Telescope Specific Forums >> Meade Computerized Telescopes
sirreg2112
newbie
Reged: 03/07/10
autostar II Cable
      #6143043 - 10/17/13 02:10 PM
I need a cable to connect the autostar II to the LX-200R. I've seen elsewhere that a regular telephone headset cable will work. Is this true?
Reg
maugi88
Reged: 08/25/13
Loc: SE MN
Re: autostar II Cable new [Re: sirreg2112]
      #6143755 - 10/17/13 09:11 PM
Compared my autostar II cable to corded phone headset cord. Looks the same.
Don't know if gage matters.
nitegeezer
Reged: 11/27/07
Re: autostar II Cable new [Re: maugi88]
      #6143771 - 10/17/13 09:18 PM
It uses the same connector but most phone cables are either 2 or 4 conductor but the connector will support 6 conductors. I don't know if the other 2 conductors are needed but I had a 6 conductor cable so I used it. A 2 conductor cable will not work.
maugi88
Reged: 08/25/13
Loc: SE MN
Re: autostar II Cable new [Re: nitegeezer]
      #6143802 - 10/17/13 09:35 PM
My auto star and phone cords are four conductor
LoveChina61
Reged: 06/20/09
      #6143999 - 10/17/13 11:48 PM
I would carefully double-check this further before plugging it in and giving it a whirl. If I remember correctly, the colored wires should be reversed when viewing the connectors at each end of the line. For example, if one of the connectors (viewed from left to right) has Red, Blue, Yellow, and then Green wires coming out of it, then the connector on the other end (also viewed from left to right) should have the wires reversed so that you see Green, Yellow, Blue, and Red.
Double-check to be sure cause I almost fried my LX200 Classic scope trying to make the correct cable that would allow me to control the scope with my laptop. Smoke was pouring forth and I had to quickly yank the wire out to save the scope.
It might seem ridicules to have to pay about $20 for the cable on eBay (for example), but it may end up being the best $20 you ever spent
Edited by LoveChina61 (10/18/13 11:00 AM)
cavefrog
Reged: 11/11/08
Loc: loozyanna
Re: autostar II Cable new [Re: LoveChina61]
      #6144056 - 10/18/13 12:36 AM
yes it is true. a telephone HANDSET (wire for between the base and what you hold to your ear) with 4 conductors (must have 4 conductors not 2) will work. That is what I use on an LX200 GPS with an Autostar II. It looks like the same thing on a classic, but it will not work on a classic. (runaways freezes and such ilk)
Theo
AnhTuan
Reged: 03/31/11
Re: autostar II Cable new [Re: cavefrog]
      #6157563 - 10/25/13 02:29 PM
It's a typical RJ11 4-pin type connector. I don't know if the wire is crossed or straight. Check the color on the wire.
For straigh cable, position 1 should always has the same wire color. For crossed wire, position 1 has wire in position 6, and position 6 has wire position 1.
2 registered and 12 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
