twhite
Reged: 01/28/06
Loc: Broken Arrow, Oklahoma, USA
Vixen DMD-2 and DD-1: interchangeable? new
      #6124044 - 10/08/13 02:32 AM
Before I go plugging something in to something else and accidentally releasing the magic smoke supply, I wanted to confirm whether or not the DMD-2 and DD-1 controllers and associated motors are, in fact, interchangeable? I believe that they are, but wanted to get confirmation. I am buying another older Vixen mount that is coming with dual motors and a DMD-2 controller, and would prefer to use a DD-1 controller with it. I have an extra DD-1, as well as a DD-1 that's modded for autoguiding, hence the question... thanks in advance for replies.
Tony
sky_dave
Reged: 07/10/08
Loc: Northern Colorado
Re: Vixen DMD-2 and DD-1: interchangeable? new [Re: twhite]
      #6124072 - 10/08/13 03:09 AM
I have a DMD-3 controller and it is compatible. The circuit board is actually labeled DMD-2. So not totally sure about the DMD-2. Vixen changed the gear ratio and voltage on the motors to improve slew times on GOTO systems. When they did they changed the motor cable connector from 5 pins to 8 pins. If the motors on this mount have 8 pins they will work with the DD-1. If only 5 pins then no good.
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6124077 - 10/08/13 03:14 AM
they are both stepper controllers, but one has a 5-pin and the other an 8-pin plug. if the plugs are the same they are probably electrically identical -
https://sites.google.com/site/thestarjar/Home/mt1
the DD-1 (I used to have one) uses the 8-pin DIN plug. Some ads/posts on the internets leaves me to believe that the DMD-2 can drive the MT-1.
but if you're in doubt, use a multimeter to check the wiring on your new motors. these are ordinary unipolar steppers so easy to figure out (use the pinouts from the link above).
twhite
Reged: 01/28/06
Re: Vixen DMD-2 and DD-1: interchangeable? new [Re: orlyandico]
      #6125451 - 10/08/13 05:06 PM
Thanks. One mount with 8-pin connectors uses the DD-1, the other the DMD-2. I didn't recall their being any difference between the two. However, I wasn't sure if the steppers had a different degrees/step rating or not. Only way to check, I assume, will be to disassemble the entire system and check them.
I know there's a difference in the go-to motors as they're closed-loop with built-in encoders (I used to have one) and I think they're servos rather than steppers anyway.
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6125782 - 10/08/13 08:14 PM
There's no difference, they're both 48 ppr Nippon Pulse tin cans. Not sure if the gearing is different though (the DD-1 uses 120:1 gearboxes). But gearing differences wouldn't release the magic smoke.
Definitely the GoTo (except the original SkySensor) uses different motors. The 48 ppr, 120:1 motors are too slow for GoTo, running full-bore they can only do 40X sidereal or so.
twhite
Reged: 01/28/06
Re: Vixen DMD-2 and DD-1: interchangeable? [Re: orlyandico]
      #6126787 - 10/09/13 11:19 AM
Many thanks.
4 registered and 21 anonymous users are browsing this forum.
