HT417
Reged: 06/08/13
Loc: The Land of "Prost!"
For 5SE: Lumicon UHC, Orion Ultrablock, or DGM NPB new
      #6106919 - 09/29/13 03:39 AM
My house is surrounded by orange streetlights but despite that I still can get some very good viewing. However, I'm hoping that a narrowband filter could improve it some. I realize the small aperture will play a factor but regardless I intend to buy one of the above. What are your thoughts and experiences? Thanks.
Tel
Reged: 03/31/06
Loc: Wallingford England
Re: For 5SE: Lumicon UHC, Orion Ultrablock, or DGM NPB new [Re: HT417]
      #6106956 - 09/29/13 05:16 AM
Hi HT417,
A very warm welcome to CN and to this particular forum !
If you want to know anything about filter application, our CN colleague, David Knisely is, without a doubt, the man to seek out.
Here for example is one of his treatise on the subject. I would strongly recommend reading what he has to say on the topic before you purchase.
http://www.cloudynights.com/item.php?item_id=63
Remember that there is no one, all purpose filter; each being specific in varying degrees, for the task it's designed to undertake.
I naively bought a Lumicon UHC some years ago looking for an "all singing, all dancing" filter to reduce my local light pollution, but I was soon aware, after using it, of its limitations. For example, it brings out the finer filaments of the diffuse Orion Nebula very well but turns them green and certainly diminishes the brightness of the background stars quite severely.
Again, it serves well to enhance emission nebulae but does nothing of any great significance for galaxies or star clusters. "Horses for Courses" as I think the expression goes !
Bearing in mind then, that many of these more specific filters are relatively expensive, I'd advise you to accumulate as much information about that/those which will suit you and your surroundings best, before you buy.
Hoping this helps,
Best regards,
Tel;
http:
CelestronDaddy
Reged: 08/22/09
      #6107117 - 09/29/13 09:53 AM
HT417, Welcome! I recently acquired the DGM NPB and I can recommend it based on my experience with it, and I live in a Red zone too. I read and kept up with the various filter discussions and bought this one. It made a huge difference on emission nebulae. As mentioned , David Knisely has some very good discussions and reviews out. Here is a new thread on filters and good luck:
Filter Thread
Edited by CelestronDaddy (09/29/13 01:51 PM)
Midnight Dan
Reged: 01/23/08
Re: For 5SE: Lumicon UHC, Orion Ultrablock, or DGM NPB new [Re: CelestronDaddy]
      #6107183 - 09/29/13 10:31 AM
Hi HT417:
The filters you mention are sometimes referred to as Nebula filters. That's because they filter out nearly all light except that in a narrow band which is produced by emission nebulae. The result is that it darkens the background for these objects, making them much more visible and bringing out more detail. These kinds of filters tend to have a very noticeable effect - when viewing emission nebulae. For all other objects, the filter will just make them darker.
On the other hand, light pollution filters let all the light through except a few notches where light pollution tends to be. In theory, these filters should work on ALL targets to some degree. While these sound like they would so a great job, in fact their effect is usually slight to non-existant. The problem is that light pollution comes from so many different sources, with so many different wavelengths, that much of it is not affected by the filter's notches.
Now, you may actually be in somewhat of a unique situation. If lights in your area show that orange glow, they are probably high pressure sodium. These are the ones that the light pollution filters tend to specifically target. So it's possible that you may see more of an effect from a light pollution filter than most people.
The question is - how widely are these lights used in your area? While the lights on your street can certainly cause problems with glare and direct lighting of the sky above you, light pollution comes from all around you as far away as 50 to 100 miles. If you're near a good sized city, your local lighting is only part of the LP issue. And the broader LP probably comes from lots of sources like mercury vapor, car lights, low pressure sodium, LED lighting etc. However, if you're in a smaller town and they tend to use the same kind of lighting on most of the streets, an LP filter might help some.
Bottom line - you may benefit from an LP filter (Astronomik CLS is a good one) but like others, you may find that they provide little to no benefit. A nebula filter will definitely improve your views, but only on emission nebulae. I have the Orion Ultrablock and it works well for me.
-Dan
nodalpoint
Reged: 06/03/13
Loc: FEMA camp
Re: For 5SE: Lumicon UHC, Orion Ultrablock, or DGM NPB new [Re: Midnight Dan]
      #6107268 - 09/29/13 11:24 AM
I have a Lumicon UHC and on certain targets it really makes them pop and allows detail you won't see otherwise. But the use is limited and the cost can be high. Look at the classifieds and see if you can get a deal on one. Mine was purchased that way for a little over half price.
HT417
Reged: 06/08/13
Re: For 5SE: Lumicon UHC, Orion Ultrablock, or DGM NPB [Re: nodalpoint]
      #6108672 - 09/30/13 04:22 AM Attachment (10 downloads)
Thanks for the warm welcome and to all for the comments. I am familiar with David Knisely and it was his comments that are driving to the narrowband filter versus the others. If you haven't seen it yet, take a look at his performance comparison of LP vs. narrowband vs. OIII here: http://www.prairieastronomyclub.org/resources/by-dave-knisely/filter-performa... You'll notice that the UHC/narrowband was the overall better performer. I know it's not a panacea for LP but it will provide limited advantages that I can appreciate going forward. I kept all of your comments in mind as I was viewing last night and I think I would enjoy darker skies and the occasional improved view of the nebulas. I agree that the filter probably isn't worth full price but I can't find a used one here - the demand is high. I am looking at a Celestron UHC/LPR instead. It appears that it's actually made by Baader. Reviews seem to indicate that it's not as high quality as the Lumicon but it's also about half the price and therefore the disappointment factor will be lower and I won't be frustrated with so much money lying around underutilized. I live at the edge of a small town but on a corner and I'm surrounded on three sides with the orange streetlights - see attached pic. I'm hoping these are the high pressure sodium ones Dan mentions and that I'll get at least a little relief.
HT417
Reged: 06/08/13
      #6111388 - 10/01/13 02:57 PM
Midnight Dan or anyone: can you confirm what type of streetlight I have in the attached pic above? Is this the high pressure sodium you mentioned in a post?
11 registered and 17 anonymous users are browsing this forum.
