N_DD
Reged: 10/21/12
Loc: East Germany
Canon EOS 1000D strange noise pattern new
      #6106970 - 09/29/13 05:46 AM
I recently got an astromodified Canon EOS 1000D (Rebel XS). I tried shooting some test images and I always get a strange noise pattern (see image: 2 min. at ISO 800, camera without lens and closed with lid, LCD off, contrast stretched). There is amp glow visible (low left), but what worries me is the dark band at the bottom. The pattern does not change if I use APT or the canon EOS utility or if I manually depress the shutter button... any idea about what could it be?
Thanks a lot!
mmalik
Reged: 01/13/12
Loc: USA
Re: Canon EOS 1000D strange noise pattern new [Re: N_DD]
      #6107444 - 09/29/13 12:58 PM
Not sure if you bought it modified or modified it afterwards; if later, I would consult with the modifier. Regards
wasyoungonce
Reged: 06/07/07
Loc: Land Downunder
      #6108170 - 09/29/13 08:42 PM
You might want to read this thread and look at a link I provided in post #5512214. Looks a lot like I experienced.
Also check the shutter isn't jamming or you have the viewfinder fully covered. Cannon give a little rubber shoe to fit over the viewfinder...you can use this or tape.
Also try to take "darks" with aluminium foil over the lens cap. A lot of plastic caps pass infrared which can be seen on the sensor as photons.
Hope this helps
edit:
Oh one last thing...check the mirror lockup is fully going up out the light path way.
Edited by wasyoungonce (09/29/13 08:46 PM)
N_DD
Reged: 10/21/12
Loc: East Germany
Re: Canon EOS 1000D strange noise pattern [Re: wasyoungonce]
      #6108678 - 09/30/13 04:43 AM
Hi Brendan,
thanks a lot for the link: I was aware of both the mirror lockup and the "live view" issues, so I disabled the ML on the camera side and on APT and did not shoot using "live view". However, I still get that dark band at the bottom of every image I take... I am still using "virtual" exposure control, might that be the culprit?
Interesting point the aluminum foil, I will try again with better light shielding.
Nico
N_DD
Reged: 10/21/12
Loc: East Germany
      #6111740 - 10/01/13 06:56 PM
Ok, seems that there is no explanation for the strange dark band... the problem is similar to what people have experienced when shooting with live view, but I have disabled it!!! The LCD screen is off, the viewfinder capped, and in APT the mirror lockup is disabled and the anti vibration pause set to 0... anyone has an idea? I am starting to consider selling the camera as partially malfunctioning ...
mmalik
Reged: 01/13/12
Loc: USA
      #6111753 - 10/01/13 07:02 PM
Modifier should own this and take care of the problem in my opinion. Thx
jsines
Reged: 09/06/11
Loc: Berkley. Michigan
Re: Canon EOS 1000D strange noise pattern new [Re: mmalik]
      #6111876 - 10/01/13 08:00 PM
My hunch is that your shutter isn't opening all the way. Try the cleaning sensor option on your 1000D, where you take off the lens, press the shutter button, and the shutter opens all the way. If you look in there and the shutter doesn't open all the way, that's probably the problem.
My hunch is also that the shutter isn't opening all the way because of how it was modified. The modifier should fix this.
wasyoungonce
Reged: 06/07/07
Loc: Land Downunder
      #6112398 - 10/02/13 02:13 AM
Yep as said check the shutter is opening fully...maybe do a 5 sec exposure or open shutter with lens off.
Also check the flip mirror is fully moving up out the way. It does look like a light leak around the flip mirror.
Other than that...it's back to the modifier.
N_DD
Reged: 10/21/12
Loc: East Germany
Re: Canon EOS 1000D strange noise pattern new [Re: wasyoungonce]
      #6113248 - 10/02/13 02:15 PM
Ok, thanks guys. I will try to troubleshoot with the previous owner (I purchased the camera used and was already modified). My bad I didn't ask for flats before buying. Anyway I checked the shutter, as already suggested by Brendan and jsines, and it seems it's opening ok. On the other hand, I am getting the noise pattern even without any light entering the camera, so it must be something electronic. Subtracting the noise pattern as bias in DSS restores the images.
Nico
5 registered and 16 anonymous users are browsing this forum.
Moderator:  Dave M, fishonkevin, WOBentley, tecmage
