Lew Zealand
Reged: 06/28/04
Loc: Pasadena, CA
inexpensive 30-35mm Plossl for eyeglasses use new
      #6137895 - 10/14/13 09:31 PM
Hi everyone, I'm looking for a Plossl to maximize the TFOV and exit pupil in my 60mm f/11.7 cheapie scope and allow glasses use without touching the EP. Many 32mm Plossls like my Meade 4000 have the eye lens so deeply set to avoid the blackouts that they are unusable with glasses on, but apparently some aren't.
Specs of usable ER for Plossls are apparently not much of a demand item, imagine that! Anybody used or know of Plossls for eyeglass use?
John Huntley
Reged: 07/16/06
Loc: South West England
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: Lew Zealand]
      #6137923 - 10/14/13 09:48 PM
The Vixen NPL 30mm plossl might be what you are looking for. It has a 2-position twist up eye cup which gives a bit more flexibility. The optics are great for the price as well !
JustaBoy
Reged: 06/19/12
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: John Huntley]
      #6138006 - 10/14/13 10:38 PM
32mm TV...
-Chuck
SpaceConqueror3
Reged: 09/19/13
Loc: Phinney Ridge, Seattle, WA
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: JustaBoy]
      #6138093 - 10/14/13 11:31 PM
32mm TV...
Inexpensive?
khendrix2
Reged: 11/11/12
Loc: Denver, Colorado
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: SpaceConqueror3]
      #6138250 - 10/15/13 01:55 AM
It would be interesting to know what the average price of an eyepiece actually is.
T1R2
Reged: 06/11/13
Loc: NeverWhere
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: khendrix2]
      #6138257 - 10/15/13 02:03 AM
I use my Meade SP32 also and noticed the same thing, so now I just fold down the eye cup and it made a noticeable difference, now I can see the edge of field of view with my glasses on, though I don't know how well this will work for you.
khendrix2
Reged: 11/11/12
      #6138267 - 10/15/13 02:19 AM
OK, I'm no expert with Microsoft Excel but using the "2013 Buyers Guide to Eyepieces", I came up with an average price of $190.58 out of 973 eyepieces.
Traveler
Reged: 08/19/07
Loc: The Netherlands
      #6138350 - 10/15/13 05:23 AM
+1 "The Vixen NPL 30mm"
Or a Vixen NPL 15mm with Barlow. Very sharp ep and enough eyerelief. Also good when using in daylight or with a H-Alpha solarscope.
Messyone
Reged: 05/02/12
Loc: Down Under
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: Traveler]
      #6138351 - 10/15/13 05:27 AM
+2 or is it 3 on the NPL Plossl. Cheap excellent views and long eye relief...pick any three! How much is a TV plossl new theses days? Not cheap.
Matt
RGM
Reged: 09/15/03
Loc: Burks Falls, Ontario, Canada
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: Messyone]
      #6138547 - 10/15/13 08:49 AM
I use glasses, and have the 30mm NPL and 32mm Omni. Both are usable, the Omni has more usable eyerelief. In fact, with the Omni, you do not even have to touch the eyepiece with your glasses to get the full FOV. The NPL requires me to rest my glasses on the eyepiece. Both provide similar views.
wd8sbb
Reged: 08/26/12
Loc: Southwest Ohio
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: RGM]
      #6141544 - 10/16/13 06:45 PM
If you're handy, try the 34 mm Plossl described in my signature block. Only hand tools neded. It can also be found (with a few errors) here on CN.
34mm Plossl. The cost should be less than $35 if you don't have any discounts. Eye relief is quite long. Works great on SCT scopes (large f-ratio). Has filter threads. I can use my glasses with it if I care to.
Starman81
Reged: 03/06/08
Loc: Metro Detroit, MI, USA
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: wd8sbb]
      #6142110 - 10/17/13 12:11 AM
The TeleVue 32mm Plossl bought used would run in the $80 range and though not truly inexpensive, is probably the best choice. It is very comfortable to use with glasses on. Another option for use with glasses is the Edmund Scientific 28mm Plossl. It is cheap but it narrowly misses out on the focal length requirement.
JustaBoy
Reged: 06/19/12
Re: inexpensive 30-35mm Plossl for eyeglasses use new [Re: Starman81]
      #6142188 - 10/17/13 01:22 AM
IIRC, the Edmund 28mm RKE is actually 28.7mm, with eye relief in the 24mm range.
I still think that the 32mm TV would be the best choice.
-Chuck
Starman81
Reged: 03/06/08
      #6142212 - 10/17/13 01:56 AM
-Chuck
I was referring to the Edmund Plossl 28mm, which is different than the RKE 28... See here.
JustaBoy
Reged: 06/19/12
      #6142225 - 10/17/13 02:21 AM
I know - Have you tried both, and if so, do you like the Plossl better?
-Chuck
BillP
Reged: 11/26/06
Loc: Vienna, VA
      #6142543 - 10/17/13 09:45 AM
The Edmunds 28mm Plossl is nice and has around 22mm ER I believe and lens mounted high. Not fully multicoated though, or in the FL range you want but a very nice performer!
The 30mm Plossl from Surplus Shed looks to have a high mounted eye lens. Give them a call to validate...they usually are good over the phone helping out.
30mm Plossl
Set 3 Plossls (better view of 30mm)
31mm Eyepiece (3 elements and 35mm ER)
izar187
Reged: 09/02/06
Loc: 43N
Re: inexpensive 30-35mm Plossl for eyeglasses use [Re: Lew Zealand]
      #6142555 - 10/17/13 09:50 AM
Consider a GSO 32mm plossl.
Very eyeglass friendly.
Retailed under many different brand names.
Very affordable new, and even more so used.
I paid $20 for my last used one, shipping included.
They look like this:
http://agenaastro.com/gso-32mm-plossl-eyepiece.html
SpaceConqueror3
Reged: 09/19/13
      #6142921 - 10/17/13 01:09 PM
I think thats a little low for the cost of a used TV 32mm plossl. In the last 60 days, sales of this eyepiece on Ebay ranged from $95-120 less shipping, with the average probably around $110.
Starman81
Reged: 03/06/08
      #6142943 - 10/17/13 01:17 PM
I think $85-$90 might be the average, but keep in mind I am shooting from the hip. With that being said, I watch CN Classifieds and Astromart like a hawk, but not eBay. The three that I have owned over the past 18 months I paid: $85, $75 and $75.
Lew Zealand
Reged: 06/28/04
Loc: Pasadena, CA
      #6144133 - 10/18/13 01:54 AM
Thanks for all the suggestions, everyone! The TV Plossl, while the best, is probably overkill for this application so I'll be looking at the Vixen, which looks good, and the Omni. In fact, Bob's comment that you don't even need to touch the Omni to see the full FOV is exactly what I'm looking for.
Bill, The 30mm Surplus Shed EP looks nice from the photo, night and day difference on where the eye lens is set compared to my Meade.
Izar, I've looked at that GSO Plossl a number of times online but can't get a photo to see how recessed the eye lens is.
Ron, that looks like a project for me and Little Zealand #1, especially since you can buy the pair of doublets for the EP ready-made. This is very intriguing as I used to be a DIY person and have fallen off the bandwagon since having kids. This looks like fun…
Hmmm now I have too many options, such wonderful "problems" to have…
19 registered and 32 anonymous users are browsing this forum.
