wavecloud
Reged: 09/22/13
Siding?????
      #6109823 - 09/30/13 07:01 PM
Does anybody have a good idea for inexpensive observatory siding?
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Siding????? new [Re: wavecloud]
      #6109949 - 09/30/13 08:20 PM
Yeah concrete block doesn't need any siding.
wavecloud
Reged: 09/22/13
Re: Siding????? new [Re: mikey cee]
      #6109987 - 09/30/13 08:41 PM
I mean for a wood framed building.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6110119 - 09/30/13 09:46 PM
He's being funny . No, it's all relatively expensive. I used tongue and grove 5/8th inch plywood. Looks good and really helps stiffen the structure up. If you go with something thin, consider t bracing to stiffen the walls. You do have a rolling roof on it.
MHamburg
Reged: 06/21/06
Loc: Brooklyn, NY/Berkshires, MA
Re: Siding????? new [Re: Raginar]
      #6110190 - 09/30/13 10:25 PM
I went to the local sawmill and got rough-sawn 1 x 12 boards for less than half the price of dressed lumber at the building supplies place. (Check out my thread here.)
Michael
wavecloud
Reged: 09/22/13
Re: Siding????? new [Re: MHamburg]
      #6110195 - 09/30/13 10:28 PM
That's a good idea.
wavecloud
Reged: 09/22/13
      #6110197 - 09/30/13 10:29 PM
Which thread?
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #6110292 - 09/30/13 11:15 PM
His construction thread on this forum.
Megabusa
Reged: 05/28/12
Loc: Page ,AZ
      #6110409 - 10/01/13 12:16 AM
5/8" Fiber board If you are referring to the finished product then Yep ! I did the same thing Inside and Out ,Over here it's called 5/8" Smart siding and comes per primed , Extra Strong needed for ROR is a must I think too, and I have a Dome go figure , I used it inside also knowing I'm going to be banging Myself around in the dark.
Edited by Megabusa (10/01/13 02:05 AM)
Alex McConahay
Reged: 08/11/08
Loc: Moreno Valley, CA
Re: Siding????? new [Re: Megabusa]
      #6110441 - 10/01/13 12:56 AM
We used T-111 and were generally dissatisfied with its wearability. (Some have deteriorated after five-to-seven years to the point of replacement.)
Weyerhauser makes a fiberboard siding I have had on my home observatory forever without any downside. It has to be painted, though.
Alex
Megabusa
Reged: 05/28/12
Loc: Page ,AZ
Re: Siding????? new [Re: Alex McConahay]
      #6110516 - 10/01/13 02:21 AM Attachment (14 downloads)
If you look at manufactured Holmes with 4'x8' sheets of Siding on it , that's Smart Siding or looks just like it , where I get it it comes Per Primed for paint 5/8" Thick 4'x 8' Fiberboard sheets , Ive been using and working with it for years ,I really like it, But I do live in AZ where it's dry .
RGM
Reged: 09/15/03
Loc: Burks Falls, Ontario, Canada
      #6110597 - 10/01/13 05:23 AM
Smart siding for me also. It is quite rigid and takes paint very well. I researched quite a bit, and this was the least expensive option I could find that gave you a "finished" look.
Startraffic
Reged: 02/12/06
Re: Siding????? new [Re: RGM]
      #6111049 - 10/01/13 11:43 AM
Wavecloud,
You can also consider Hardiboard (concrete). It doesn't rust, rot, or smell bad in wet weather. Paintable or prepainted. Installed right lasts for ~75yrs. If you have 24" framing, you're golden. It doesn't like hard point type impacts (baseballs). I'm putting on my house. I got ~1500sqft for $500. Frame for 24"OC & you can Tyvek wrap the walls & insulate inside.
Clear Dark Skies
Startraffic
39.138274 -77.168898
wavecloud
Reged: 09/22/13
Re: Siding????? new [Re: Startraffic]
      #6111066 - 10/01/13 11:52 AM
Startraffic,
I've heard of that stuff.
What format does it come in?
wormstar
Reged: 11/23/09
Loc: Central Ct
      #6111177 - 10/01/13 12:59 PM
I just used vinyl to match my other out building it's kind of fun and easy to install.
Keith
telfish
Reged: 11/17/10
Loc: Adirondack Mountains NY
Re: Siding????? new [Re: wormstar]
      #6111276 - 10/01/13 01:55 PM
I went to Lowes and they had an odd box of vinyl siding 2 squares left over. It was $200 marked down to $126 I offered them $60 for it and it was mine. More than enough to clad my Obs.
telfish
Reged: 11/17/10
      #6111280 - 10/01/13 01:56 PM
(Accidental double post removed by moderator)
Edited by csa/montana (10/01/13 02:37 PM)
HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
      #6111326 - 10/01/13 02:14 PM
...What format does it come in?
Google is your friend:
Cement board products
You probably want to add in the cost of a dedicated saw blade that's made for cutting cement board.
Installation works the best with an air gun, rather than a plain hammer.
It would help to know what kind of climate you're in.
One usually tailors materials choices to specific areas of the world.
dan k.
Edited by HunterofPhotons (10/01/13 02:17 PM)
Startraffic
Reged: 02/12/06
      #6113264 - 10/02/13 02:22 PM
Wavecloud,
I found mine at a building materials auction. It is 9" high, 8ft long, 1/4" thick with a 1" overlap. I'm drilling holes every 24" for decking screws & washers. I don't drive them down tight, just snug. I also got a load of another 4500sqft of 9"x8ftx3/8" for $750. Very cheap but FUGLY I don't care what it looks like as long as it keeps the weather out. SWMBO wasn't amused.
Clear Dark Skies
Startraffic
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #6113299 - 10/02/13 02:42 PM
When I priced out vinyl siding for my 11x9', the prices ranged from $300 to $1500. The nice thing was it was an easy installation.
11 registered and 8 anonymous users are browsing this forum.
Moderator:  Christopher Erickson
