Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | (show all)
MHamburg
Reged: 06/21/06
Loc: Brooklyn, NY/Berkshires, MA
Re: Construction Begins new [Re: MHamburg]
      #6110222 - 09/30/13 10:41 PM Attachment (43 downloads)
Update: I took advantage of the glorious weather and finished up a lot of the exterior work such as door and window trim and battens. Next step is to wire and insulate.. Then I can really work inside the new addition.
Michael
MHamburg
Reged: 06/21/06
      #6110226 - 09/30/13 10:43 PM Attachment (22 downloads)
The other side:
MHamburg
Reged: 06/21/06
      #6110239 - 09/30/13 10:45 PM Attachment (23 downloads)
One more: This was the toughest area to work on as I had to literally squeeze myself into contortions to raise a hammer.
Edited by MHamburg (09/30/13 10:46 PM)
MHamburg
Reged: 06/21/06
      #6110243 - 09/30/13 10:48 PM Attachment (20 downloads)
I constructed an interior insulated door around an old double-glazed window I "recovered" from our town dump.
MHamburg
Reged: 06/21/06
      #6110244 - 09/30/13 10:49 PM Attachment (27 downloads)
It actually works!!
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #6110287 - 09/30/13 11:13 PM
The outside really is beautiful! I love the "recovered" window that will now see a new life in your door! Very nice job!
MHamburg
Reged: 06/21/06
Re: Construction Begins new [Re: csa/montana]
      #6110996 - 10/01/13 11:13 AM
As always, thanks for your kind words, Carol.
Michael
wavecloud
Reged: 09/22/13
      #6111060 - 10/01/13 11:50 AM
How'd you make that dome?
MHamburg
Reged: 06/21/06
Re: Construction Begins new [Re: wavecloud]
      #6111403 - 10/01/13 03:04 PM
Basically it is .025" sheet aluminum pop-riveted onto 1/8" aluminum bars. The base ring and frame for the shutter are rolled angle iron. It is not as elegant as the commercial versions, but it has withstood time and weather for 25 years. I will post some detail pics asap.
Michael
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
      #6114837 - 10/03/13 10:13 AM
Wow, that is one thick and wide door.Looking great and I love your choice of siding also.
MHamburg
Reged: 06/21/06
Re: Construction Begins [Re: tim57064]
      #6116893 - 10/04/13 10:04 AM
Thanks, Tim. The siding continues the look of all the buildings on the property. I guess I got used to building in that style. I really wanted to make sure the dome room is thermally isolated from the control room. I will update with pics as I inch forward. Thanks for comments.
Michael
MHamburg
Reged: 06/21/06
      #6148784 - 10/20/13 05:56 PM Attachment (20 downloads)
Latest update: I just got back from hiking two weeks in Utah and kept thinking how this landscape is like another planet to this Easterner. Did some interior work on the warm room:
Here is an entrance light salvaged from another project that will glow an inviting red soon.
Michael
MHamburg
Reged: 06/21/06
      #6148790 - 10/20/13 05:58 PM Attachment (18 downloads)
#2:
Insulated the ceiling with the same stuff that I did for the floor so many moons ago.
MHamburg
Reged: 06/21/06
      #6148795 - 10/20/13 05:59 PM Attachment (14 downloads)
#3:
Completed the rough-in wiring.
MHamburg
Reged: 06/21/06
      #6148800 - 10/20/13 06:01 PM Attachment (13 downloads)
#4:
The walls are next!
Michael
MHamburg
Reged: 06/21/06
      #6148806 - 10/20/13 06:04 PM Attachment (15 downloads)
#5:
I also closed the open wall connecting the warm room and the telescope room. Not sure yet how I will finish the boards. Thanks for looking.
Michael
ps BTW, this project has turned out more demanding than I ever imagined (and it isn't done yet).
tim57064
Reged: 08/23/12
      #6160321 - 10/27/13 08:18 AM
Michael,I just had a thought about the area between the dome and your warm room. I your part of the state where the OBS is ,do you get a lot of snow? I hope that the snow build up is not so that it makes it's way into the observatory or pile up and make it difficult to remove.
I was just checking out your thread again and was wondering about it.
MHamburg
Reged: 06/21/06
Re: Construction Begins new [Re: tim57064]
      #6161182 - 10/27/13 06:01 PM Attachment (16 downloads)
Tim,
Funny you should ask! I am installing de-icing cables on that connecting roof. Otherwise I probably would wind up with a solid block of ice locking the dome until the spring. Thanks for your concern! Here are a few pics of the latest progress (very boring insulation.) BTW, I ran one of those oil-filled electric radiator heaters today to test the heat retention and man oh man----as Kramer told Jerry Seinfeld as they sat in a sauna, it was like a sauna in there in less than 30 minutes. Next step is to install all the outlets and lighting fixtures (oh yes, and those deicing cables.)
Michael
MHamburg
Reged: 06/21/06
Re: Construction Begins [Re: MHamburg]
      #6161186 - 10/27/13 06:03 PM Attachment (15 downloads)
One more angle:
Mary B
Reged: 05/21/10
Loc: Minnesota
      #6162849 - 10/28/13 03:59 PM
Fiberglass... itch... now I am going to be scratching all day just from the picture
8 registered and 10 anonymous users are browsing this forum.
