pdfermat
Reged: 11/12/07
Loc: Wisconsin
This is good, right?
      #6136095 - 10/13/13 11:42 PM
Right now, I'm writing this message from my living room, while my rig is tracking/autoguiding ngc 457. I must say, it feels weird "doing astronomy" without actually being outside.
I'm using TeamViewer to control my netbook next to the scope, and everything is finally coming together. I think I'm getting good results with my autoguiding, but I'd like some of you seasoned veterans to take a look:
Those red and blue lines are barely moving from the center line, but that's what I'm shooting for, right? I used the EQMOD polar alignment procedure to get everything dialed in, and I think it has had a positive result on my tracking.
Anyway - I'm having a blast moving the scope around from inside and watching the finderscope view from PHD. As they say - if you're having fun, you must be doing something right!
gillmj24
Reged: 12/06/05
Loc: PA
Re: This is good, right? new [Re: pdfermat]
      #6136104 - 10/13/13 11:51 PM
Pic doesn't show up for me but sounds like you're doing good.
pdfermat
Reged: 11/12/07
Loc: Wisconsin
Re: This is good, right? new [Re: gillmj24]
      #6136122 - 10/14/13 12:03 AM
Hmm...I wonder why the pic doesn't show for you? I'm using photobucket, and haven't had troubles in the past. I'll go to a different device and see I it shows up for me.
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
      #6136138 - 10/14/13 12:16 AM
The flat line DEC shows the polar alignment is good.
The RA looks fine, but without a clue of how large the movements are it is hard to tell for sure. But the RMS value looks good.
Blueman
orion69
Reged: 05/09/10
Loc: Croatia
Re: This is good, right? new [Re: blueman]
      #6136238 - 10/14/13 02:41 AM
If stars are good then everything is OK. PHD graph doesn't mean much since you are probably using finder for guiding (if mount is Atlas EQ-G).
Mike X.
Reged: 06/28/10
Loc: Greece-Athens and Rome-Italy
Re: This is good, right? new [Re: orion69]
      #6136245 - 10/14/13 02:48 AM
I agree with Orion.
What focal lenght has the guide scope and at what FL do you immage?
This is what i get at 500mm guiding for example:
And gives me ok stars at 945mm FL immaging...Much depends also on what we think it is ok for us i guess.
If your stars are good than you don't have to worry
Edited by Mike X. (10/14/13 02:57 AM)
pdfermat
Reged: 11/12/07
Loc: Wisconsin
Re: This is good, right? new [Re: Mike X.]
      #6136467 - 10/14/13 09:03 AM
The more I read about PHD, I see that the graph is more of a qualitative tool than quantitative. In my case, it seems I should have a pretty flat graph unless something is drastically wrong, since I'm guiding with an Orion 8x50 finder (162mm focal length).
When I do decide on an imaging camera, I'll be imaging through my c8 with a f/6.3 reducer, so the imaging focal length will be around 1200mm. As you say, the real test will be if stars are round. I guess I'll have to wait and see!!
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6136562 - 10/14/13 10:14 AM
PHD2 allows you to input the focal length and pixel size in um. Hence it can display the guiding graphs directly in arc-seconds.
Much more edifying. And you can change the scale. If your scale is +/- 1" even a Mach1 has an alarmingly jagged curve.
snommisbor
Reged: 06/15/09
Loc: Cedar Park, TX
      #6136701 - 10/14/13 11:25 AM
I was thinking that was really flat myself. I have an EM 200 and feel I get good polar alignment but my DEC is never that flat. Mine looks more like yours. I guide with a ST 80 and SSAG. Although sometimes it will guide perfect and other times it will be so finicky. Can be frustrating.
23 registered and 36 anonymous users are browsing this forum.
