dpippel
Reged: 04/05/13
Loc: Desierto de Sonora
Re: Just Joined the Club new [Re: UncleMossy]
      #6152128 - 10/22/13 05:57 PM
I did have some trouble getting Sky Safari to control the mount properly via my iPad and Skyfi, but that can wait.
If I remember correctly this could be the issue.
I had to select Nexstar GPS from the scope list to gain control of my scope, not Nexstar 6/8.
The iPad works as the gps and sends the location.
If you can connect to skyfi but not your scope then this should fix things, hopefully.
I am assuming that you are plugged into the hand controller and not the aux port on the base.
Thanks for the tip Jim, but that's the mount I've selected - "Celestron NexStar GPS/SLT/SE". Yes, I'm plugged into the controller. I use the SkyFi/iPad/Sky Safari combo to control my CGEM DX all the time and am familiar with its operation.
The problem I'm having is VERY strange too. Once I level the mount and go through a SkyAlign, I connect to the scope via SkyFi. Everything is just dandy unless I try to slew to something in the *southern* sky. For example if I use Almach, Vega, and Altair as my three alignment objects and then try to slew to Venus or the Lagoon Nebula, the scope slews NORTH towards Polaris. I can go to practically any star around zenith or north of the celestial equator, but if I select Fomalhut, for example, she slews north again. WEIRD! I'm selecting Phoenix, AZ as my location from the controller database, so the software knows where I am on Earth. If I use the hand controller to select these same objects the gotos are just fine, so I suspect the problem is some setting in Sky Safari.
One evening when I have the time to sit down and really dig into it I'll find out what's going on and report back here.
7 registered and 24 anonymous users are browsing this forum.
Moderator:  Brian Risley, panhard, Mitchell Duke, mayidunk
