snorkler
Aperture Aficionado
Reged: 10/11/04
Loc: Bay Area, California
Polishing optical acrylic lens element in a Lunt s new
      #6075701 - 09/11/13 07:05 PM
An optical acrylic lens element in the prism of my Lunt solar scope developed mineral deposits in storage. I removed the prism.
Remove the prism by loosening the set screws. Then unscrew the tube. You can see the fogged element inside.
Remove the retaining ring with a spanner wrench. For lack of better tools in Bryce Canyon National Park, we used needle nose pliers.
Edited by snorkler (09/11/13 07:42 PM)
snorkler
Aperture Aficionado
Reged: 10/11/04
Re: Polishing optical acrylic lens element in a Lunt s new [Re: snorkler]
      #6075761 - 09/11/13 08:02 PM
Photo shows the removed lens element. Until we removed it, I thought the element was a multi-element lens fogged internally. After removal, I saw a single element, which was coated on both sides with mineral deposits. Washing did not remove the deposits completely.
After searching the WWW for polishing compounds for optical acrylic plastic, I found three recommended compounds: Meguiar's PlastX, Novus plastic clean and shine, and Brasso. We drove 80 miles to the nearest city, Cedar City, because Meguiar's is sold in Walmarts.
I polished the lens element (or filter) with the Meguiar's using cotton underwear. The results were amazing.
Views through my solar scope are as good as they have ever been.
Edited by snorkler (09/11/13 08:21 PM)
Sean Cunneen
Let Me Think
Reged: 08/01/07
Loc: Blue Island Illinois
      #6075879 - 09/11/13 09:09 PM
Nice!
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Polishing optical acrylic lens element in a Lunt s new [Re: Sean Cunneen]
      #6076109 - 09/11/13 11:42 PM
Good work! Many would be rather too trepidatious.
Crayfordjon
Vendor - Zerochromat
Reged: 06/17/09
Loc: UK
Re: Polishing optical acrylic lens element in a Lunt s new [Re: GlennLeDrew]
      #6076271 - 09/12/13 01:57 AM
I once experimemterd making acrylic lenses, I polished them with plasticene laps and rouge, the finish was brilliantly clear.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: Polishing optical acrylic lens element in a Lunt s new [Re: Crayfordjon]
      #6077090 - 09/12/13 02:00 PM
Is this the same issue as the "rusting"? Seems like a very simple solution for a worrisome problem.
richard7Moderator
Not Quite
Reged: 11/02/07
Loc: Sacramento
Re: Polishing optical acrylic lens element in a Lunt s new [Re: Footbag]
      #6077215 - 09/12/13 02:54 PM
This is something that neither I nor Cloudy Nights would recommend. You're dealing with something that could cause permanent eye damage.
If it looks bad, send it back to the manufacturer.
RikkiHocking
Vendor - Lunt Solar Systems
Reged: 02/15/08
Loc: Tucson, AZ
Re: Polishing optical acrylic lens element in a Lunt s new [Re: richard7]
      #6077459 - 09/12/13 05:24 PM
I am sorry to see you are having this issue. We have come across it on a few blocking filters. Sometimes there is a film that develops on this piece of glass. There is no degrading of the filter. There are no coatings on this piece. You can feel free to either clean the glass as you have seen here or contact Lunt Solar and we can send you a new piece.
Thank you,
Rikki Hocking
Lunt Solar Systems
(520)344-7348
r.hocking@luntsolarsystems.com
richard7Moderator
Not Quite
Reged: 11/02/07
Loc: Sacramento
Re: Polishing optical acrylic lens element in a Lunt s new [Re: RikkiHocking]
      #6077908 - 09/12/13 10:44 PM
Thank you Rikki.
snorkler
Aperture Aficionado
Reged: 10/11/04
      #6079129 - 09/13/13 05:45 PM
I hadn't considered the element could have been coated, or glass. I would have backed off if I had seen any optical change, but I agree I should have contacted Lunt before proceeding as I did. You get used to doing your own repairs in park isolation.
Since my problem is fixed, I won't request replacement of the blocking filter. Thanks Rikki and Richard for your feedback.
ion
Reged: 04/26/08
Loc: Bortle Scale 2
      #6079185 - 09/13/13 06:20 PM
The Lunt website refers to this phenomenon as "premature failure" of the Induced Transmission Filter (ITF):
http://www.luntsolarsystems.com/technical-manuals.html
How can simply removing the damage or "film" be an acceptable repair? What is this "film" composed of if the part is not coated? Where exactly did all these "mineral deposits" come from and why don't they affect any other internal lenses in the telescope?
http://www.optcorp.com/media/catalog/product/cache/1/image/9df78eab33525d08d6...
RikkiHocking
Reged: 02/15/08
Loc: Tucson, AZ
Re: Polishing optical acrylic lens element in a Lunt s new [Re: ion]
      #6079227 - 09/13/13 06:54 PM
Hi Ion,
We do not use ITF's in our systems anymore. The poster image you have is very old. This is BG glass. There are no coatings on it. The glass itself is the filter. We have not had any film on any other element.
Rikki Hocking
Lunt Solar Systems
marktownley
Reged: 08/19/08
Loc: West Midlands, UK
      #6133232 - 10/12/13 02:57 PM
What a revealing thread. Very interesting
BYoesle
Reged: 06/12/04
Loc: Goldendale, Washington USA
Re: Polishing optical acrylic lens element in a Lunt s new [Re: marktownley]
      #6133394 - 10/12/13 04:34 PM
Makes sense with the use of a hot-mirror ERF coating with the front filters or on the collimator lens of an internal etalon scope.
See the BG glass filter curves in this document: http://www.us.schott.com/advanced_optics/english/filter/us/index.html
marktownley
Reged: 08/19/08
Re: Polishing optical acrylic lens element in a Lunt s new [Re: BYoesle]
      #6133542 - 10/12/13 06:18 PM
Tee hee hee - I was looking at the same webpage Bob
BYoesle
Reged: 06/12/04
Re: Polishing optical acrylic lens element in a Lunt s [Re: marktownley]
      #6133811 - 10/12/13 08:29 PM
BYoesle
Reged: 06/12/04
      #6147765 - 10/20/13 01:33 AM Attachment (8 downloads)
BG38 looks like a likely candidate for the filter used, with decent transmission @ 656 nm ~ 50% :
17 registered and 19 anonymous users are browsing this forum.
