 08/18/13 05:02 PM
I like it. I like the inverter one... You can see the more details
PatHolland
Reged: 10/11/09
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: Aboy]
      #6033295 - 08/18/13 05:47 PM
Thanks guys! Interesting to see the northern belt begin to weaken for the pole shift. I was not into solar astronomy 11 years ago, this is my first time seeing it.
AstroPaolo
Reged: 01/30/08
      #6033311 - 08/18/13 05:55 PM
i like them, how is working the camera?
i'm interested
PatHolland
Reged: 10/11/09
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: AstroPaolo]
      #6033316 - 08/18/13 05:58 PM
Thanks for asking , I'll be back tonight and will give the first light assessment.
LarryAlvarez
Reged: 08/12/05
Loc: Texas
      #6033996 - 08/19/13 05:14 AM
Looks like a really cool camera setup. Definitely good for Solar.
Matt Wastell
Reged: 07/05/09
Loc: Paddington, Brisbane, Australi...
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: LarryAlvarez]
      #6034018 - 08/19/13 06:00 AM
Hi Pat
That is a great image - I love one frame disc snaps - the Skyris looks like a great imager for your setup!
sullij1
Reged: 11/08/08
      #6034355 - 08/19/13 11:17 AM
Right there with you. Fascinating stuff.
DavidM
Reged: 03/25/06
Loc: Perth, Australia
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: sullij1]
      #6035196 - 08/19/13 06:53 PM
Excellent images Pat. Keep them coming.
PatHolland
Reged: 10/11/09
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: DavidM]
      #6035483 - 08/19/13 10:16 PM
Thanks all. I thought I would jot a few lines down about my experience with the Celestron Skyris 674M. The camera has a more solid and therefore slightly heavier body than other cameras in it's class. Since the camera is not actively cooled, I figured it is more along the lines of a "heat sink" aluminum body. It's not "heavy", just heavier than my grasshopper or chameleon cameras.
The camera itself works well, it's a Sony Super HAD ICX274 Monochrome chip, which is a safe bet for solar imaging. No newt rings to report (but I did not use it with a barlow either). The image is noise free and no bad, hot or white pixels to report on the camera.
As with most cameras, the real reporting is with the software. I am familiar with ICAP with the NexImage 5 camera, so there were no surprises there. The ICAP software has all settings on automatic when freshly installed on a PC, so the exposure and gain setting had to be set to manual to use the camera without over-exposing the sun.
Registax readily handles the .AVI videos and processes them nicely.
The camera chip size is 8.50mm x 6.80mm (roughly 11mm diagonal) so can easily work with B1200 without severe light drop-off on the sun. The resolution is 1600X1200 pixels (2 Megapixels) so you can make larger prints with your solar system images. The pixel size is 4.40 microns, so even at 12 bit A/D Conversion, you still have sensitivity for solar surface details and flares.
The chip size allows for full frame images of the sun in the Lunt 60mm and I suspect 80mm scopes. I don't like putting together mosaics, so a full frame image of the sun is just the ticket for me. I've ordered a Lunt 80mm APO scope for larger full frame images with WL, Cak and moon shots.
Only had 1 day with the camera so far, so I will report more later.
rigel123
Reged: 06/29/09
Loc: SW Ohio
      #6035521 - 08/19/13 10:37 PM
Great report Pat and beautiful images, the contrast is great in both of them!
Durval Menezes
Reged: 08/30/10
Loc: Rio de Janeiro, Brazil.
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: rigel123]
      #6069267 - 09/08/13 10:48 AM
Hi Pat,
Amazing pictures! Thanks for posting them, and for the report.
Just looked for it over at Celestron's web site, but they don't list a Skyris 674M; there's a camera there with exactly the same specs (specially the resolution, which seems to be the difference between models), but they are calling it a 274C, not a 674C. Could it be that Celestron changed the model number?
PatHolland
Reged: 10/11/09
Re: Whole Disc Image 8-18-13 - Skyris 674M [Re: Durval Menezes]
      #6078625 - 09/13/13 12:06 PM
I have no idea Durval, I will have to look into that. 274 would make more sense for a model number...it's a 2 megapixel camera.
*edit* wonder if that makes the 674 a "limited issue" collector's item?
Edited by PatHolland (09/13/13 12:07 PM)
wes
Reged: 11/13/03
Loc: Oklahoma
      #6081056 - 09/14/13 08:43 PM
Excellent images Pat I have some images using the Skyris 274 they are good cameras.
Wes Higgins
Reged: 02/08/11
Loc: Montreal, Quebec, Canada
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: wes]
      #6081088 - 09/14/13 09:08 PM
Really beautiful image Pat.
Andre
BYoesle
Reged: 06/12/04
Loc: Goldendale, Washington USA
Re: Whole Disc Image 8-18-13 - Skyris 674M new [Re: Andrev]
      #6081253 - 09/14/13 10:58 PM
Very nicely done Pat!
6 registered and 12 anonymous users are browsing this forum.
