Speciality Forums >> Science! Astronomy & Space Exploration, and Others
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | (show all)
deSitter
Still in Old School
Reged: 12/09/04
Re: The Higgs Boson as a field of snow new [Re: PeterR280]
      #6127634 - 10/09/13 06:46 PM
Why would you think that?
-drl
PeterR280
Reged: 05/27/13
Re: The Higgs Boson as a field of snow new [Re: deSitter]
      #6127672 - 10/09/13 07:01 PM
To be consistent with relativity
llanitedave
Humble Megalomaniac
Reged: 09/26/05
Loc: Amargosa Valley, NV, USA
      #6127971 - 10/09/13 10:01 PM
In such a world, the Higgs mechanism is irrelevant, and the Higgs field would sit glumly on the bench like a klutzy infielder whose presence on the team is mandated by nepotism.
Now, THAT's an analogy!
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
Re: The Higgs Boson as a field of snow [Re: PeterR280]
      #6128622 - 10/10/13 09:28 AM
I'd be curious if any person without any knowledge of physics understood what the Higgs Field is from what you said above,
I have a limited knowledge of physics and thought it was the most clear explanation I have seen so far.
I took from it that the Higgs field propogates out and allows the weak force to operate at a distance that would otherwise violate conservation. - Is that a valid understanding?
deSitter
Still in Old School
Reged: 12/09/04
Re: The Higgs Boson as a field of snow new [Re: shawnhar]
      #6128922 - 10/10/13 11:48 AM
The best analogy for the role of the Higgs interaction comes from classical mechanics! It is this. A typical problem tackled by the physics student in his first full-blown physics course, is to solve the problem of a ball bearing in a gravitational field, rolling on the inside of a spherical surface. The ball bearing wants to fall, but is "constrained" by the spherical bowl and must remain on that bowl. So its trajectory is not straight down, rather, a more or less complex motion on the sphere itself. We are taught a method for dealing with problems that involve constraints like this - "Lagrangian mechanics". The free motion of a falling object is described by a "Lagrangian function". To this function is added another term with an undetermined "Lagrange multiplier" to take account of the sphere. Once the equations are solved this way, you can determine the value of the undetermined Lagrange multiplier. It turns out that it gives just the required normal force of the sphere on the ball to ensure that it does not leave the sphere. So you can look at things from two points of view - you have the motion of a ball constrained to a sphere, or you can ignore the sphere altogether and add in a mysterious "sphere force" that causes the ball to deviate from its normal course of falling straight down.
Now, what if you had a ball bearing that was moving on a sphere which was invisible? You'd be perplexed and wonder, why isn't this ball bearing falling down to the floor like the other ones? And you try things and eventually hit on the idea of this sphere force. The sphere force is not pre-determined, it is just what it needs to be to resist motion off the sphere.
That is pretty much what happens with the Higgs field. The gauge bosons are by their nature massless and so long-range, but they behave as if they were not. So you throw into the Lagrangian function that describes the various fields and their interactions in the massless case, this mysterious "Higgs field" which always provides just what is needed to make the gauge bosons appear massive.
The Higgs field thus describes, not an actual state of matter alone, but matter in relation to the background in which it moves. It is more a property of the vacuum of particle physics itself, than an independent entity.
It is very likely that the Higgs boson story is not over. A tight argument says that it must be composite in some way, perhaps made of actual matter in some sort of bound state. This also has an analogy in superconductivity. The ultimate cause for (normal) superconductivity is the pairing of electrons that takes place when you put them in cold metal lattice. They interact not just with each other, but also the lattice in which they move. So, even though they repel each other electromagnetically, they are also attracted to each other because of some magic that happens when they are inside a cold atomic lattice other than free space. The attraction can be strong enough to overcome the electromagnetic repulsion and they form bound pairs (Cooper pairs). These pairs are bosons and can now pile into the same quantum state. The result is the supercurrent. The long-range electromagnetic interaction, or at least, part of it, has been hidden by interaction with the background atomic lattice. The Higgs field in this scenario is then to be thought of as excitations of this lattice that result in the net attractive force. The lattice behaves just as it has to, to ensure pairing of electrons and formation of the supercurrent. Once the current is established, you can forget about the background lattice and treat the supercurrent alone. When the energy is high enough, the temperature of the lattice goes up, it begins to vibrate out of its normal orderly pattern that allows the quantum collective state to form, the interactions of electrons via the lattice breaks down, the supercurrent disappears, and the normal state of unscreened, long-range electromagnetic interaction returns.
Without the theory of superconductivity as developed by London and London, Landau and Ginzburg, and finally Bardeen, Cooper, and Schrieffer, none of the modern model of spontaneously broken gauge symmetry as a fundamental theory would exist. This illustrates in dramatic terms, that this model - broken gauge symmetry - is *entirely* phenomenological, and will eventually be replaced by a complete theoretical model involving new ideas.
-drl
Otto Piechowski
Reged: 09/20/05
Loc: Lexington, KY
      #6129018 - 10/10/13 12:40 PM
Danny,
I wish I would have had you as a physics teacher in high school.
Another issue: You wrote, "The Higgs field thus describes, not an actual state of matter alone, but matter in relation to the background in which it moves. It is more a property of the vacuum of particle physics itself, than an independent entity."
Do you remember many months ago when I asked you/this forum about the idea of uneducated "savant" I knew name Lawrence who suggested that space was the cause of motion. Is your statement which I just quoted, consistent with, similar to his idea?
His reasoning was that, according to Einstein, energy is a type of matter, and according to Newton a thing cannot overcome its own inertial movement; therefore, matter cannot move itself, nor can various forms of energy (forces) move matter because that would be a case of matter moving itself. The only thing, left, Lawrence reasoned was space and therefore he suggested space is what causes motion.
Otto
GregLee1
Reged: 07/21/13
Loc: Waimanalo, HI
Re: The Higgs Boson as a field of snow new [Re: Otto Piechowski]
      #6129044 - 10/10/13 12:57 PM
... and according to Newton a thing cannot overcome its own inertial movement;
Did they have Roman candles in Newton's day?
deSitter
Still in Old School
Reged: 12/09/04
      #6129105 - 10/10/13 01:27 PM
Danny,
Otto
No, that's a trivial oversimplification. It may be possible to have a new more inclusive space in which matter shows up as aspects of that space. That's an idea very close to my heart. But spacetime, the 4d sort that lives under field theory, is not a form of matter, and the Higgs field is not coextensive with it. The Higgs field is an aspect of field theory and its vacuum, which presumes flat, continuous spacetime as a stage.
-drl
Otto Piechowski
Reged: 09/20/05
Loc: Lexington, KY
      #6129128 - 10/10/13 01:38 PM
Thank you Danny.
Your words "matter shows up as aspects of that space. That's an idea very close to my heart" sound interesting.
Otto
dvb
different Syndrome.
Reged: 06/18/05
Loc: Vancouver, Canada
      #6129145 - 10/10/13 01:48 PM
I applaud the science writers who attempt to explain physics to laypeople.
The exercise will necessarily be imperfect, and the laypeople know that, but I also applaud the laypeople who are curious about these things, and who hope to understand them as best they can.
And, I applaud those of you who are in a position to critique those attempts to explain to laypeople, and who can find the right balance between comprehensibility and accuracy.
But, please, may be all be saved from the worst such efforts, such as references to a "God Particle".
PeterR280
Reged: 05/27/13
      #6129150 - 10/10/13 01:51 PM
" It may be possible to have a new more inclusive space in which matter shows up as aspects of that space."
That would indeed be a more complete theory building on what Einstein had done.
PeterR280
Reged: 05/27/13
      #6129186 - 10/10/13 02:09 PM
"The Higgs field is an aspect of field theory and its vacuum, which presumes flat, continuous spacetime as a stage."
Danny
Have you played with granularity to Spacetime? I haven't seen too much written about that.
deSitter
Still in Old School
Reged: 12/09/04
      #6129288 - 10/10/13 03:00 PM
No but my advisor David Finkelstein sure did! So I've heard a lot about it. It's certainly a valid approach and I admire those with the patience to pursue it.
-drl
deSitter
Still in Old School
Reged: 12/09/04
      #6129300 - 10/10/13 03:06 PM
What I work on is the opposite idea, to eventually explain quanta as a phasy aspect of a more inclusive spacetime. The extra dimensions in this spacetime are timelike and correspond directly to matter and antimatter without any reference to particles as such. I have had some success with this idea, but here is not the place to discuss it. It's enough to say that there is plenty of room for new ideas.
-drl
deSitter
Still in Old School
Reged: 12/09/04
      #6129309 - 10/10/13 03:11 PM
The main point is - the way forward is to reconcile the, as of now, complete isolation of the theory of spacetime geometry, and the fields that live on it. String theory is a failure. Onward
-drl
PeterR280
Reged: 05/27/13
      #6129373 - 10/10/13 03:40 PM
except for gravity
deSitter
Still in Old School
Reged: 12/09/04
      #6129379 - 10/10/13 03:46 PM
No, that too!
-drl
dickbill
Reged: 09/30/08
      #6129475 - 10/10/13 04:54 PM
Can one be refreshed on the conservation laws, often mentioned by deSitter?
About Energy, Mass, Momentum, Space itself maybe? etc. not forgetting Time, and or Entropy.
dickbill
Reged: 09/30/08
Re: The Higgs Boson as a field of snow new [Re: dickbill]
      #6129649 - 10/10/13 06:29 PM
...or maybe let's talk about what is not conserved in our enclose system: the Universe. Is it really enclosed by the way? nothing can escape from all-togetherness and I am thinking about black holes.
Entropy is supposed to ever increase, so it is not conserved.
Time, IF a conservation law does not apply for Time, why?
Space (Volume) is not conserved since the Universe is expending.
Energy (=mc^2) ? I read here that there is nothing in Relativity that poses it should be conserved. Although we learn in school that Energy and mass are conserved, that they can only be transformed, here we talk about the total energy (and mass or any other form) contained in the Universe.
So, does the Universe still weight the same than at its birth?
deSitter
Still in Old School
Reged: 12/09/04
      #6129653 - 10/10/13 06:31 PM
YES, good question, I'll get to it presently.
-drl
0 registered and 5 anonymous users are browsing this forum.
Moderator:  LivingNDixie, FirstSight, JayinUT
