Telescope Specific Forums >> Meade Computerized Telescopes
marcyc
Reged: 10/21/10
Loc: Northern VA, USA
Need help reassembling ETX-70 new
      #6097351 - 09/23/13 07:54 PM
I bought an ETX-70 at a yardsale, but unfortunately it came to me in pieces. I have managed to get it back together except for one part - I can't figure how the piece I have seen referred to as the "friction sleeve" fits in the OTA.
Can anyone give me any advice?
Marcy
astronomylife
Reged: 08/07/13
Loc: San Francisco Bay Area, Califo...
Re: Need help reassembling ETX-70 new [Re: marcyc]
      #6097715 - 09/24/13 12:09 AM
I have an ETX 80 and I just dissembled it yesterday, so I know they are similar. (There should be 2 barrels, one with lens, and one wihtout) The sleeve goes in the barrel of the OTA attached to the mount. There should be a hole drilled on one side of the OTA, should be near the rim, so make sure it lines up with the bump on the sleeve. Then slide it in place. Post some pictures if you can, they'll be helpful.
astronomylife
Reged: 08/07/13
Re: Need help reassembling ETX-70 new [Re: astronomylife]
      #6097718 - 09/24/13 12:11 AM
Here follow these instructions. Go to step "x".
Let me know how it works out.
marcyc
Reged: 10/21/10
      #6097896 - 09/24/13 06:34 AM
Thanks for your help - I won't be able to try this until tonight, but will let you know how it goes.
I am a little surprised at the instruction to add the lithium grease, though. The parts don't seem like they have ever had any kind of lubricant on them.
astronomylife
Reged: 08/07/13
      #6099281 - 09/24/13 08:29 PM Attachment (9 downloads)
Here is a picture of the friction sleeve in the blue OTA. If you look at the right inside, you will notice the blue of the OTA showing. The rest is covered by the sleeve. Hope the picture helps.
Edited by astronomylife (09/24/13 08:30 PM)
marcyc
Reged: 10/21/10
      #6099513 - 09/24/13 11:13 PM
You helped tremendously. It is back together and works perfectly. Thanks for your assistance!
astronomylife
Reged: 08/07/13
Re: Need help reassembling ETX-70 [Re: marcyc]
      #6099549 - 09/24/13 11:35 PM
No problem, glad to know it works.
0 registered and 11 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
