dcbaros
Reged: 02/05/10
Loc: Austin Texas
Stabilizing your tripod. new
      #6138588 - 10/15/13 09:07 AM
Anyone have any tips or tricks to stabilize a tripod? I have a N11 with the old style tripod and I recently bought the old HD wedge because it was cheap, but I have heard nothing but horror stories as far as stability. I have not gotten to take it out yet due to the monsoon in central Texas we are currently under. I have heard anything from filling the legs with foam to anchoring it to the ground. What would be the best methods? I bought some vibration suppression pads so we will see how those work.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Stabilizing your tripod. new [Re: dcbaros]
      #6138690 - 10/15/13 10:02 AM
Hey there, not sure of old style stuff, but when I had my 9.25 on a CPC and got the wedge it worked great, but then again it is the HD wedge,
Kasey
Phil Sherman
Reged: 12/07/10
Loc: Cleveland, Ohio
Re: Stabilizing your tripod. new [Re: dragonslayer1]
      #6138809 - 10/15/13 11:12 AM
Two "tricks" I've used:
1. Hang a heavy weight from the top of the tripod.
2. Add another spreader midway between the top of the tripod and the ground.
Phil
dcbaros
Reged: 02/05/10
Loc: Austin Texas
Re: Stabilizing your tripod. [Re: Phil Sherman]
      #6139899 - 10/15/13 10:04 PM
Bump
RandyO
Reged: 11/29/13
      #6227667 - 12/01/13 06:25 PM
For outreach, I use a screw in dog leash anchor, available at Walmart or pet stores. i found the right size eye nut to screw onto the spreader threaded rod. using a small web strap down with a ratchet, you can ensure that the mount doesn't move. This is great to prevent accidental movement by guest observers.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Stabilizing your tripod. new [Re: RandyO]
      #6227889 - 12/01/13 08:24 PM
I really like that idea, Randy.
hottr6
Reged: 06/28/09
      #6228619 - 12/02/13 09:09 AM
I set up tripods for stop-motion photography that often extends for months to a year. I use a tripod rock bag for stability, and it survives some pretty wild storms. Google it.
17 registered and 23 anonymous users are browsing this forum.
