Stargazer78
Reged: 03/05/13
Loc: Susanville California
Post pics of your pimped out reflector new
      #6107971 - 09/29/13 06:14 PM
So here is mine. Its a AT8in with a At72ed ridding piggy back. On the right side of the tube I have a 50mm right angle finder and on the left side a AT50gs
Ed D
Reged: 04/30/10
Loc: Sunny South Florida
Re: Post pics of your pimped out reflector new [Re: Stargazer78]
      #6107990 - 09/29/13 06:26 PM Attachment (62 downloads)
Would these be pimped out enough?
Ed D
Stargazer78
Reged: 03/05/13
Re: Post pics of your pimped out reflector new [Re: Ed D]
      #6107994 - 09/29/13 06:29 PM
LOL awesome
AlBoning
Reged: 03/06/11
      #6108411 - 09/29/13 11:12 PM Attachment (51 downloads)
Here's my AD8 conversion to EQ mounting sitting on an Atlas EQ-G at 'Ning's Observatory #3. Modifications include:
1)Protostar FlockBoard in the OTA and drawtube.
2)Suspended fan mounting
3)Rear mounted baffle to direct all the air from the fan up the tube.
4)Tube ring based rotating rings. (Thanks again AstroBaby!)
5)Telrad on a Scopestuff mounting rail with dovetail foot. RACI or Telrad, never both.
6)An additional dovetail shoe on the other side of the focuser to allow switching the RACI or Telrad to the other side when I rotate the focuser to the other side so I can still have the RACI/Telrad on top. Done as a work-around for those situations when the focuser is over the mount or a tripod leg making it difficult to place the observing chair.
7)MoonLite CR2, dual rate, shaft lock.
8)Primary springs replaced with ones from Bobs Knobs.
9)Secondary alignment screws replaced with ones from Bobs Knobs, allowing for toolless adjustment of the secondary.
10)AstroZap Light Shield.
11)Flock paper on the mirror clips
12)Slated to be removed for having no effect is a flocked annular mask, mounted to the mirror clips. This was done to mask the bevel edge of the primary as a check for TDE, of which there is apparently none.
13)Cedar carry handle bridging the tube rings.
Pinbout
Reged: 02/22/10
Loc: nj
Re: Post pics of your pimped out reflector new [Re: AlBoning]
      #6108496 - 09/30/13 12:24 AM
pimpin' out
satin alum vinyl stripe with cutout scope specs.
rear retro reflective yellow stripe.
polish alum low profil moonlite focuser.
ply cell with heavy springs.
WO binos
Pinbout
Reged: 02/22/10
Loc: nj
Re: Post pics of your pimped out reflector new [Re: Pinbout]
      #6108564 - 09/30/13 01:26 AM
here's a pimped out concept from footbags napkin sketch...
Reged: 06/16/04
      #6108606 - 09/30/13 02:16 AM
Pimped out DobsL
Here's a couple of before and afters:"pimped out Dobs:
16 inch Starfinder transformed into a Dobstuff strut scope..
The scope on the right is my 12.5 inch Discovery in the before photo..
The after photo:
Gastrol
Reged: 11/04/11
Loc: los angeles
Re: Post pics of your pimped out reflector new [Re: Jon Isaacs]
      #6109244 - 09/30/13 12:54 PM
My 12" Lightbridge with setting circle, levelers, Stellarvue 60mm finder.
BDS316
Reged: 09/16/09
Loc: Sol 3
Re: Post pics of your pimped out reflector [Re: Stargazer78]
      #6109327 - 09/30/13 01:55 PM
http://www.astrogoods.com/stone.goldeneye.jpg
Moonlite CR2, Bob's Knobs, flocked, Astrogoods prototype base, Telrad, digital inclinometer, secondary mirror washer, and custom balance system.
george golitzin
Reged: 02/24/06
      #6110196 - 09/30/13 10:28 PM Attachment (31 downloads)
Here's my 12.5 f/6 with a new 70mm finder, wheelbarrow handles, and recently upsized teflon bearings. 15 lbs per square inch really is about ideal--can you say "buttery smooth?"
-geo
cavefrog
Reged: 11/11/08
Loc: loozyanna
Re: Post pics of your pimped out reflector new [Re: george golitzin]
      #6111978 - 10/01/13 09:09 PM Attachment (31 downloads)
Does the Woodenbridge qualify?
cavefrog
Reged: 11/11/08
Loc: loozyanna
Re: Post pics of your pimped out reflector new [Re: cavefrog]
      #6111993 - 10/01/13 09:17 PM Attachment (23 downloads)
This LB 8" is more of a "MUTT" than it is pimped.
Stargazer78
Reged: 03/05/13
      #6112013 - 10/01/13 09:31 PM
You have done what I want to do with my 10 inch dob. I want to mount it on my dx and use it for imaging. At least I now know that it may be possible.
cavefrog
Reged: 11/11/08
Loc: loozyanna
      #6112036 - 10/01/13 09:40 PM
I too have recently been thinking about doing this with an LB10. I guess I would have to make a strap mount for it.
omahaastro
Reged: 08/30/06
Loc: Omaha, NE
      #6112142 - 10/01/13 10:35 PM
My powder coated 8" f/6 Cave...
Ed D
Reged: 04/30/10
Re: Post pics of your pimped out reflector new [Re: omahaastro]
      #6112711 - 10/02/13 09:40 AM
Some really awesome scopes! Keep 'em coming.
Ed D
John_G
Reged: 01/18/10
      #6659610 - 07/29/14 05:48 PM
A night of monster mosquitoes. I just set it up with a dual saddle so I can use RACI side by side with the RDF. What a difference. The EQ5 handles the weight quite well. It's a very steady view.
Pinbout
Reged: 02/22/10
Loc: nj
Re: Post pics of your pimped out reflector new [Re: John_G]
      #6659749 - 07/29/14 07:12 PM
I'm keeping this scope no-frills.
I'll get around to fixing the mirror so I'll have a sports car engine in a vw bug [72'] body.
23 registered and 25 anonymous users are browsing this forum.
Moderator:  ausastronomer, Knuklhdastrnmr, Phillip Creed, JayinUT
