Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Ah, Jeez, I think I fixed it!... new
      #6092702 - 09/21/13 12:07 AM
On my Windows XP machine, I've been having a terrible problem with something called svchost.exe taking the CPU to 100% and slowing things up horribly, even terminally.
I'm not much of a PC nerd, but I finally did some digging, and the quick fix was to disable Windows Automatic Update. I had it set to advise me, but not download; but it turns out the program itself has a bug and completely disabling it eliminates it.
It seems to have worked!
I never download any Microsoft fixes anyway. Last time I did, I lost the ability to access the internet. After asking Microsoft for help, and being told that it was my fault, and that I should stay off the internet because I'm a menace, I stopped getting their fixes. Their software is so awful and buggy! My new computer has Win8, and lots of you know about THAT!
If you're on XP and have this trouble, try that.
StarWars
Mr. Postmaster Man
Reged: 11/26/03
Loc: At the Gym >Spudtastic<
Re: Ah, Jeez, I think I fixed it!... new [Re: Rick Woods]
      #6092796 - 09/21/13 02:20 AM
I had a similar problem. To find the problem follow these instructions..
Download Process Explorer then run PE (no installation required). Look for svchost.exe taking the CPU to 100% then right click on this process, select properties then click the services TAB.
Windows Update is wuauclt.exe
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
Had a problem with svchost.exe (Windows Audio) plus I didn't have any audio..
The problem was with Windows Media player. The Windows Media player would request to update to version 11. After the update the sound returned and svchost.exe no longer was taking the CPU to 100%
I use Process Explorer version 11 and typically run the program in the background.
Rick Woods
Reged: 01/27/05
Re: Ah, Jeez, I think I fixed it!... new [Re: StarWars]
      #6093244 - 09/21/13 11:31 AM
Thanks! I found a lot of references to PE and procedures like that; but I couldn't download anything without hanging the system. I finally found the quick fix on the "Ask Leo" web site. But I'll look into the audio thing too, now that you've told me about it (thanks again!).
StarWars
Mr. Postmaster Man
Reged: 11/26/03
      #6093375 - 09/21/13 12:45 PM
Not sure why this is happening now. Did a malware scan found no scum ware..
Today had another problem with Windows media player 11 svchost.exe taking the CPU to 100% so I tried to remove with my Smart Uninstaller Pro 2009 but Billy Gates only lets the player roll back to the previous installed version.
So now I am back to WMP version 9 no more hang ups....
StarWars
Mr. Postmaster Man
Reged: 11/26/03
      #6093389 - 09/21/13 12:58 PM
What was preventing the downloading....
Sorny
Reged: 03/15/12
Loc: Southern MN
      #6093970 - 09/21/13 07:01 PM
Things like that are why I now run Macs.
No muss, no fuss.
Rick Woods
Reged: 01/27/05
      #6095228 - 09/22/13 03:26 PM
The fact that svchost.exe would take the CPU to 100% and hang me up!
StarWars
Mr. Postmaster Man
Reged: 11/26/03
      #6096067 - 09/23/13 12:00 AM
Download and run SuperAntiSpyware 5.6.1032...
http://www.filehippo.com/download_superantispyware/
Rick Woods
Reged: 01/27/05
      #6098870 - 09/24/13 04:51 PM
I don't need to - I fixed the problem.
StarWars
Mr. Postmaster Man
Reged: 11/26/03
      #6099443 - 09/24/13 10:25 PM
What did you do........
StarWars
Mr. Postmaster Man
Reged: 11/26/03
      #6136907 - 10/14/13 12:53 PM
More Info from the web...Svchost.exe 100% Usage Problem.
[XP Pro] Wuaueng.dll / Svchost.exe 100% Usage Problem.
Microsoft have an obvious problem with their windows update site. Here's what Ive been seeing. On computer that have Service Pack 3 install, if the users goes and tries to do any windows updates, the website wants to install an update to the updater service which does the following.
The Service pack 3 file: wuaueng.dll (4/14/08) is replaced by a wuaueng.dll file which is dated: (7/30/07).
Once the computer does this anytime the updater program auto-starts or is initiated by the windows update site, the wuaueng.dll file running inside of the svchost.exe will use 100% of the primary system processor bringing the entire system to a crawl.
Ive found no fix to this issue besides stopping the windows update service and copying the newer file back to the c:\windows\system32 directory. Only bad thing is that you cant use the windows update site again as it will try to replace this file again.
More Info from the web....
In some cases the issue can be traced to busy servers. However, the "fix" suggested earlier above will likely resolve the issue in any case.
The "Fix":
From a command session, type carefully:
net stop wuauserv
rmdir c:\windows\softwaredistribution /s
net start wuauserv
You need to stop the wuauserv service (if running) to clear the softwaredistribution folder.
StarWars
Mr. Postmaster Man
Reged: 11/26/03
      #6137781 - 10/14/13 08:16 PM
Update....
Got tired of the wuaueng.dll and the Svchost.exe 100% Usage Problem so I used Process Explorer to KILL the process...
The computer went back to normal usage!!
Turned OFF updates...
Rick Woods
Reged: 01/27/05
      #6139747 - 10/15/13 08:19 PM
I turned Windows Automatic Update off. That's where the problem is.
StarWars
Mr. Postmaster Man
Reged: 11/26/03
Re: Ah, Jeez, I think I fixed it!... [Re: Rick Woods]
      #6142262 - 10/17/13 03:56 AM
Update..
Yesterday while surfing I got the BSoD and a reboot...I turned the Windows updates back on and did an update. Left the computer idle for a short time and when I returned I noticed another reboot... Signed back online and Left the computer idle for a short time and when I returned I noticed another reboot.
The svchost.exe problem is GONE....
Rick Woods
Reged: 01/27/05
      #6158162 - 10/25/13 08:41 PM
You have more faith in MS than I do!
3 registered and 10 anonymous users are browsing this forum.
Moderator:  richard7, kkokkolis
